My 2000 XJ not leveled - JeepForum.com
post #1 of 7 Old 04-01-2012, 04:10 AM Thread Starter
Hamid
Hamid's Avatar
2015 WK
Hi:
My 2000 XJ is .60" lower at the LH side than the RH side, I thought I would remove the front shocks and lay'em on the ground and see if they have the same length. I also suspect the front insulation at the upper end of the front coils.
I would appreciate if some one show some can shed some facts on this subject.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #2 of 7 Old 04-01-2012, 08:00 AM
squashman702
1994 ZJ
Front shocks are identical. Have you checked the rear leaf springs? Those have a much greater tendency to sag, especially after 190k, and may be why the Jeep is sitting low on one side.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #3 of 7 Old 04-01-2012, 12:16 PM
VegasGT
1988 MJ Comanche
^ What he said. Plus take a look at your coil spring isolators. Check for any deterioration. More often than not its inconsistency in the leaf springs that will cause a "lean".
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #4 of 7 Old 04-01-2012, 01:44 PM
Motorcharge
Just out of curiosity, how are you measuring? Are you sure the ground you're measuring on is level? Half an inch difference isn't much.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #5 of 7 Old 04-26-2012, 05:48 PM Thread Starter
Hamid
Hamid's Avatar
2015 WK
I tore the front end down today, I removed everything, found the front LH shock is weak and almost 1" shorter than the RH. They are Gabriel Ultra.
Now what is best recommended front shocks for 1/2' lift?. thank you all for your help.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #6 of 7 Old 04-28-2012, 09:24 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Shocks provide no lift.
Springs, coil spacers, and shackles give you lift. The simplest and cheapest solution is to add an extra stock coil spring isolator to the low side, or just ignore it.
CJ7-Tim is offline
post #7 of 7 Old 04-29-2012, 10:29 PM Thread Starter
Hamid
Hamid's Avatar
2015 WK
Would anyone recommend a little over regular shocks front and rear for off road and hauling purposes.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
Leveled out the XJ :D Metro55 XJ/MJ Cherokee Non-Technical Forum 9 08-16-2011 05:12 PM
2000 XJ 130000 clicking between 1500 to 2000 rpm?? Wiggy XJ Cherokee Technical Forum 0 04-25-2011 11:57 PM
2000 I6 Cat QuickSlvr4x4 XJ Cherokee Technical Forum 4 07-07-2010 06:33 AM
Will a 2000 grand cherokee cd player work in a 2000 cherokee sport? soonernort XJ Cherokee Technical Forum 1 03-01-2007 12:00 PM
Leveled wipedawg XJ Cherokee Technical Forum 6 05-16-2005 11:51 PM
