Need new headlight frames - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Need new headlight frames
CCOR is Hiring! Athens, GA!ZONE 4.25" combo lift for TJ available at Rockridge4wBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 08-09-2015, 08:31 PM   #1
MtBoy
Hey all, I am looking for some simple advice. My son's 96 XJ needs new Headlight frames, as the screw hole on the drivers side cracked and the side light is falling out. I believe they would be considered flat black. My question to you guys is where to order and what brand is a good quality? I see some cheap ones and some expensive ones online but its hard to tell the difference. Has anyone purchase some that they were happy with?
Thanks
MtBoy is offline   Reply With Quote Quick reply to this message
Unread 08-10-2015, 06:59 AM   #2
S8NNG8
1995 XJ Cherokee
Junk Yard! Stock ones will likely be of better quality, and cheaper.
D3<!L!>3D
S8NNG8 is online now   Reply With Quote Quick reply to this message
Unread 08-10-2015, 02:05 PM   #3
bluejunior
If you can't spot one in a junkyard easily, Rockauto has replacements for like...3 bucks each. They call them headlamp doors IIRC. I just picked up a pair for my '01 because there are next to no XJ's in junkyards here that weren't put there by a major front end collision.
Lifted, Locked, Stiffened
Build
bluejunior is online now   Reply With Quote Quick reply to this message
Unread 08-10-2015, 04:36 PM   #4
S8NNG8
1995 XJ Cherokee
No, they're actually called headlight bezels.
D3<!L!>3D
Unread 08-10-2015, 05:41 PM   #5
bluejunior
Not on rockauto. Just double checked the catalog.
Build
Unread 08-10-2015, 08:32 PM   #6
lsmurphy
Doors or bezels..........both are correct.
lsmurphy is offline   Reply With Quote Quick reply to this message
Unread 08-10-2015, 09:03 PM   #7
bluejunior
I call them bezels in normal conversation I'm not trying to argue or anything, just specifying what to look for when searching through certain parts catalogs
Build
Unread 08-10-2015, 09:10 PM   #8
MtBoy
Thanks guys. I think I have also seen them called headlight frames too. Your right the wrecking yard is probably the best option but I am not familiar with the best places to look. I know some are real cheep online but are they cheep in quality?
Unread 08-10-2015, 09:14 PM   #9
bluejunior
Generally they're thinner plastic than OEM, not all but i try to go junkyard when i can to be safe. Though other than being black instead of paint matched i could tell any difference between my stockers and the replacements i bought. That was for a 97-01 front end though
Build
Unread 08-13-2015, 04:08 PM   #10
Ferryman
Quadratec.
http://www.quadratec.com/products/pr...26+Rings&c=224
Ferryman is offline   Reply With Quote Quick reply to this message
Unread 08-13-2015, 05:31 PM   #11
MtBoy
Originally Posted by Ferryman View Post
Well that is where I actually ordered from. I got the ones manufactured by Crown Automotive. I guess we will see what we get, I guess that cannt be any cheaper than the one that broke.
Thanks guys
Unread 08-13-2015, 05:43 PM   #12
bluejunior
Thanks guys
Crown stuff is generally good. You'll be fine.
Build
