My 1995 $400 Expense - Page 4 - JeepForum.com
post #46 of 93 Old 03-13-2011, 07:57 PM Thread Starter
tsvallette
So I decided to rip into the Gauge Cluster wires and have a few hocked up. The blinkers don't work, there are no wire placement for the tec, speedo, fuel, temp, oil pressure, or even the voltage. The 98 appears to have a single line feed that carries this as a main signal through out and the 98 gauge cluster instrument panel holds the circuitry that decifers that signal.
So for this project i may need to rip out the 98 gauges, retrofit the 95 into the 98 housing, and make a new lighting system. Or try to backwards configure the electronics and hook into that part of the circuit board. Ive even thought about completely building a new housing for the Tec, Speedo, blinkers, and warning lights. Then place the temp, volt, heat, and oil gauges along the door/window plastic. I need to get this done as soon as I can.
If its too plain then it can be made better ( Modify )!!!!!
95 Build/Rebuild
http://www.jeepforum.com/forum/f177/my-1995-400-expense-948376/
tsvallette is offline
post #47 of 93 Old 03-13-2011, 11:09 PM Thread Starter
tsvallette
I am done for the night working on the 98 to 95 component gauge cluster instrument panel. It will have the most of the warning lights, Speedo, and Tec gauges. I did take a few pics while working on it but I will try to put them up tomorrow some time. I would like to get the warning lights installed but I dont have enough time to do before actually driving it. So for the most part I will only have the speedo and tec working. Hopefully I have the wiring done and hooked up tomorrow along with holes for the warning lights.
95 Build/Rebuild
post #48 of 93 Old 03-17-2011, 08:21 AM Thread Starter
tsvallette
Here are a few pics:
Current work space.
Test fit
True mileage reading.
Had to trim a little from the gauges.
Template
How it looks so far.
Could someone tell me what size tire I can fit on my stock suspension? I just got some much needed money for some tires.
95 Build/Rebuild
post #49 of 93 Old 03-17-2011, 10:57 AM
Aero
Current work space.
[IMG]http://img.Photobucket.com/albums/v200/tsvallette/1995%20jeep%20cherokee%20xj/IMAG0401.jpg[IMG]
Test fit
[IMG]http://img.Photobucket.com/albums/v200/tsvallette/1995%20jeep%20cherokee%20xj/IMAG0402.jpg[IMG]
[IMG]http://img.Photobucket.com/albums/v200/tsvallette/1995%20jeep%20cherokee%20xj/IMAG0406.jpg[IMG]
Template
[IMG]http://img.Photobucket.com/albums/v200/tsvallette/1995%20jeep%20cherokee%20xj/IMAG0407.jpg[IMG]
[IMG]http://img.Photobucket.com/albums/v200/tsvallette/1995%20jeep%20cherokee%20xj/IMAG0404.jpg[IMG]
[IMG]http://img.Photobucket.com/albums/v200/tsvallette/1995%20jeep%20cherokee%20xj/IMAG0409.jpg[IMG]
Could someone tell me what size tire I can fit on my stock suspension? I just got so money for some much needed tires.
Pictures no workie. :<
Aero is offline
post #50 of 93 Old 03-17-2011, 01:53 PM Thread Starter
tsvallette
Sorry I was in a bit of a hurry this morning when I got home from work and I wasn't near a computer. I picked up my cellphone and tried to post the links. Pictures have been edited and to make a long story short its been installed and working for the last 3 days, it just took me longer to add the pictures. As for the warning lights, I am still thinking of how to install them so that I can remove them for future final product.
At another note, I was doing some eBay research and seen some white gauge cluster skins but they are in Kpm and then secondary Mph. The listing list them for the Grand Cherokee.Is there any other ones that can work for the 95 Cherokee gauges
And current tires are p225 75r 15. Will the 235 75r 15 fit with little to no rubbing as long as the suspension doesn't flex so much?
95 Build/Rebuild
post #51 of 93 Old 03-19-2011, 06:07 PM Thread Starter
tsvallette
Today I purchased two 31 x 10.5 tires, have them balanced, one installed on the passenger side and bolted on... NO ISSUES!!! Now to the side... I noticed that the leaf is very flexed, I put the wheel on and lowered it.... the body actual rests on the tire. I go and check the first tire I installed and it has clearance all around and the leaf is in good flexing state. The other one is in need of replacement. I planned on giving it a s10 bastard lift but will this hinder my ability of using the original Jeep leaf spring?
