need help with my xj - JeepForum.com
post #1 of 5 Old 07-20-2014, 06:06 AM Thread Starter
loudliftedjeep
ok i have some questions.right now i have a rough country 3 inch lift on my xj.2inch in back 3 in front.wanna go bigger but dnt have much money.so plan on buying 2 inch spacers for front.3inch block for back.and get transfer case drop kit.any other things i have to do if im doin 5 inches of lift?like control arm drop.also can i clear 35 inch tires if i trim fenders
loudliftedjeep is offline
post #2 of 5 Old 07-20-2014, 07:35 AM
93gc40
You can do the 35" at 3" and l;ots of trimming so 5" no problem. 5" of lift you should plan to need a new Adjustable trackbar, longer lower control arms and/or LCA Drop, longer brakelines, longer swaybar links, longer shocks, SYE (tc drop might work), and new axle gears (to turn the 35s).
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #3 of 5 Old 07-21-2014, 06:55 AM
VNilla
Going that high will be expensive not matter how you do it. I'd say wait so you don't have to use spacers.
1998 Cherokee
Breaking bolts and taking names.
VNilla is offline
post #4 of 5 Old 07-22-2014, 10:18 PM
TylerU
Problem is if you got Dana 30 and aw4, even if you can put on 35s with whatever lift and trimming, it's gonna be too hard for your tranny and axle. I know people who snap your stock axles. That's why there is Dana 44, 60, super 60.
TylerU is offline
post #5 of 5 Old 07-23-2014, 09:29 PM
Renix
1989 XJ Cherokee
I would stay away from blocks in the rear. It will get expensive going to 35's, You should look at the RE coils and rear leafs. You could get the coils for $100 bucks and the rear leafs for $200 on amazon. Then you could piece the rest together with time. New shocks for added lift, longer trackbar, and brakelines ASAP. Start reading as much as you can about lifting your Cherokee so you can do it right and not have to back track
Renix is offline
