My 92 XJ build - Page 42 - JeepForum.com
post #616 of 1103 Old 06-02-2013, 01:33 PM
VegasGT
1988 MJ Comanche
Originally Posted by alexrule123 View Post
Don't lie you are really a 13 year old girl on the inside and love stickers.
Hello Kitty under the hood and ****
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #617 of 1103 Old 06-04-2013, 04:33 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
****ing knew it.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #618 of 1103 Old 06-05-2013, 07:32 PM
aircruiser
aircruiser's Avatar
In for more pics of skid! Finally ready through some of your thread, damn good fab work man
aircruiser is offline
post #619 of 1103 Old 06-07-2013, 09:26 AM Thread Starter
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
Thanks.
It's done for now. I'm out if time since I'm going wheeling this weekend.
But all the 1/4" mounting brackets are welded on and the shape is finished. The plate is secure but there are still about 10 more holes to drill and tap but I need to pick up some more countersunk bolts.
and I need to pull it back off and trim some of the aluminum backing plate just to clean it up.
But minus some bolts this is the finished skid. I really like the way the uhmv can smoothly conform to the uneven frame rail
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #620 of 1103 Old 06-07-2013, 09:54 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
How much did this skid project cost you?
D3<!L!>3D
S8NNG8 is offline
post #621 of 1103 Old 06-07-2013, 09:56 AM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
$70 ish
2013 COTY
post #622 of 1103 Old 06-07-2013, 10:13 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I got a 6'x3' stainless steel table from KFC. I'm gonna try to do the skids with the material.
D3<!L!>3D
S8NNG8 is offline
post #623 of 1103 Old 06-07-2013, 12:02 PM
aircruiser
aircruiser's Avatar
Did you order that UHMV sheet locally or online? I am going to see if I can get it cheap through my vendor but $50 sounds pretty reasonable.
post #624 of 1103 Old 06-07-2013, 12:13 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
Just make sure bracing is strong enough and the material is thick enough to survive
2013 COTY
post #625 of 1103 Old 06-07-2013, 12:14 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
Ordered from mcmastercarr online. Took like a day to get here
2013 COTY
post #626 of 1103 Old 06-07-2013, 12:45 PM
ibjeepin95
Originally Posted by SFRautomotive
Thanks.
Sweet. That should be nice and slick!
ibjeepin95 is offline
post #627 of 1103 Old 06-08-2013, 08:09 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
Packed and ready to go wheelin tomorrow.
Alex will not be participating since he does not feel like responding to text!....
2013 COTY
post #628 of 1103 Old 06-08-2013, 10:09 PM
alexrule123
alexrule123's Avatar
Hey I responded, just around 4 hours later.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #629 of 1103 Old 06-10-2013, 07:09 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
I don't know if a KFC table would be thick enough for a skid...
Previous:
DNFJ is offline
post #630 of 1103 Old 06-10-2013, 09:23 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Ya, I think you're right. But, as far as what I need them for, it's mostly protection from flying debris. That table is heavy, I'm not too keen on the idea of adding all that weight.
D3<!L!>3D
S8NNG8 is offline
The Trev-Rock Build....noobie build.. Trev-Rock XJ/MJ Cherokee Non-Technical Forum 1 03-20-2012 01:50 PM
96 xj build atv_fanatic XJ Cherokee Technical Forum 6 03-21-2009 10:55 PM
I need your opinions. Build the one I have or buy a newer one to build up. Element96x XJ/MJ Cherokee Non-Technical Forum 5 02-13-2009 03:52 PM
92 XJ Build ddeadserious XJ Cherokee Technical Forum 30 12-26-2007 02:00 AM
