My 1995 $400 Expense - Page 5 - JeepForum.com
post #61 of 93 Old 04-17-2011, 03:22 PM
lk123
1993 XJ Cherokee
damn horse not looking both ways
4.0 I6ho Sport RC LA 6.5"
95 Lexus Sc300 coiled on 19's
94 ZJ 5.2 v8 Limited 3" rancho*sold*
93 2wd pos xj sport *sold*
89 nissan 240sx *wrecked*-03 Cbr954rr *traded*
2nd 89 nissan 240sx *sold*
lk123 is offline
post #62 of 93 Old 04-18-2011, 05:52 AM
jkylshark
whyd the horse cross the road?, trick question the horse stopped and its life was ended
Project Commander Kitty Cat...Aka Winston
http://www.jeepforum.com/forum/f22/winston-xj-build-1141903
jkylshark is offline
post #63 of 93 Old 04-18-2011, 06:15 AM
husker88jeep
1988 XJ Cherokee
whoaaa nellie!
husker88jeep is offline
post #64 of 93 Old 04-19-2011, 08:59 PM
tofuzeppelin
tofuzeppelin's Avatar
Sorry to hear man, depending on if it was owned by family or a club you may have a chunk of change coming to you. I'm in the same boat but hit a deer, next up grade is going to be a ABR Bumper for sure, wish you luck man
tofuzeppelin is offline
post #65 of 93 Old 04-20-2011, 10:21 PM Thread Starter
tsvallette
Its looking like its more than likely owned by an Amish family up the road. No one has came by to pick it up yet. Also I GOT THE JEEP HOME TODAY! I have been taking pics and did as much work as I could to assess the damage. Let the pictures tell the story.
As you may see there is little damage done to the engine, to the best of my abilities currently. Shes buttoned up for now, and low and behold one of my close friends knows of someone that getting rid of a 97 XJ for $600. Currently its in the shop getting repaired but 100% driveable. I am going to try my best to take a look at it tomorrow, and if at all possible buy it!
If its too plain then it can be made better ( Modify )!!!!!
95 Build/Rebuild
http://www.jeepforum.com/forum/f177/my-1995-400-expense-948376/
tsvallette is offline
post #66 of 93 Old 04-20-2011, 10:43 PM
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
doesn't look THAT bad. Pick up that one for $600, use parts off of yours and then keep the rest as spares and you're set.
koolaid5 is offline
post #67 of 93 Old 04-20-2011, 11:08 PM Thread Starter
tsvallette
If I can get it that's exactly what I will be doing!
95 Build/Rebuild
post #68 of 93 Old 04-21-2011, 08:06 PM Thread Starter
tsvallette
Fan is busted, how do I remove this?:
Front frame is buckled:
More damage to this one piece:
Powersteering pump is pully is bent:
Cracked cover I think:
And a pic form the rear toward the front. Looks worse than it truly is.
95 Build/Rebuild
post #69 of 93 Old 04-21-2011, 11:17 PM
husker88jeep
1988 XJ Cherokee
Looks like its a parts Jeep now.... any word on the owner of the horse? ..Owning a jeep is a labor of love, for sure.
post #70 of 93 Old 04-25-2011, 06:27 PM Thread Starter
tsvallette
Looks like a Heep now but you wont believe it, IT HAS LIFE!!! I called up a salvage yard and was talking to the owner, he will be making lots of money from me from now on! He said to cut the belt and try to start it. I was in disbelief due to the condition of the front end.... so I charged the battery and slapped it in there, first time START! Second time START! All I wanted to do was to hear it start, since the engine has no radiator. Now its time to take off the bad and do the nasty work... true and plumb... What should I do, could I do, or then again what can I get away with if I don't want to get all the front end body parts?
OK tranny works from Park to Neutral, the brakes work, and I can't see any reason why the there's anything wrong with the Drivetrain at all due to all of this. There are no oil leaks, or tranny leaks, and the engine sounds sound.... but there's lots of body work to be done. OH I'M SO JOYOUS!!!!!
95 Build/Rebuild
post #71 of 93 Old 04-25-2011, 06:35 PM
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
OUTSTANDING news. Congratulations.
koolaid5 is offline
post #72 of 93 Old 01-19-2012, 06:07 AM Thread Starter
tsvallette
Its been a long time but I finally started to buy parts for my Jeep. I seen on Craigslist a parts Jeep but he didn't keep it around. I managed to get 2 sets of hoods and front fenders, both brake light, radiators, alternator, starter, tentioner pulley with bracket, and both door mirrors. Once I get the radiators back in place I will be moving it back up to the house so that I commence more work... Time to call the Salvage yard to find out if we can work out a deal!
95 Build/Rebuild
post #73 of 93 Old 01-19-2012, 10:30 AM
theshaolin
That's incredible. I can't believe a horse did that much damage, you must've been booking pretty good...and I can't believe you kept it and it's coming back! Most people would have totalled a $400 Jeep at that point! Props for sticking with it, keep the updates coming!
1996 Cherokee Sport - 4x4 4.0L - Wheeling Project
1986 Mazda RX-7 Turbo - 400RWP project - 2000 Saturn SC1 - Turbo RWD project
1996 Suzuki Bandit 600 - Frame up restore project - Too Many Projects!!
1991 Chevrolet K1500 - 4x4 5.7L 5spd - For Sale (Cheap!)
theshaolin is offline
post #74 of 93 Old 01-19-2012, 05:26 PM
tofuzeppelin
Rough man, hope you can snag that 97 or you turn this one into a trail beast at least...
01 TJ with some stuff
77 SJ Cruzer
Lifes to short for bad coffee and bald tires
post #75 of 93 Old 01-19-2012, 05:49 PM Thread Starter
tsvallette
I looked at it like this, it runs check, it drives check, the ts works check, and it still stops check...... Looks are another thing but personally its work the experience of rebuilding it. For the past two days including today I have put $182 into parts which is a bonus so far; that's the above post and what I got today. Today I picked up a/c compressor mount, alternator plate, thermostat housing, battery tray, hood prop, and lots of hopeful wishing! After inspecting the powersteering pump it appears to be in working order, so no need to replace that. I may go back to get the a/c compressor.... $35 doesn't seam to be all that bad and looks very clean especially from a 91 model. To me it looks like it was replaced in the past couple of years but I just don't know if it works.
Tomorrow I will be going into town to pick up the thermostat housing gasket and a hose tool..... thingy (not sure what to call it but it releases springs that holds hoses to pipes.) When we get back, depending on weather, I will start the build.
95 Build/Rebuild
98 Tj 4.0 into 1995 XJ TwistedXJ XJ Cherokee Technical Forum 3 09-07-2009 11:40 AM
Air conditioning worth the expense? mcthnif XJ/MJ Cherokee Non-Technical Forum 5 08-17-2009 07:52 PM
1995 XJ restoration h.vandruten XJ Cherokee Technical Forum 2 01-11-2008 07:36 AM
1995 XJ Build Up rescuejeeper XJ Cherokee Technical Forum 4 10-14-2007 09:34 PM
1995 Fsm $65 ChadsXJ XJ Cherokee Technical Forum 3 02-15-2005 01:24 PM
