Need a quick answer-Tcase chain slack - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Need a quick answer-Tcase chain slack
July 4th Sale Event! and Yes, We're Open!Metalcloak: Celebrate Freedom with Free ShippingThe Cure for your Tie Rod Roll!
Unread 05-20-2015, 07:21 PM   #1
FairlanePhil
Need a quick answer-Tcase chain slack: ANSWERED
Posted in WDYDTYCT thread as well, sorry for the dupe post but I want to put this back together ASAP
Is this amount of slack normal?
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 07:28 PM   #2
AKIQPilot
AKIQPilot's Avatar
It looks to be about right actually. I did a quick Google image search and yours looks like it has less slack than any other picture posted.
http://www.google.com/search?q=n+231j+chain+slack&client=firefox-a&hs=faw&rls=org.mozilla:en-USfficial&channel=sb&source=lnms&tbm=isch&sa=X&e i=SDRdVY7bO47egwS9koHwCw&ved=0CAkQ_AUoAw&biw=1536& bih=890
AKIQPilot is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 07:31 PM   #3
FairlanePhil
Dang, good thinking. I didn't think to image search :/
Unread 05-20-2015, 07:32 PM   #4
AKIQPilot
AKIQPilot's Avatar
I read through several posts an yours may have a bit more slack than it should. Do you notice any marks in the case where the chain has slapped it. A brand new chain will have about 3/4" of clearance from the bottom of the drooping chain and the inside of the case.
Unread 05-20-2015, 07:56 PM   #5
FairlanePhil
I did check for clearancing on the inside of case and did not see any marks. The gear teeth all look uniform and unworn.
There was no play in the shaft or tailshaft bearing.
I will say that my growl does seem like it's coming from the T case.
I did a search for "Growl on Deceleration" and found a bunch of posts on a variety of forums.
Almost all were solved with an SYE
Funny thing. In my search I found this old thread I made about my last Jeep.
http://www.jeepforum.com/forum/f11/g...1299991-print/
Ujoint fixed that one for a while. SYE eventually cured it
