My 92 XJ build - Page 45 - JeepForum.com
post #661 of 1103 Old 06-14-2013, 08:01 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Originally Posted by SFRautomotive View Post
so I'm thinking 37/12.5/17 MTR on some 17" steel d windows. And eventually some weld on beadlocks?
I would think you are exactly the kind of Jeeper that shouldn't go with bigger rims. Just a thought
D3<!L!>3D
S8NNG8 is online now
post #662 of 1103 Old 06-14-2013, 08:07 AM Thread Starter
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
17" is pretty much what everyone is going to now so the tire and wheel options are better.
And 17" really isn't that big for a 37" tire. And as far as I know there is no 37" mtr for a 15" wheel
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #663 of 1103 Old 06-14-2013, 08:11 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I suppose by the time the tires are that big... it'll look like 35's on 15's, but will create an illusion that the body of the Jeep looks smaller, like a 'Zuk'.
D3<!L!>3D
post #664 of 1103 Old 06-14-2013, 08:13 AM
VegasGT
1988 MJ Comanche
I dig this idea.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #665 of 1103 Old 06-14-2013, 08:58 AM
ibjeepin95
17" is a good option when you go 37's because you cut back on the amount of sidewall you would have if you ran a 15" wheel and 37's. Too much sidewall can be a bad thing.
ibjeepin95 is offline
post #666 of 1103 Old 06-14-2013, 09:16 AM
alexrule123
alexrule123's Avatar
You son of a birch!
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #667 of 1103 Old 06-14-2013, 01:56 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
Originally Posted by alexrule123 View Post
You son of a birch!
I can't help it
2013 COTY
post #668 of 1103 Old 06-14-2013, 02:34 PM
alexrule123
I can't help it
And MTRs no less!!!
post #669 of 1103 Old 06-14-2013, 05:11 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
And MTRs no less!!!
Sho nuff
2013 COTY
post #670 of 1103 Old 06-14-2013, 11:53 PM
aircruiser
aircruiser's Avatar
Id say go for it, only reason I am looking at 17s is for when I do bigger axles to clear the brakes. Plus they dont look all that bad, we run 37x12.5x17 MTRs on 17" beadlocks on the show TJ at work.
aircruiser is offline
post #671 of 1103 Old 06-16-2013, 04:59 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
I really want to do the weld on beadlocks at the same time as everything, but not sure the cash will be there
2013 COTY
post #672 of 1103 Old 06-17-2013, 05:53 AM
DNFJ
I will have 17" moabs soon enough too.
35/12.50/17s
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #673 of 1103 Old 06-17-2013, 08:46 AM
DNFJ
Originally Posted by DNFJ View Post
build me some of these. I want that.
This was a semi-serious post by the way.
Previous:
DNFJ is offline
post #674 of 1103 Old 06-17-2013, 09:20 AM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
The steering links?
2013 COTY
post #675 of 1103 Old 06-17-2013, 09:40 AM
DNFJ
The steering links?
yes
Previous:
DNFJ is offline
The Trev-Rock Build....noobie build.. Trev-Rock XJ/MJ Cherokee Non-Technical Forum 1 03-20-2012 01:50 PM
96 xj build atv_fanatic XJ Cherokee Technical Forum 6 03-21-2009 10:55 PM
I need your opinions. Build the one I have or buy a newer one to build up. Element96x XJ/MJ Cherokee Non-Technical Forum 5 02-13-2009 03:52 PM
92 XJ Build ddeadserious XJ Cherokee Technical Forum 30 12-26-2007 02:00 AM
