My 92 XJ build - Page 38 - JeepForum.com
post #556 of 1103 Old 05-11-2013, 11:51 AM
Project1
Originally Posted by S8NNG8 View Post
My idea would save you from moving them at all. Go from l\___ to \____.
oh I see.. but the point of moving them up is for clearance .. like this
... Sorry for posting a bunch of pics in your thread brother
Project1 is offline
post #557 of 1103 Old 05-11-2013, 11:57 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Crazy! At that point you're shaving the floor out too.
D3<!L!>3D
S8NNG8 is online now
post #558 of 1103 Old 05-11-2013, 01:37 PM
Project1
yea .. a bit
Project1 is offline
post #559 of 1103 Old 05-11-2013, 04:00 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
That's one of the reasons it becomes alot of work. Also doors must be trimmed
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #560 of 1103 Old 05-11-2013, 04:37 PM
alexrule123
alexrule123's Avatar
You going to be at the shop tomorrow? I have a steering box for you.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #561 of 1103 Old 05-11-2013, 06:29 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
Don't think so. But I could meet you there
2013 COTY
post #562 of 1103 Old 05-12-2013, 07:56 AM
YoureverydayXJ
Originally Posted by SFRautomotive View Post
did some mocking and planning tonight.
tacked the crossmember together (still missing the side plates that will sandwich the framerail)
mocked it under the jeep, and marked will i will cut to make clearence for the bottom of the trans and driveshaft.
im thinking i will do this setup for my transmount off the front of the crossemember.
and cut up my floor some.
im going back and forth on how i want to mount the upper link mount.
either like this
or this, which is where im more leaning to because it will give me a little more frame seperation.
and how it looks from under.
and looks like i wont have to do way to much bending on the upper link to clear the starter.
couple more mock up pictures. pretty much just me figuring out exactly where im mounting my frame side track bar mount.
Did you ever put up pics of that low-profile transmission mount you came up with when it was finished? Did it just bolt to the face of the crossmember?
'00 XJ parts donor, '98 XJ body donor
YoureverydayXJ is offline
post #563 of 1103 Old 05-12-2013, 09:10 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
ill get some pictures tomorrow
2013 COTY
post #564 of 1103 Old 05-12-2013, 09:11 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
so im constantly tossing around the idea of going hatchless.....not sure yet what im going to do...
2013 COTY
post #565 of 1103 Old 05-12-2013, 09:43 PM
alexrule123
It's going to fold like a taco!
post #566 of 1103 Old 05-12-2013, 10:31 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Build a tube hatch tied into the stock hinge locations, and have it lock in the stock pin. This will retain the structural rigidity.
D3<!L!>3D
post #567 of 1103 Old 05-12-2013, 10:34 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Funny, this symbol is how I pictured the idea. This would be the supports in the hatch shaped hoop.
D3<!L!>3D
post #568 of 1103 Old 05-13-2013, 05:10 AM
ibjeepin95
X2. And then magically burst into flames. Because the interwebz says so.
ibjeepin95 is offline
post #569 of 1103 Old 05-13-2013, 08:45 AM
Project1
I'm pretty much hatchless ... And no cage and its holding up ..... And you have the cage and a lot more .. You will be good.
I really like your soft windows though ... Not a bad option. Did you make the windows yourself?
Project1 is offline
post #570 of 1103 Old 05-13-2013, 10:18 AM
YoureverydayXJ
Thanks dude. Are you happy with it so far? No issues?
'00 XJ not quite there..
The Trev-Rock Build....noobie build.. Trev-Rock XJ/MJ Cherokee Non-Technical Forum 1 03-20-2012 01:50 PM
96 xj build atv_fanatic XJ Cherokee Technical Forum 6 03-21-2009 10:55 PM
I need your opinions. Build the one I have or buy a newer one to build up. Element96x XJ/MJ Cherokee Non-Technical Forum 5 02-13-2009 03:52 PM
92 XJ Build ddeadserious XJ Cherokee Technical Forum 30 12-26-2007 02:00 AM
