My 92 XJ build - Page 44 - JeepForum.com
post #646 of 1103 Old 06-12-2013, 07:40 AM
crockett07
1992 XJ Cherokee
Originally Posted by DNFJ
I'd comp cut because I'd tie together with sliders and a rear bumper as a mini-exo cage, plus tube fenders and have it tied to my rear quarter armor as well.
Oh and throw frame stiffeners into that whole thing too.
In that whole statement I didn't see te first reason to comp cut
crockett07 is offline
post #647 of 1103 Old 06-12-2013, 07:41 AM
ibjeepin95
But you wouldn't stretch? You do realize how pointless that would be and it would look like @ss, right? You can do all of those things without comp cutting it.
ibjeepin95 is offline
post #648 of 1103 Old 06-12-2013, 07:55 AM
DNFJ
Sometimes I forget I have a 4door and not a 2 door.
God how I want a 2door 97+
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #649 of 1103 Old 06-12-2013, 08:05 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I was gonna say, you don't have the room cuz of your back doors.
D3<!L!>3D
S8NNG8 is offline
post #650 of 1103 Old 06-12-2013, 08:32 AM
ibjeepin95
You can still comp cut an XJ, but don't do it unless you stretch it. My bud did his, but he only gained about 4" from turning the springs around. IMO, it was lots of work for not much gain.
post #651 of 1103 Old 06-12-2013, 08:48 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
And when you reverse the axle position to the rear half of the spring, the rear axle comes forward as the spring compresses. Not much, but it does reverse the arc of travel.
D3<!L!>3D
S8NNG8 is offline
post #652 of 1103 Old 06-12-2013, 08:50 AM
DNFJ
This is part of the reason why jeepspeed set ups are longer bastard packs with huge shackles. Then again, if regulations let you, they'd all run axle-unders so yeah.
Previous:
DNFJ is offline
post #653 of 1103 Old 06-12-2013, 09:53 AM
ibjeepin95
And backwards XJ springs wheel hop like a mofo...
post #654 of 1103 Old 06-12-2013, 09:54 AM Thread Starter
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
With the shackle in the back the wheel will still travel backwards during compression
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #655 of 1103 Old 06-12-2013, 10:22 AM
VegasGT
1988 MJ Comanche
Just get a decent 110. They are fairly cheap and you will be surprised what you can do with them. Hell, everything on my Jeep has been done with my 110.
X2. I have a 110 that Ive done odd jobs with and it does great and doesnt take up much space. Im about to use it to do my repair to my little rotted section of the rear unibody rail.
And lookin good SFR! Pictures never do anything justice and those look like some steep climbs. I bet they are even more pucker factor worthy in person.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #656 of 1103 Old 06-13-2013, 06:10 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
Thanks man. That place is really a blast
2013 COTY
post #657 of 1103 Old 06-13-2013, 06:11 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
So trying to sell my tires now. Trying to start collecting funds for a new wheel/tire combo
2013 COTY
post #658 of 1103 Old 06-13-2013, 06:31 PM
Motorcharge
Only reason I'd comp cut and stretch the rear wheel base would be if I converted to coils in the rear. I can't stand when people comp cut them and just leave the rear open like that without doing any body work. Drives me insane.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #659 of 1103 Old 06-13-2013, 11:42 PM
aircruiser
aircruiser's Avatar
Originally Posted by SFRautomotive View Post
really the only time the tires came off the ground were during a couple climbs where the ledge was steep enough to tilt the jeep to its vertical center of gravity. and that was just the suspension dropping out to full droop. during all the other somewhat steep climbs the suspension stayed neutral.
actual unloading characteristics are a little different.
Gotcha, I couldnt tell if it was just that steep or not. Pictures never do justice
aircruiser is offline
post #660 of 1103 Old 06-14-2013, 07:45 AM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
so I'm thinking 37/12.5/17 MTR on some 17" steel d windows. And eventually some weld on beadlocks?
2013 COTY
The Trev-Rock Build....noobie build.. Trev-Rock XJ/MJ Cherokee Non-Technical Forum 1 03-20-2012 01:50 PM
96 xj build atv_fanatic XJ Cherokee Technical Forum 6 03-21-2009 10:55 PM
I need your opinions. Build the one I have or buy a newer one to build up. Element96x XJ/MJ Cherokee Non-Technical Forum 5 02-13-2009 03:52 PM
92 XJ Build ddeadserious XJ Cherokee Technical Forum 30 12-26-2007 02:00 AM
