new guy on the block with a question - JeepForum.com
post #1 of 8 Old 02-07-2009, 06:55 PM Thread Starter
CT98XJ
Xj new guy on the block with a question
hey all im joe, i just picked up a 98 cherokee sport today it has a I6 with a 5spd.. I was informed today that the 3:07 gears suck with a lift or any bigger tires is there any truth behind that? lets discuss this.
CT98XJ is offline
post #2 of 8 Old 02-07-2009, 07:17 PM
91xjgawes
its discussed daily...
try this
http://www.jeepforum.com/forum/search.php?f=11
blue jeep club member 174
2001 xj- 2 inch bb moabs
1998 zj 5.2- 245/75's moabs
91xjgawes is offline
post #3 of 8 Old 02-07-2009, 07:22 PM Thread Starter
CT98XJ
thanks for the Help! ....
CT98XJ is offline
post #4 of 8 Old 02-07-2009, 07:28 PM
91xjgawes
no problem, quick answer, 3.07 are not optimal... with a 31x10.50 it will do alright but if you go bigger then the need to regear increases.
it does not bother some people as it does others i personally dont like 3.55s with 32's, but someone else, or you may not mind it.
post #5 of 8 Old 02-07-2009, 07:37 PM Thread Starter
CT98XJ
thanks for the info now im kinda disappointed my buddy has a 89 2dr cherokee with 32's and does fine cruises fine with the auto trans. where is a good place to get the gears to re gear?
CT98XJ is offline
post #6 of 8 Old 02-07-2009, 07:40 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You're best bet for the manual transmission would be to snatch the axles from an auto, at the junk yard. They will have 3:55's and perform well with 31's or 32's on your 5 speed. It will be a lot cheaper than regearing your current axles. Just be sure to find one with the 8.25 in the rear, and the 97-up will be the 29 splined axles.
xjfever is offline
post #7 of 8 Old 02-07-2009, 07:43 PM
91xjgawes
also dont get the front axle out of a 00-01, its lp...
post #8 of 8 Old 02-07-2009, 07:44 PM Thread Starter
CT98XJ
thanks guys for the help i deff look forward to learning alot about jeeps from ya;ll
CT98XJ is offline
Electrical and fuse block replacement question cardana24 XJ Cherokee Technical Forum 1 01-02-2008 09:15 PM
new fuse block? am i a block head? 2nd alt? futurefd XJ Cherokee Technical Forum 3 02-12-2007 11:37 AM
Hood Alarm/Block Heater Question fridge XJ Cherokee Technical Forum 5 11-16-2005 11:33 AM
Engine Block (etc) swapping question, concerning camshaft and more BlewMeAway XJ Cherokee Technical Forum 5 07-15-2005 08:30 PM
Question on running lift block? completed air tube DW 97 XJ XJ Cherokee Technical Forum 1 01-06-2005 09:16 PM
