My Detour's Carrier bumper - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > My Detour's Carrier bumper
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 08-15-2010, 04:19 PM   #1
Fury3
Fury3's Avatar
This isn't a write up or a how too but I'll give a pretty good description and a few pics. I literally just got done with the install. The bumper came securely packaged in wood and heavy cardboard. Some bracing was added to the rocker guards to keep them in shape. The bumper itself has beautiful welds and came primed and ready to paint. I gave it a light sanding and used Duplicolor's rattle can bed liner. I'll report later on it's longevity. The bumper ties in where the old bumper mounted and with two additional mounts using the frame rail where the gas tank skid or stock hitch would mount.
It also mounts at the rockers themselves. Mark @ Detours suggested cutting and folding the rockers but I went a different route. After the bumper was bolted in at the rear, I cut open a 3" x 4" "door" on the inner skins of the rockers. This was to bolt the bumper to the outter rocker sheet metal using the supplied thick "washer" plates and allen cap screws. After bolting them up using a little thread locker, I pop riveted two pieces of 1/8" aluminum over the cutouts and siliconed everything really well.
Removing the outter rocker cladding added sort of a gap where the stock flares end and the bumper begins. To eliminate this gap I cut the old plastic claddings to about flare size and shaped them with a grinding wheel. I then drilled new holes to mount them near the top (the old mount at the bottom was still used). I used stainless steel pan heads with screw covers on the outside to keep things pretty and nylock nuts on the inside panel. I think they tie the bumper into the stock flares pretty well.
Overall I like this bumper for it's mounting strength and to me, it looks pretty cool. Best thing is I finally got the 31 incher outta my interior... I love the smell of tire in the morning....not really, well I didn't mind but the woman made a few comments. I also like having the room back. I like the angle of the carrier following the lines of the hatch too. So here's a few pics any questions ask away.
detours-004.jpg   detours-005.jpg   detours-001.jpg   detours-006.jpg   detours-008.jpg
Fury3 is online now   Reply With Quote Quick reply to this message
Unread 08-15-2010, 06:11 PM   #2
jccJeep
2007 WK
I love the all terrain meats!
USA
jccJeep is offline   Reply With Quote Quick reply to this message
Unread 08-15-2010, 06:27 PM   #3
Fury3
Fury3's Avatar
Thanks, they're TreadWright's Guard Dogs...31" x 10"
Unread 08-15-2010, 11:43 PM   #4
mg2000xj
How's the hing on the carrier? What's used for bearings and such?
-Morgan
'00 Silverstone 2 Door XJ
Utah Jeep Crew Member #119
My Webshots
New Build
Old Build
mg2000xj is offline   Reply With Quote Quick reply to this message
Unread 08-16-2010, 12:08 AM   #5
LiquidPT
1991 XJ Cherokee
Did you just drill new holes to move the plate right? I'm trying to remember the tailgate on my 91, and if it's possible. I really want this bumper though.
LiquidPT is offline   Reply With Quote Quick reply to this message
Unread 08-16-2010, 12:20 AM   #6
Fury3
Fury3's Avatar
The hinge is a post in socket design, with the post being scored to accept grease, there's a zerc atop for lubing it up. There is zero wobble to this while moving free enough to open and close easily.
Unread 08-16-2010, 12:24 AM   #7
Fury3
Fury3's Avatar
I used the right most holes on the hatch with the left holes on the plate and yes, I drilled two more holes in the hatch for the right holes on the plate. I had some 3m double face tape and put that underside the plate to keep it off the surface a bit and rattle free. In open holes on the left side of the old holder I reinstalled the screws and used screw covers to neaten it up.
Unread 08-16-2010, 07:22 PM   #8
LiquidPT
1991 XJ Cherokee
Is that a 1990 liftgate you've got on there? I had assumed the ones with the handle were newer than mine, not older...
Thank
Unread 08-16-2010, 07:42 PM   #9
Spokes
looks great!!! u got a purty xj!!!
Red 00 XJ lifted
Build -->http://www.jeepforum.com/forum/f177/...hread-1280981/
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline   Reply With Quote Quick reply to this message
Unread 08-16-2010, 08:59 PM   #10
303_XJ
What was the total price plus shipping? If you dont mind me asking
Colorado Jeep Club Member # 208
303_XJ is offline   Reply With Quote Quick reply to this message
Unread 08-16-2010, 09:13 PM   #11
stevieboy
Looking good, I love mine as well. Great product
99' XJ ~4.0L6~NP231~6" Hybrid RC lift~MT Classic Lock~Detours Custom Light Bar Brushguard~Detours TailBone~Hooker Aero~aFe stage2~KC slimlines~JKS ACOS~JKS Disco.~JKS track bar~JCR T.C.Skid~JCR Stage 3 sliders~JK bumper fogs
stevieboy is offline   Reply With Quote Quick reply to this message
Unread 08-16-2010, 10:15 PM   #12
Timboll
looks good since you added that plastic to the fender flare. i never liked the way that bumper looked without it.. looked unfinished
'01 Cherokee XJ - a work in progress...
Timboll is offline   Reply With Quote Quick reply to this message
Unread 08-17-2010, 06:24 PM   #13
Fury3
Fury3's Avatar
Thank
The lift gate is the ol' stock steel one that came with the jeep, Mine's a 2000
Unread 08-17-2010, 06:26 PM   #14
Fury3
Fury3's Avatar
I thought so too. Best thing is that it was virtually free to make the little flare add on from the old cladding. Besides the work all I needed to buy was a couple of stainless pan heads, washers, nylon lock nuts and screw cap covers. All gotten at Loews for around 12 bucks.
Unread 08-17-2010, 06:27 PM   #15
Fury3
Fury3's Avatar
How long have your had yours and what did you paint it with?
