My First Jeep - Page 3 - JeepForum.com
post #31 of 112 Old 07-16-2013, 09:17 AM Thread Starter
PurpleToxin1
I have no clue, is there a way to find out without getting under there, i'm at work but super freakin curious now
PurpleToxin1 is offline
post #32 of 112 Old 07-16-2013, 12:04 PM
XJmike0122
Open the hood and see if you have this guy
Hope you don't cuz that means you could have the 8.25. Then just look under to see if your diff looks like this.
XJmike0122 is offline
post #33 of 112 Old 07-16-2013, 12:07 PM
XJmike0122
That's the 8.25 the best stock axle they come with.
post #34 of 112 Old 07-16-2013, 01:05 PM Thread Starter
PurpleToxin1
Is that what you have
post #35 of 112 Old 07-16-2013, 01:09 PM
T-REXJ
Here is my engine and diff I think im in luck
T-REXJ is offline
post #36 of 112 Old 07-16-2013, 01:14 PM
XJmike0122
Yeah luckier than I am. I have the ****ty little Dana 35.
post #37 of 112 Old 07-16-2013, 01:18 PM
XJmike0122
I found a 8.25 for 150 off a 98 thinking about getting it.
post #38 of 112 Old 07-16-2013, 01:41 PM Thread Starter
PurpleToxin1
Way cleaner than mine is lol. Ill check once I get home. But mike you should look for one out of a 4 cly, geared to 4.10
post #39 of 112 Old 07-16-2013, 01:53 PM
XJmike0122
**** I thought toxic Mike posted that. Yours is the 8.25 but will still don't know if its a 29 spline yet.
I would but I don't want 2 wheel drive until I have the money to re gear the front. Even then 4.10s are not the best for 33s. 4.56 is the best match.
post #40 of 112 Old 07-16-2013, 02:04 PM Thread Starter
PurpleToxin1
Yeah, your right in that in between spot. found this "From 96-down the chrysler 8.25 will be 27 splined axles, from 96.5-up they are 29 splined axles. The 96's will be hit or miss on the spline count and the only way to verify is to pull an axle and count."
post #41 of 112 Old 07-16-2013, 02:07 PM
T-REXJ
I will have to pull the axle then, don't know how but this will have to wait a week or two anyways
T-REXJ is offline
post #42 of 112 Old 07-16-2013, 08:06 PM Thread Starter
PurpleToxin1
I got the 8.25 and no abs
post #43 of 112 Old 07-16-2013, 09:52 PM
XJmike0122
Well that's one of us that don't need a new axle any way.
post #44 of 112 Old 07-16-2013, 10:02 PM Thread Starter
PurpleToxin1
The other Mike doesn't either, he can swap it out if he ever installs a locker. But 27 arent bad
post #45 of 112 Old 07-16-2013, 10:05 PM
Muddy97Cherokee
1997 XJ Cherokee
no 8.25 has ABS. ABS only came on the D35's.
Look and see when your jeep was built to see the spline count. A late built 96 will have a 29 spline. You could also look at the yoke. The 27 spline has a collar around the base of it. Its like this:
27 spline is on the left and and 29 on right.
But this isn't always correct since it is a model change. Only true way to get the count is too pull the yoke out and count the splines.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
