-   XJ/MJ Cherokee Non-Technical Forum (http://www.jeepforum.com/forum/f177/)
-   -   My 92 XJ build (http://www.jeepforum.com/forum/f177/my-92-xj-build-1089525/)
SFRautomotive 08-16-2010 09:40 AM
My 92 XJ build
day one.
picked up this decent condition 92 XJ
Details:
4.0 H.O.
D30/d35 combo
np231
5spd
2dr
http://i12.photobucket.com/albums/a2...J/IMAG0019.jpg
http://i12.photobucket.com/albums/a2...J/IMAG0020.jpg
http://i12.photobucket.com/albums/a2...J/IMAG0021.jpg
http://i12.photobucket.com/albums/a2...J/IMAG0022.jpg
http://i12.photobucket.com/albums/a2...J/IMAG0023.jpg
http://i12.photobucket.com/albums/a2...J/IMAG0024.jpg
SFRautomotive 08-16-2010 09:47 AM
Next up Was a trip to the junkyard
My pickings...
99 Intake manifold and p/s pump off a WJ
http://i12.photobucket.com/albums/a2...J/IMAG0030.jpg
S10 leaf springs and a spare front driveshaft
http://i12.photobucket.com/albums/a2...J/IMAG0029.jpg
i also grabbed a set of brand new 2010 Rubicon shocks from the shop (only 20 miles on them)
http://i12.photobucket.com/albums/a2...J/IMAG0028.jpg
SFRautomotive 08-16-2010 09:57 AM
99 intake install
oldness
http://i12.photobucket.com/albums/a2...J/3bb4687f.jpg
oldness removed
http://i12.photobucket.com/albums/a2...J/11c6a72b.jpg
side by side
http://i12.photobucket.com/albums/a2...J/ddaaa974.jpg
installed
http://i12.photobucket.com/albums/a2...J/17b0d649.jpg
http://i12.photobucket.com/albums/a2...J/b0b20c88.jpg
i removed the upper idler pulley and had to trim the timing sight on the timing cover
http://i12.photobucket.com/albums/a2...J/e1ca2f92.jpg
http://i12.photobucket.com/albums/a2...J/e4bda48d.jpg
SFRautomotive 08-16-2010 10:04 AM
Time for the lift!
picked up some Rustys 4.5" coils and got to work
-made the bastard pack
-removed the sway bars
-made my BPE's and installed my JK rubicon shocks
-did a tc drop (more info on this later)
http://i12.photobucket.com/albums/a2...J/c2781b73.jpg
http://i12.photobucket.com/albums/a2...J/91caa06f.jpg
http://i12.photobucket.com/albums/a2...J/f717be2a.jpg
dont mind the exhaust, it has since been replaced
http://i12.photobucket.com/albums/a2...J/398c0e3a.jpg
some flex shots right after. the rear leafs have softened up after driving some the the backend now flexes better than in the pictures
http://i12.photobucket.com/albums/a2...J/fbc97dcd.jpg
http://i12.photobucket.com/albums/a2...J/b0c1ad0e.jpg
http://i12.photobucket.com/albums/a2...J/d0fa0584.jpg
http://i12.photobucket.com/albums/a2...J/f6fcb34b.jpg
http://i12.photobucket.com/albums/a2...J/11082bdc.jpg
http://i12.photobucket.com/albums/a2...J/b3f57d4f.jpg
full compression
http://i12.photobucket.com/albums/a2...J/7d710374.jpg
SFRautomotive 08-16-2010 10:11 AM
next, modified my hinges and made my doors removable.
http://i12.photobucket.com/albums/a2...J/4eeb4585.jpg
SFRautomotive 08-16-2010 10:14 AM
i picked up a set of 31/10.5/16 mud terrains and a set of 4 16's off of a JK along with a set of wheel adapters to run the 5x5.5 bolt pattern.
also i trimmed the front fender near the bumper to clean up the look some
http://i12.photobucket.com/albums/a2...J/d02de39f.jpg
http://i12.photobucket.com/albums/a2...J/8b1c07e7.jpg
itspeat 08-16-2010 10:16 AM
i just picked up a 91 2 door 5spd xj. except i had to do a lot more engine work because the person who had it before decided to not maintain it AT ALL.
I only got a 3" Rusty's lift though, i was going for the 4.5" but my dad talked me out of it...might still get some 1.5" shackles and spacers though.
Looks good!
SFRautomotive 08-16-2010 10:16 AM
and i mounted up half my kayak rack, i still need to modify the rear to work right.
http://i12.photobucket.com/albums/a2...J/48dc8f10.jpg
SFRautomotive 08-16-2010 10:17 AM
Looks good!
thanks, the 31's are only temporary till i build an 8.8 up and build the front up...then i will be going with 35's
SFRautomotive 08-16-2010 10:23 AM
i then removed the TC drop and modified the factory crossmember to have an internal Drop on 1.5's so i wouldnt loose any ground clearance.
http://i12.photobucket.com/albums/a2...J/b2239482.jpg
http://i12.photobucket.com/albums/a2...J/36130126.jpg
SFRautomotive 08-16-2010 10:25 AM
and then it was off to Jeep Beach in Daytona!
http://i12.photobucket.com/albums/a2...ch2010/ddd.jpg
http://i12.photobucket.com/albums/a2...2010/jeep2.jpg
http://i12.photobucket.com/albums/a2...95IMAG0072.jpg
http://i12.photobucket.com/albums/a2...95IMAG0053.jpg
http://i12.photobucket.com/albums/a2...0/IMAG0074.jpg
http://i12.photobucket.com/albums/a2...95IMAG0045.jpg
http://i12.photobucket.com/albums/a2...95IMAG0044.jpg
SFRautomotive 08-16-2010 10:44 AM
installed some KC's
http://i12.photobucket.com/albums/a2...J/be625779.jpg
http://i12.photobucket.com/albums/a2...J/1d99fc53.jpg
SFRautomotive 08-16-2010 10:45 AM
installed rear JK control arms for my LCA's
http://i12.photobucket.com/albums/a2...J/9525aa34.jpg
http://i12.photobucket.com/albums/a2...J/d711d145.jpg
SFRautomotive 08-16-2010 10:49 AM
installed YJ steering and began my floor repair
http://i12.photobucket.com/albums/a2...J/6f74ea36.jpg
getting rid of all the rust so that i can bedline my floor
http://i12.photobucket.com/albums/a2...J/bd3370f4.jpg
http://i12.photobucket.com/albums/a2...J/f878d37c.jpg
http://i12.photobucket.com/albums/a2...J/3803c7c4.jpg
http://i12.photobucket.com/albums/a2...J/788107dd.jpg
http://i12.photobucket.com/albums/a2...J/84673d4b.jpg
http://i12.photobucket.com/albums/a2...J/ed08cca1.jpg
still some more to do
SFRautomotive 08-16-2010 10:50 AM
and here is how it currently sits as of the weekend.
http://i12.photobucket.com/albums/a2...J/062f7028.jpg
http://i12.photobucket.com/albums/a2...J/d068e036.jpg
The time now is 08:34 AM.
