Need Feedback On This Info Received Plz! - JeepForum.com
post #1 of 3 Old 08-06-2008, 10:56 PM Thread Starter
the303hooligan
Question Need Feedback On This Info Received Plz!
Ok as you guys can see im in the market for an XJ...I asked for specs on this guys XJ that might poss be an option for me.. but i need some feedback..Am i making a mistake to go as old as 1992?..was looking for more of late 90's model that a little more updated...Also he's running 36 swamper on 3.73 gearing...kinda concerns me about the wear n tare on um...So thought i might run this info by you enthusiasts to see what you think and stuff i need to look out for...Thanx
Ok it's a 4 door 1992 Jeep Cherokee
*4.0 inline 6
*Body is all rihno paint green and black on lower
*36 inch super swampers and also have a set of thin thin 35 mtrs
*Rear end is 8.25 with locker full time
*Gears are 3.73
*Lift is 8in sky jacker mid arm extreme flex lift with the front trus for dif.
*Has no Swaybars
*4.0 ho motor and auto tranny (no motor noise tranny is solid 4x4 works awesome) Very Powerful!
*The midt is all hym joints
*Changed both front doors to 1998 full power Cherokee doors (gray int.)
*2in receiving Hitch
*Rancho 9000s (the new style ones that have the huge shaft adj)
*Custom built front steer bar and drop pitman arm
*Front left fender and both doors minor dents
Colorado Jeep Club Member #'303'
1998 Jeep Wrangler TJ Sport 4.0 I6, D30 and D44,4.56 G2 Gears,belly,gas & steering skids, 35x12.5 Wrangler MTR Kevlars,4" ProComp Coils,1.25" JKS BL,1"Currie MML,Bilstein 5100's, Chromoly LCA's front and rear, JKS Disco's,K&N intake,PSC BFH front stinger bumper w/winch & d-rings,PSC Rear stinger/carrier w/d-ring,PSC Rocker Knockers,Dynomax Ultraflo welded ss, APN header,PIAA 520 ATP, Bestop top,alpine CDA-105 deck,Tuffy underseat Security box, JL Audio speakers in sound bar and dash, Corbeau front seats, matching Neoprene cover on bench,trimmed flares...and PLENTY more to come..
**Oil Field Trash Makin' Oil Field Ca$h**
the303hooligan is offline
post #2 of 3 Old 08-06-2008, 11:28 PM
wil badger
How much is he asking?
So far it's vehicle that is way under powered with 36" tires and 3.73's.Trans might feel fine but that doesn't mean the added stress of trying to move those meats around hasn't done a number on the clutch bands in the trans.It might feel strong now but who knows you get it out on a trail and the next thing you know you are stranded because the trans went south.Second it has a Skycrapper lift ,and the older one at that.That lift sucks hard.The the front truss/craddle comes loose none stop.The hiems that come with the lift are junk.Since its all hiems the control arms tend to transmit a lot of road vibration into the body/chassis.I do how ever like thier spring rate for the 8" coil,they worked well for me.
The rest of it doesn't sound to bad but really with lift being the high dollar item on the rig what are you saving by buying it.You would wind up replacing most of it which would leave you with a prebeat Cherokee with some items like shock,tires,and springs.
So you have to ask yourself a question do you feel like buying somebody else mistake?
wil badger is offline
post #3 of 3 Old 08-07-2008, 06:26 AM Thread Starter
the303hooligan
Thats exactly what i needed to hear!...My gut is telling me that there is somthing not 100% about his rig and to stay on track with what i am really looking for...Just neede an breakdow/opinion from someone that isnt as anxious as me to buy ....Thanks alot...
This is why this forum is king of them all!!!
Just received an e-mail with Grdaemon XJ Cherokee Technical Forum 4 01-05-2006 08:25 AM
Received the cup holder and... Mestopin XJ Cherokee Technical Forum 8 11-03-2005 10:54 PM
feedback on shocks Hell Raiser 106 XJ Cherokee Technical Forum 0 10-26-2005 03:35 PM
JKS Disco Feedback xjRalfy XJ Cherokee Technical Forum 3 07-10-2004 09:17 PM
Feedback on lift. chino85 XJ Cherokee Technical Forum 3 10-17-2002 10:33 AM
