My hardtop/softop XJ build - Page 6 - JeepForum.com
post #76 of 347 Old 04-02-2011, 07:27 PM Thread Starter
Hussler
1992 XJ Cherokee
No progress on the hard top today but I got a lot done on the floors. The floors will definatly be done by next weekend, which is when I hope to make "the big cut"
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #77 of 347 Old 04-02-2011, 08:13 PM
Motorcharge
Originally Posted by Hussler View Post
Oh, and what opinions do you guys have on this roof rack is going to have to be intergrated around the open top. Loose the moonvisor?
Moonvisor looks good and you don't seem em on XJs often. Not liking the rack, well the front of it anyway.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #78 of 347 Old 04-02-2011, 08:30 PM
rugsucka
I am also looking forward to this - this is the most interesting roof mod since the VW camper top - it must be a NY thing to hack open your roof. Matches the floors of most rust belt XJ's I guess.
re: Roof Rack
Looks like a headboard from a kids bedroom set. I'm just sayin'
I prefer a smaller stock type of roof rack look and square seems to be most common.
If you are just wanting to be different, I believe that roof rack achieves it.
Now that spring is really here, finish the floors and let's see some grinder sparks flying up top too.
rugsucka is offline
post #79 of 347 Old 04-02-2011, 08:49 PM Thread Starter
Hussler
1992 XJ Cherokee
[quote=rugsucka;11292740]I am also looking forward to this - this is the most interesting roof mod since the VW camper top - it must be a NY thing to hack open your roof. Matches the floors of most rust belt XJ's I guess.
re: Roof Rack
I'm actually going to use a circular saw to cut the roof so there is NO sparks. Last thing I want to do is spray more hot metal around in there.
Lowes sells a special blade that I will use in that Rigid I bought pictured on page 5
Hussler is offline
post #80 of 347 Old 04-02-2011, 08:56 PM
rugsucka
I like projects that give me the excuse to buy more tools too. I'm using axle ujoints as an excuse to buy a 3/4" breaker bar and at least a 36mm impact socket - maybe a whole set of big ol' sockets.
Your neighbours are likely used to seeing you work on your jeep, but kneeling on the roof with a skil-saw will probably top your other mods. You should get someone to take some pics and video you in action - it would make a good "it's a jeep thing" motivational.
rugsucka is offline
post #81 of 347 Old 04-02-2011, 11:19 PM Thread Starter
Hussler
1992 XJ Cherokee
Haha I definitely should get some in action shots! If I get all the sheetmetal down tomoorow I think I'll finish mapping out the roof in sharpie
I know the length and width and the XYZ of where I'll place the thing but some VERY special cuts need to be made in the corners. I've drawn out many diagrams so I now know the perfect trims that need to be made
Hussler is offline
post #82 of 347 Old 04-03-2011, 12:57 AM
toyotaguy
I just noticed this thread, and was skeptical when I saw it, but now I'm psyched! That's a really cool idea, I'm excited to see how it works out. My first thought was "why is he using plywood instead of sheet metal?" But after thinking about it I'm starting to see the merits of plywood. You're a braver man than I to be cutting up your roof, I'm sure it'll turn out great though, and I'll be jealous this summer when you're cruising around with the top off and I'm not! Good luck!
toyotaguy is offline
post #83 of 347 Old 04-05-2011, 09:28 PM Thread Starter
Hussler
1992 XJ Cherokee
I appriciate the kind words.
And to all that are still watching, I'm going to cut the roof this weekend, whether i'm ready for it or not. The floor still isnt done and my steering collum got ruined but im just going to pick up my sack and swing it even harder.
Hussler is offline
post #84 of 347 Old 04-06-2011, 05:32 AM
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
good.... I can't wait to see some progress... especially a big gaping hole in that roof
koolaid5 is offline
post #85 of 347 Old 04-06-2011, 07:33 AM
Brookhart63
Cut! Cut! Cut!
Brookhart63 is offline
post #86 of 347 Old 04-06-2011, 09:36 AM
tofuzeppelin
tofuzeppelin's Avatar
dude keep the rack the same as long as you stuff the front loop with lights it will look BA, other wise its iffy
01 TJ with some stuff
77 SJ Cruzer
Lifes to short for bad coffee and bald tires
tofuzeppelin is offline
post #87 of 347 Old 04-07-2011, 11:44 AM
tbeaton
can't wait to see how this goes. i was just thinkign about this, saw it in jp magazine last night.
tbeaton is offline
post #88 of 347 Old 04-07-2011, 10:31 PM Thread Starter
Hussler
1992 XJ Cherokee
I better get some compensation for it being in JP .
Anyways, im having a **** load of trouble with my broken steering column. I HAVE to figur out a solution by tomorrow AND have the floors done
Hussler is offline
post #89 of 347 Old 04-07-2011, 10:35 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
hows your column broken?
1990JEEPXJ is offline
post #90 of 347 Old 04-07-2011, 10:36 PM
Back_In_Black
cut that *****!
look what I found on youtube....I watched every video,from tips and tricks part one, all the way to this one. the 4 door looked so familiar, but when I saw this one I was like "Holy ***** its hussler!"
Back_In_Black is offline
The Trev-Rock Build....noobie build.. Trev-Rock XJ/MJ Cherokee Non-Technical Forum 1 03-20-2012 01:50 PM
Which should I build out of the other??? ct157167 XJ/MJ Cherokee Non-Technical Forum 3 01-19-2011 08:53 PM
I need your opinions. Build the one I have or buy a newer one to build up. Element96x XJ/MJ Cherokee Non-Technical Forum 5 02-13-2009 03:52 PM
XJ Softop? WAMPAROO XJ Cherokee Technical Forum 3 01-05-2007 01:40 AM
