My 1998 Cherokee Build "The Chief" - JeepForum.com
post #1 of 12 Old 04-05-2009, 06:25 PM Thread Starter
JeepNoma
Well I finally got around to starting the build. Its been an intense 72 hours in which I have not accomplished half of the things I wanted to.
I started off by accidentally rounding the bolts heads in the unibody for the upper control arms.
Later I found the rear suspension was torqued down WAY too much. Basically my dad was able to stand on a break bar for the rear leafs....he is 260+ pounds...
Now I found that the shocks 4 Wheel Parts told me would fit....don't....and I'm stranded 1000 miles from home in Chicago.
Lastly I found a bend in the unibody near the front passenger LCA as if someone drove over a speed bump and bottomed out...its scares me even though you couldn't tell it was there even if you wanted. Let me know what you guys think... (BELOW FIRST PIC)
BUT! anyways on with the build...!
STOCK:
Rubicon Express 4.5" Super Flex kit going on:
Bump Stop and Coil:
Coil and Shock:
Quik Disconnect and Coil and Shock (Rancho RS5000):
Rear leafs:
U-Bolts:
Broken Shock Bolts:
Done without rear shocks :
JeepNoma is offline
post #2 of 12 Old 04-05-2009, 07:10 PM
bennyblown2v
Looks great so far! Those rear shock bocks are a PITA haha... I just welded my BPE's to the trunk pan
bennyblown2v is offline
post #3 of 12 Old 04-05-2009, 07:15 PM
CT98XJ
be shure to take pics of the tc drop and report if you have any drive line viberations
CT98XJ is offline
post #4 of 12 Old 04-05-2009, 07:16 PM
ride172
where do you live at in CO???
ride172 is offline
post #5 of 12 Old 04-05-2009, 07:18 PM Thread Starter
JeepNoma
arvada.
lastly i will not be putting the t case drop in i dont need it. : )
JeepNoma is offline
post #6 of 12 Old 04-05-2009, 07:24 PM Thread Starter
JeepNoma
Slip Yoke Eliminator
its not completed yet but soon...tomorrow....
Does the chain seem ok? ^
Tom Woods Driveshaft tommorrow... : )
JeepNoma is offline
post #7 of 12 Old 04-06-2009, 03:24 AM
xGArfx
sweet build up jeepnoma you should of considered the hack n tap to help save a few bucks that could of gone elsewhere but overall like you rig buddy
xGArfx is offline
post #8 of 12 Old 04-06-2009, 08:35 AM Thread Starter
JeepNoma
how tight should the T case chain be?
JeepNoma is offline
post #9 of 12 Old 04-06-2009, 11:57 AM Thread Starter
JeepNoma
bump.................
JeepNoma is offline
post #10 of 12 Old 04-07-2009, 11:57 AM Thread Starter
JeepNoma
Well i finnally got shocks in and overall the lift yielded 5.5" of lift.
JeepNoma is offline
post #11 of 12 Old 04-07-2009, 08:03 PM
mattathayde
nice,
if your worried about that dent in the unibody just weld a reenforcement there or get some one to do it, it doesnt look very bad, honestly im having a hard time telling what is bent and how, i see a little bit but it almost looks like it was meant to be that way. a few inches of angle stock and you will be better than you were to start
-matt
mattathayde is offline
post #12 of 12 Old 04-08-2009, 11:26 AM Thread Starter
JeepNoma
well today was the first time i drove it since the lift. I started it and got tons of burnt oil smoke and got under it to find the driveshaft shot grease all over the exhaust. At first it was very loud running and felt very odd. After an hour of driving it on high way I have concluded there are no vibrations. The one thing i can say however when going 1-5 mph i do have this rumble noise/grind....any ideas? sounds like its coming from the front.
JeepNoma is offline
1998 Jeep Cherokee Brake "Thumping" JeepGuyTO XJ Cherokee Technical Forum 10 07-01-2012 04:32 PM
Build thread: "Black beater" 97 XJ 4.0l sahara XJ Cherokee Technical Forum 32 09-01-2011 03:41 AM
"Magic carpet ride" Build 92XJCowboy XJ Cherokee Technical Forum 54 09-07-2009 11:35 PM
Cherokee "Chief" vs. Cherokee... sroodtuo74 XJ Cherokee Technical Forum 3 10-03-2004 03:58 PM
