My 92 XJ build - Page 25 - JeepForum.com
post #361 of 1103 Old 02-13-2013, 06:53 PM
crockett07
1992 XJ Cherokee
which did you end up ordering
crockett07 is offline
post #362 of 1103 Old 02-17-2013, 08:23 PM
ibjeepin95
WAIT, are you still running short arms up front? What brand? I need some sort of new arms, but I have no reason for a 3/4 link mid arm other than getting a flatter angle. I have no idea what I want to do...
ibjeepin95 is offline
post #363 of 1103 Old 02-17-2013, 09:22 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
these with some 90/100 bulbs
http://item.mobileweb.ebay.com/viewi...id=40149054928
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #364 of 1103 Old 02-17-2013, 09:25 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
Yes, for now. Just running some homeade uppers and some rear jk arms for lowers.
The flatter angle is nice, but the possible geometry improvement of a good 3/4 link setup makes it worth it. Stock geometry is pretty terrible for on throttle climbs IMO
2013 COTY
post #365 of 1103 Old 02-18-2013, 03:41 PM
Luke95
With your links how much was spent and is it possible to get down to 3 3.5 inches?
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #366 of 1103 Old 02-18-2013, 04:27 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
i do not remember how much everything was because i swapped in the 8.8, got a new driveshaft, and payed for an SYE all at the same time.
yes, you can get that low, but to do that you will have to french the coil mount into the frame rail.
2013 COTY
post #367 of 1103 Old 02-18-2013, 05:14 PM
Luke95
Ugh may just throw a spacer in and go to 4.5 total
Luke95 is offline
post #368 of 1103 Old 02-18-2013, 06:05 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
It's really not too bad, I kind of wish I would have gone that route originally. It would have opened up more coil options.
2013 COTY
post #369 of 1103 Old 02-18-2013, 06:09 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
I installed my autopals and 90/100 bulbs today. I'll have to get a night picture but the output difference is unreal. I can actually see at dark now.
2013 COTY
post #370 of 1103 Old 02-18-2013, 06:40 PM
Luke95
True but I if I do it I'd rather just put the coil mounts on the frame I'm ok at fab but the idea of cuttin the frame freaks me out a bit
Luke95 is offline
post #371 of 1103 Old 02-18-2013, 09:37 PM
ScottD16
Any pictures of how your cage ties into the frame? I can see the a-pillar but curious to the b-pillar and diagonals inside. I'm trying to get my hybrid cage planned out this week.
JEEP BUILD better late than never
I like to do the photography Flickr-
wheeling pictures and other random stuff Photobucket
ScottD16 is offline
post #372 of 1103 Old 02-18-2013, 09:53 PM
alexrule123
alexrule123's Avatar
Well where is the night picture? I already know what it looks like but I want to see a picture.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #373 of 1103 Old 02-18-2013, 10:01 PM
power73
what bulbs did you use?
power73 is offline
post #374 of 1103 Old 02-18-2013, 10:11 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
The interior b pillar is welded to a big plate that is welded to the floorboard on top of the frame rails. And the backseat bracing is just welded to a plate that is welded to my reinforced fenderwells.
The interior portion of the cage is more meant to add more rigedness to the body . And I'm still going to add 5 more interior tie in plates.
And the exterior which currently has 6 frame tie ins and 4 big roof tie ins, is still going to get an exterior b pillar tied into the sliders and a piece under the rear window that ties the the exterior b pillar to the rear exterior pillar. And few other tie ins. Just need some more tubing and time
2013 COTY
post #375 of 1103 Old 02-18-2013, 10:12 PM Thread Starter
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
Best I got right now
2013 COTY
The Trev-Rock Build....noobie build.. Trev-Rock XJ/MJ Cherokee Non-Technical Forum 1 03-20-2012 01:50 PM
96 xj build atv_fanatic XJ Cherokee Technical Forum 6 03-21-2009 10:55 PM
I need your opinions. Build the one I have or buy a newer one to build up. Element96x XJ/MJ Cherokee Non-Technical Forum 5 02-13-2009 03:52 PM
92 XJ Build ddeadserious XJ Cherokee Technical Forum 30 12-26-2007 02:00 AM
