My first mod...the headliner! - Page 3 - JeepForum.com
post #31 of 35 Old 07-12-2014, 06:43 AM
SSellers
Starting mine next weekend I reckon. Got the ebay headliner roll and three cans of Permatex Body Shop high heat headliner adhesive. Won't go back in for a while though....sold another car so have some cash to repaint the XJ and hopefully remove the evidence of what appears to be someone having dropped a piano on the roof. Going to take lots of before pictures of the trim for sure.
SSellers is offline
post #32 of 35 Old 07-12-2014, 10:19 AM
originalmon
1988 XJ Cherokee
Thanks for sharing these tips! Nice to see.
originalmon is offline
post #33 of 35 Old 08-12-2014, 12:29 PM
Riley/MN
Finished mine a couple weeks ago, seems to be holding okay. Messed up the visors while pulling them apart. Broke the little nubs that hold the things together. I am thinking I need to get a pair from the junkyard and cut the foam away, then carefully release the little plastic nubs...
~Riley
TMA MN State Rep
http://www.traditionalmuzzleloadingassociation.com
Riley/MN is offline
post #34 of 35 Old 08-12-2014, 04:02 PM
jeepjunkie97
Finished mine about a month ago as well. Before using ~2 cans of 3m super 77. Didn't hold everywhere. Few weeks later I used a hair dryer to activate the adhesive and peel the headliner back slowly (took like 3 days). That time I used ~4 and it did the trick. Stay up everywhere except behind the soundbar, little sag. But in my book it's a victory
jeepjunkie97 is offline
post #35 of 35 Old 09-03-2014, 08:15 AM
SSellers
Finally did mine the other day. Learn from my mistakes.
-After laying the headliner out, trim the excess off the ends so it's easier to work with especially if you're doing it alone. I didn't so I had over a foot hanging off each end. One side/half did OK but the other got slack and bunched on me when I was laying it down and stuck immediately, and then the opposite side from where I was holding touched down. Plus having a coat of glue on the headliner itself means if it happens to touch itself it sucks. F dash dash dash multiple times. Couldn't pull it back off and when I tried it would just catch somewhere else. It was like trying get a really bad booger off your finger without having anything to wipe it on times 1000. My wife was going to be off work the next day and told me to wait but nooooo old Steiner has to try everything alone. Of course she made fun of me later, but now she can't see it.....at least until the swelling goes down.
-If you can find sawhorses and a piece of plywood or at least a few boards for support that's the way to go instead of laying it on the ground like I did. On the ends you need to support the back of the board while pressing so it doesn't bend and crack. I didn't have any problems with that but i think it would've been easier to work on if elevated.
-Two cans of the the Permatex Body Shop high heat headliner adhesive was enough to do two coats on the board and one coat on the headliner. If you follow the directions (five minutes between coats and five minutes before final assembly) it will stick IMMEDIATELY.....so hard that on the places I tried to pull up it started pulling the board off or tearing the foam off and this was before pressing it down. On some of the youtube vids it looked like people sprayed the glue and then laid out the headliner right away and could reposition it a little as needed. I guarantee you ain't doing that with this stuff if you apply it using the instructions. Hopefully this also means it ain't coming loose.
Overall yeah I've got a few wrinkles/bunches in it but a couple will be covered by the full overhead console, and at least it'll be better than feeling like I'm riding under a deflated hot air balloon along with foam snow going everywhere when the windows are down. Maybe I should've just f'ed up the whole thing like that so it would look like wrinkle finish paint or like a giant brain. I'm trying to work up the motivation to redo it but I don't think it's going to happen any time soon. Don't let it scare you though, it would go pretty good I think if you don't follow my lead.
Steiner
1998 XJ Classic driver
1998 XJ Sport spare parts supply
SSellers is offline
87 XJ wet headliner. ??? tubbyzj XJ Cherokee Technical Forum 3 06-20-2009 02:55 AM
xj headliner wehr31 XJ Cherokee Technical Forum 5 03-04-2008 09:47 PM
$20 Headliner fix marioct XJ Cherokee Technical Forum 5 02-27-2007 08:55 PM
Headliner?? rob92xj XJ Cherokee Technical Forum 10 07-12-2006 12:39 PM
I did my headliner... Tjs88xj XJ Cherokee Technical Forum 22 08-17-2005 08:26 PM
