My 1995 $400 Expense - Page 3 - JeepForum.com
post #31 of 93 Old 02-28-2011, 08:53 AM Thread Starter
tsvallette
Round 2: Oh BTW: I have been looking at http://www.mallcrawlin.com/forum//showthread.php?t=2781 I found this while doing some searching here on the forum. So far its been straight forward compared to e-Hows 4 line write up.
koolaid5: Thanks for the heads up, I will be doing this as well.
RoamFreely: It may be rough but it does run and drive very well, trans is in great condition and there is no knock. I haven't even replaced the beaten up tires. All in all this was an excellent buy in my opinion.
If its too plain then it can be made better ( Modify )!!!!!
95 Build/Rebuild
http://www.jeepforum.com/forum/f177/my-1995-400-expense-948376/
tsvallette is offline
post #32 of 93 Old 02-28-2011, 08:58 AM
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
oh.... my bad. That was just a how to for service. Sorry... I only looked for a min.
Keep us updated on your progress and we love pics, so keep them coming.
koolaid5 is offline
post #33 of 93 Old 02-28-2011, 04:50 PM
RedZeppelinXJ
Originally Posted by koolaid5 View Post
I still don't wear my safety glasses when I go under
that's a bad idea.....ask carol
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Briarwood - The Spruce Moose (Parting Out)
'79 J10 - Spartacus (Parting Out)
RedZeppelinXJ is offline
post #34 of 93 Old 02-28-2011, 06:34 PM
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
hahahaha... I know... I know
koolaid5 is offline
post #35 of 93 Old 02-28-2011, 07:01 PM
wlc78
1997 XJ Cherokee
sound like you got a good deal with your XJ...I know I have had mine for 10 years now
wlc78 is offline
post #36 of 93 Old 02-28-2011, 07:58 PM
tofuzeppelin
tofuzeppelin's Avatar
Glad you got the deal on the Cherokee man, hope it all turns out and glad to see another person from Michigan on here
01 TJ with some stuff
77 SJ Cruzer
Lifes to short for bad coffee and bald tires
tofuzeppelin is offline
post #37 of 93 Old 02-28-2011, 08:30 PM Thread Starter
tsvallette
Me too, would like to meet up! Well today I didn't do much of any work till I got back home around 3pm. I went out and looked at the bolts/nuts and decided to go once again back out and actually buy a 9/16" rattle wrench.. Sears was the only place that had them, separate, but I paid $20 for only one...ouch! Too bad I didn't have enough money and I would have bought a whole set from Walmart for $38, but anyways I am glade I did. I started to work on it around 8pm... kids are in bed... and now I am down to the last bolt/nut. I need to take off the crossmember to get access to the last bolt. I have jacks holding the transmission and the TC up. I take a few pics now since I am taking a break.
95 Build/Rebuild
post #38 of 93 Old 03-01-2011, 03:06 PM Thread Starter
tsvallette
After taking a few pics I cant seem to find my cable... Damn-it. But good news I have the old tc off and slid out from under the jeep, now time to finish taking off the front drive shaft and take somemore pics with a different camera, of course after I make a quick meal for the family. You will be shocked to see what the condition of the old TC is in, Im shocked that I was still driving on it!
95 Build/Rebuild
post #39 of 93 Old 03-01-2011, 05:55 PM Thread Starter
tsvallette
Well dinner is done, kids are in bed and time to get back to work. Here are a few pics of it and also some of the 98 interior that I installed about 6 or so months back: As you may see I have a lot more work to go!
Replacement TC and old TC:
Upper and side holes in old TC:
Bottom hole in old TC:
Crossmember:
Where the TC is from:
Dashboard:
Passanger side door:
Rear Seat:
Rear door:
95 Build/Rebuild
post #40 of 93 Old 03-01-2011, 06:40 PM Thread Starter
tsvallette
Ok another hicup, I need to get a 5/16" wrench so that I can remove the front drive shaft off of the old TC. I am trying a modified 5/16" socket and a pair of channel locks as well as visegrips and cant seem to break them free. It looks like another trip to see if I can buy another wrench!
95 Build/Rebuild
post #41 of 93 Old 03-01-2011, 08:05 PM Thread Starter
tsvallette
My first try to modify the 5/16" socket came from a screwdriver bit set, I then hacked off about 1/4" from the part that you insert into the drill, and that was it. Thats when I called it quits and decided that I needed to buy one, well then I went back to the drawing board and did somemore modifying. I ended up cutting 1/8" off each side of the shaft, this is what I ended up with:
To my surprise I got one loose and out! Yessss it worked, so I thought. I went on to the second bolt... Damn it broke! So once again back to the drawing board. I ended up with this:
YESSSSSS all are out and now I have the driveshaft on the replacement TC and bolted up! Onward I shall go!
95 Build/Rebuild
post #42 of 93 Old 03-01-2011, 10:46 PM Thread Starter
tsvallette
Ok break time and I have the replacement TC up and in place, I have 5 bolts/nuts on and somewhat tight, the 6th is half way in, then my light blew... good time to take a break. I will have the replacement installed tonight still and a test drive soon after. Gosh.... I can't wait to get this done!
95 Build/Rebuild
post #43 of 93 Old 03-02-2011, 12:59 AM Thread Starter
tsvallette
It's finished!!!!!!! I took it out for a test drive and everything functions like it should and tomorrow will be the test of my 4wd for the 1st time! Oh the joy!!! Next big project is to tackle the rear brakes... dun dun dun.
95 Build/Rebuild
post #44 of 93 Old 03-07-2011, 05:10 PM Thread Starter
tsvallette
A few days ago I modified the heating tube that runs under the center console that delivers heat to the rear seat. There's a slight difference in length and how it attaches to the heater blower unit, this is what I had done.
Yesterday, I started to work on the 98 AC/Heater Control, I have all of the vacuum lines figured out and attached, but having a little difficulty doing this. All of the lines are attached and it switches with out any problems. By the end of the night I was working on the electrical switch (fan speed) and blew 2 fuses. So that was the end of it and called it a night. When I came back in, I did some more research and figured out my problem but I was too tired and night. So now I am working on attaching the cable that controls the temp, but I need to get this part:
Where can I get this part, what is it called just the part? The 98 one that I have had a pot attached that controlled the temp but I need this manual one. This image came from a 97XJ pdj pg 712, any ideas?
Edit: I got my answer its part number 55037426AA I found it on eBay Now to dig for that separate part, tomorrow the salvage yard will be visited!
95 Build/Rebuild
post #45 of 93 Old 03-07-2011, 07:14 PM
crockett07
1992 XJ Cherokee
OMG THAT TCASE IS JACKED!!! good luck with the rest of it
crockett07 is offline
98 Tj 4.0 into 1995 XJ TwistedXJ XJ Cherokee Technical Forum 3 09-07-2009 10:40 AM
Air conditioning worth the expense? mcthnif XJ/MJ Cherokee Non-Technical Forum 5 08-17-2009 06:52 PM
1995 XJ restoration h.vandruten XJ Cherokee Technical Forum 2 01-11-2008 06:36 AM
1995 XJ Build Up rescuejeeper XJ Cherokee Technical Forum 4 10-14-2007 08:34 PM
1995 Fsm $65 ChadsXJ XJ Cherokee Technical Forum 3 02-15-2005 12:24 PM
