Quantcast need a jy alternator - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > need a jy alternator
Old 09-01-2009, 01:59 AM   #1
8990jeepster
1989 XJ Cherokee
just got my first jeep a 89 xj 2wheeldrive , but for $300 notbad for a starter ,and all ready lined up a doner 4X4 but at least it is a 4.0 just need a jy bolt in alt 4 2 months till school is out. I think the firebird gm is a direct bolt in any help thanks in advance sorry if already talked till death.
8990jeepster is offline   Reply With Quote
Old 09-01-2009, 09:35 AM   #2
XJH-007
I drank what?
XJH-007's Avatar
*I got this one*
<rolls up sleeves>
WTF ARE YOU TALKING ABOUT?
When you say JY do you mean YJ? as in a Wrangler or JUNK YARD? Are you asking if a GM alternator out of a Firebird will fit an XJ? Are you just randomly looking around the backyard trying to get stuff to fit?
Similar alternators that will fit your XJ will be from vehicles of similar build. Cherokees/Wranglers/Grand Cherokees/Dodge Dakotas but they will have to be of a similar year. This is in NO WAY a gurantee it will have the right pulley/connector/AMP rating....
I think it's best if you went to a salvage yard and picked up a $5 unit from an XJ of similar year. OR go buy a remanufact. unit....they can be had pretty cheap. ($40)
Trying to get some other random alternator to fit could cause major problems since AMP's could be diff, direction of power generation, plugs...including, computer fry, fire....
...oh and welcome to the FORUM!
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline   Reply With Quote
Old 09-01-2009, 05:05 PM   #3
8990jeepster
1989 XJ Cherokee
thanks for the info but just to clear up a few things the only reason i asked about it is I saw that it was a possible upgrade over the 90amp to136. Secondly if u actually look at the rotation of a 89 4.0 to gm 350 alt the rotation is the same. The real question is what modifications u would have to make to the brackets .The plug is no big deal has long has u can read a wiring diagram and connet A to B .
Old 09-01-2009, 05:10 PM   #4
Fletch8672
1975 CJ5
Originally Posted by XJH-007 View Post
*I got this one*
<rolls up sleeves>
Well done! But you forgot to tell him that all XJ owners are required to watch "2 Girls 1 Cup" before they are allowed to start posting here.
Present: 96 XJ ~Black~ , 75 CJ-5 ~Blue~
Past: 95 YJ ~Bright Mango~ , 96 XJ ~White~, 72 CJ-5 ~Baby Blue~
Remember: Owning A Jeep is a lot like having Herpes, sure it may act up from time to time but you'll never get rid of it...
~Black Jeep Society~
Fletch8672 is offline   Reply With Quote
Old 09-01-2009, 05:12 PM   #5
XJMuscle98
You can get a 136a alternator that iwll be a direct fit in the following vehicles :
* 1997-1998 Dodge B.Series Van
* 1997-1998 Dodge Dakota
* 1998 Dodge Durango
* 1997-1998 Dodge Ram Pickup
* 1997-1998 Jeep Grand Cherokee
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline   Reply With Quote
Old 09-01-2009, 05:15 PM   #6
Fletch8672
1975 CJ5
That makes as much sense as going to an Indigo Girls concert and expecting to get laid...
Dude, it would save you A LOT of potential headaches and frustration if you go to the JY (junkyard) and pull an alternator out of an XJ (Cherokee).
...and welcome to the forum~
Old 09-02-2009, 09:27 PM   #7
8990jeepster
1989 XJ Cherokee
Thanks for the advice MattEagan
Old 09-02-2009, 09:46 PM   #8
Holder350
1995 XJ Cherokee
now.....I have to say this idea has come to mind.....
A GM self exciter alt on the 4.0 cranking out 70-80 amps would be great and could be rebuilt for cheap.
however...personally with the absence of the CEL to be able to tell when something is really wrong, I would only try this on a carb setup.
Also something to keep in mind is that if you go with the bigger alt you may have to remove the bracket and do some grinding to make it fit.
95' XJ Country - Stock Skids - Limited Slip Rear Diff
Off Road Package - 4.0 HO - AX15 - NP231
Repeal Ohms Law!!!
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline   Reply With Quote
Old 09-03-2009, 01:37 AM   #9
keepishop
keepishop's Avatar
1989 XJ Cherokee
People! We have a problem! You're all recommending Mopar alts! OP has a 1989, that's a GM alt. There are bolt in alternators from similar year Cadillacs that will give higher output, but you would have to grind the brackets to make room. Easiest thing to do is find an alt from a 86-90 4.0 XJ, or an identical one from a GM. You may have to splice the field wires as you mentioned.
This is the one for the renix 4.0 XJ from schucks.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline   Reply With Quote
Old 09-03-2009, 08:38 AM   #10
RedZeppelinXJ
ok if you want more power out of your alternator get one from a ZJ ('93-98 Grand Cherokee) but it needs to have the V8 engine. it will take a little bit of grinding to make it fit but it will take you from 90 amps to like 138 amps.....if you want more info go to the cherokee technical forum and look up this thread: Budget Builds: What junkyard parts will fit an XJ?
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Laredo - The Grizzly Bomber (Trail Rig) 4.0/AW4/NP242/HP30/D35, 2"BB 31's
'91 XJ Briarwood - The Spruce Moose (Club Project) Can you say Chop-Top?
'79 J10 - Spartacus (Farm Project) 360/TH400/BW1305/D44's
RedZeppelinXJ is offline   Reply With Quote
Old 09-03-2009, 08:55 AM   #11
99Greenmachine
X100 on the '98 136A...I need to do this soon myself
'99 XJ Sport MY BUILD
Thank You Hooligan!!!
XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA!
99Greenmachine is offline   Reply With Quote
Old 09-03-2009, 09:11 AM   #12
keepishop
keepishop's Avatar
1989 XJ Cherokee
Like I just said, a ZJ alt won't work. The ECU regulates the voltage on Mopar alts, and this guy does not have a Mopar alt, he has a Delco alt. You want more amps, you get it from a Cadillac, or a GM truck. You *can* hack an external ford voltage regulator up if you really want to use a Mopar alt, but why bother?
1984-1990 Cherokees have DIFFERENT ACCESSORIES UNDER THE HOOD from 1991 and later Cherokees. AMC was smart, they went with Chevy stuff under the hood, it was cheap, reliable, and plentiful.
Bleed or Quit.
Old 09-03-2009, 11:25 AM   #13
Holder350
1995 XJ Cherokee
DUH......
why did I not notice that.....I guess cause it was a XJ and not a CJ
But its true....The renix motors had Delco Alts instead of Denso.
And to think theres no telling how many of these I have rebuilt.
Repeal Ohms Law!!!
Old 09-03-2009, 07:29 PM   #14
keepishop
keepishop's Avatar
1989 XJ Cherokee
Whew, I thought I was going crazy there for a minute.
Bleed or Quit.
Old 09-04-2009, 12:18 PM   #15
keepishop
keepishop's Avatar
1989 XJ Cherokee
http://www.jeepforum.com/forum/f11/136-amp-alternator-mod-338597/#post2950414
That guy was able to use a mopar high output alt in a renix using an old dodge voltage regulator. Should be everything you need.
Bleed or Quit.
Glock Forum
