Need help fixing a bumper! - JeepForum.com
post #1 of 12 Old 05-28-2013, 12:49 PM Thread Starter
ColinWK
2005 WK
Long story short, I'm stupid and my WK's bumper made out with my friend's XJ's bumper. It made a dent right in the middle of his rear bumper (no damage to mine) and will not allow his trunk to open. Are there any cheap fixes for this? He doesn't want to replace the whole thing if he doesn't have to.
ColinWK is offline
post #2 of 12 Old 05-28-2013, 12:54 PM Thread Starter
ColinWK
2005 WK
looks like the second picture isn't loading...Let me try that again
ColinWK is offline
post #3 of 12 Old 05-28-2013, 01:08 PM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
That's toast. A used rear bumper shouldn't be more than 50$
April 2014 & 2015 COTM
MOBBiN is offline
post #4 of 12 Old 05-28-2013, 01:11 PM Thread Starter
ColinWK
2005 WK
Anyone know how to pop out a dent in the rear bumper?
Friend got a dent in his rear bumper that won't allow him to open the liftgate. anybody know of a cheap way to fix it rather than replacing the bumper itself?
ColinWK is offline
post #5 of 12 Old 05-28-2013, 01:12 PM
chriskeenan
I did about the same thing but with a tree instead of a WJ. Hammer out the dent with the BFH so the hatch will open and replace the bumper if you want.
chriskeenan is offline
post #6 of 12 Old 05-28-2013, 01:14 PM
austin6137
1990 XJ Cherokee
Unbolt it and beat it straight, not much else you can do other then replacing it.
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #7 of 12 Old 05-28-2013, 01:17 PM
austin6137
1990 XJ Cherokee
Why do you have two thread going about the samething
post #8 of 12 Old 05-28-2013, 03:29 PM
dmill89
1995 XJ Cherokee
^ This, the BFH (Big *&%$ing Hammer) method tends to work best for this. It won't look great, but at least they should be able to open the door.
Though they might just want to replace it, a new rear bumper for an XJ only costs about $40 (OE style) and a used one from a junk yard should be even cheaper.
http://www.rockauto.com/catalog/x,ca...,parttype,1340
Of course for about $200 they could put a heavy duty bumper on it and never have to worry about it getting dented again.
dmill89 is offline
post #9 of 12 Old 05-29-2013, 10:06 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I merged these duplicate threads into one in order to minimize confusion.
***Chris***
chris87xj is offline
post #10 of 12 Old 05-30-2013, 09:44 PM
scottmphoto
1991 XJ Cherokee
Cheapest way is to use a BFH and beat on it. He could always upgrade it and get a real bumper.
scottmphoto is offline
post #11 of 12 Old 05-31-2013, 12:44 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
yah I'm not sure how else one would fix dented/bent sheet metal.
If you happen to have contacts with a local jeep club, you might be able to get a decent take-off bumper really cheap from someone upgrading to a heavy duty off-road type.
***Chris***
post #12 of 12 Old 05-31-2013, 06:28 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Mine hasn't kept me for opening the hatch, but I used a large C-clamp on the top/bottom, while prying from the back side with a hooked crow bar. Once you can get to the 8 bolts that hold it on, lay it on a wooden surface and grab a sledge. Pin down the ends so you don't turn the whole bumper into an arch.
D3<!L!>3D
S8NNG8 is offline