95 Build/Rebuild
post #52 of 93 Old 03-20-2011, 12:59 PM Thread Starter
tsvallette
Here are a few pics of the driver side rear leaf spring:
Here is a pic of the 31 x 10.5 15 mounted on the other side. As you can see it fits perfect!
And for a laugh, here is are few pics of a toy Jeep that I cleaned up and repainted for an R/C vehicle of mine. Just wish it was this easy to make my 95 Cherokee look better!
95 Build/Rebuild
post #53 of 93 Old 03-20-2011, 03:10 PM Thread Starter
tsvallette
I just put on order for 2 gauge cages, one that is a single and another that holds 3. With some more slight modifications I will have all gauges installed and working! Thank you Amazon!
95 Build/Rebuild
post #54 of 93 Old 03-21-2011, 11:08 AM Thread Starter
tsvallette
Off to the salvage yard to get my 01 s10 leafs for $35 each! That's the cheapest all around here! I'm excited.... but now what else will I need? Also what springs will I need to get for the front? I want to pick up all of my parts today from the scrapyard, what year and vehicle do I need to get these from?
95 Build/Rebuild
post #55 of 93 Old 03-28-2011, 09:06 AM
xxxxxxxxxxxxxxxxxxxxxxxxWThorn
Guest
Let me help you out with that......
http://www.jeepforum.com/forum/f11/b...fit-xj-847303/
^Good source of information in there!
xxxxxxxxxxxxxxxxxxxxxxxxWThorn is offline
post #56 of 93 Old 03-28-2011, 11:04 AM Thread Starter
tsvallette
I found that page while I was in the AutoValue Parts Plus store getting my new Ubolts for the rear lift then I couldn't find the page after I closed my cellphone browser (HTC EVO : Sprint) Thank you for the link, I am so happy that you put this on my page. I am on the floor rolling with joy! THUMBS UP!!!!!!!!!!!!
Update: I have test fitted the new gauge cages that I got a few days ago and now I am modding the current gauges to fit in for now. A little black tape will hold them in until I get the funds to purchase my replacements. Im thinking of going all digital but then again my funds will all depend on what I will be getting! Here are a few pics of what I got:
New U bolts and Hood Pins
Work space for the time being:
What the start out when you pull them:
Wire cutters work great to trip the access. Heres what it looks like after you trim them:
What it looks like when you file them down:
What it looks like when you set it in place:
And best of all, heres the 31" on, lift in the rear, and hood pins installed:
95 Build/Rebuild
post #57 of 93 Old 04-15-2011, 09:58 AM Thread Starter
tsvallette
Well today I was on my way home from work, got out at 4am. I was about two miles away from home when I took my eyes off of the road for 2 seconds to look at the orange moon ( INTERESTING ) When I looked back at the road.............................................. ......I HIT A DAMN HORSE!!!!!!!!!!!!!!!!!!!! I will be getting pics later and soon will be getting Jeep home may take a couple of days. Not sure what to do but if its all possible I will be sueing the horse owners for the price to get my Jeep fixed or then again replace my Jeep!
95 Build/Rebuild
post #58 of 93 Old 04-16-2011, 11:56 AM Thread Starter
tsvallette
Whats left for parts on the road:
Here's where the my Jeep stopped:
Here's what my Jeep looks like now:
and
Finally here's the animal I hit on the road:
There could have been more damage done and I could have been killed. Thanks Goodyear for the great times that saved my life. RIP 95 XJ Jeep Cherokee until I get you back home to inspect the damage!
95 Build/Rebuild
post #59 of 93 Old 04-16-2011, 04:42 PM
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
aaawwwww..... poor horse
koolaid5 is offline
post #60 of 93 Old 04-17-2011, 12:06 PM
njg2982
Sucks about your XJ. Been there.
ditto
2000 Jeep Cherokee I6 4.0L - Stock for Now...
njg2982 is offline
98 Tj 4.0 into 1995 XJ TwistedXJ XJ Cherokee Technical Forum 3 09-07-2009 10:40 AM
Air conditioning worth the expense? mcthnif XJ/MJ Cherokee Non-Technical Forum 5 08-17-2009 06:52 PM
1995 XJ restoration h.vandruten XJ Cherokee Technical Forum 2 01-11-2008 06:36 AM
1995 XJ Build Up rescuejeeper XJ Cherokee Technical Forum 4 10-14-2007 08:34 PM
1995 Fsm $65 ChadsXJ XJ Cherokee Technical Forum 3 02-15-2005 12:24 PM
