04-30-2012, 07:44 PM
#811
i would find an 8.8 with 4.10's and limited slip and just gear the front and lock it. or just an 8.8 with 4.10's and do the super88 kit.
the 8.8 is stronger... but if you wanna go deeper with gears it might just be easier to do the 8.25. they are both c-clip so i'd go with the 8.8
Jacob - open axle king
March 2012 COTM
04-30-2012, 08:09 PM
#812
Not a Real Jeep
8.8 is much stronger and has a much larger aftermarket than the 8.25.
Only downside is that it is narrower.
92xj....Linked, Locked, Caged, Armored...
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
04-30-2012, 08:10 PM
#813
9''
Originally Posted by chris87xj
(in my best accent and with hands folded)
"Ah Grasshopper, we drink of the cherokee life fluids to become one with our soul brothern."
Originally Posted by AustinTJer
Have you ever seen and or filmed a rainbow? More specifically a double, possibly triple rainbow?
04-30-2012, 08:13 PM
#814
DYNATRAC 60's FRONT AND REAR NOW DO IT
March 2012 COTM
04-30-2012, 08:52 PM
#815
Is he going to build it up? Or going up in sizes on tires?
The 8.25 should hold up fine stock for what he's got. I think "much stronger" is an overstatement. The aftermarket is no contest in favor of the 8.8, though. Still meh
Patriot Blue XJ 4x4
RE 4.5" | 305/70/16 MTR K
My Build Thread
04-30-2012, 09:20 PM
#816
Originally Posted by alexrule123
Well the 8.25 is an easier swap and it's cheaper then the 8.8
8.8 isnt a difficult/expensize swap at all. Plus youll have the added security of having a beefier rear axle. 31 vs 29 spline, 3.25 tubes vs 3, 8.8 inch ring gear vs 8.25, etc.
8.8 can always be built to handle 37s no problem, while the 8.25 doesnt have that option. The aftermarket for the 8.8 is HUGE, the aftermarket for the 8.25, not so much. Just my 2c though.
2012 Cherokee of the Year
04-30-2012, 09:53 PM
#817
My issue with the 8.8 vs 8.25 is that you don't see many 8.25 spin tubes. 8.8's do it constantly even when they are welded.
We use the 8.8's in jeep speeds alot, and it happens. I'd stick with the 29spline 8.25, honestly people have beaten the sh*t out of them on 35's without issues!
Now decide if you want anything deeper than 4.56 gear's. If you do then forget the c8.25 as it only goes to 4.56.
And axle shaft strength wise..theres a chart online somewhere, but 8.25 is with 50 ftlbs force to a 30spline D44 shaft, the 8.8 wasn't listed, but no it is not that much stronger at all.
04-30-2012, 09:56 PM
#818
I will eventually going up to 35x12.50s and locked. (That's the plan anyways)
I am leaning towards the 8.8 and I am planning on pricing one at the junkyard this weekend.
1999 Cherokee Classic: R.I.P. http://www.cardomain.com/ride/2313036
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, IRO 5.5" Leaf Springs, Liquid Iron Industries Slider Boxes, 35x12.50 Goodyear MTR/K, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, WJ Brakes and steering, JCR Rock Sliders, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler
04-30-2012, 10:03 PM
#819
That's good to know, I plan on getting the tubes welded anyways (hopefully the axle tubes don't spin)
04-30-2012, 10:05 PM
#820
you can go 4.88 in the 8.25
Patriot Blue XJ 4x4
My Build Thread
04-30-2012, 10:56 PM
#821
First time I've heard that, I always thought 4.56 was as deep as it went.
As for the 8.8 issue. Alot of people take a simple piece of 1.5 or 1 3/4" medium walled, and throw a simple truss on it..Cost virtually nothing.
05-01-2012, 05:16 AM
#822
Not a Real Jeep
Check out the warn break test that was done a few years back. The 8.8 shaft was off the charts and well past the d44 break strength . The8.8 lasted farther than the machine could measure.
Where is this chart you are refering to?
That little 1.18 8.25 shaft is nothing compared to the 1.30 8.8 shaft. Thr carrier is bigger, housing thicker, ring gear larger, pinion and bearings larger, pinion shaft flange stronger and more desirable.
And if people are spinning tubes on a welded 8.8. Then they need to go back and learn how to weld to cast.
05-01-2012, 02:17 PM
#823
Thought I was going to snag a set of rubi rims off Craigslist for $300 but when I called them 13 min after posting they told me they sold them a few weeks ago...
05-01-2012, 02:38 PM
#824
They make them now.
http://www.jeepinoutfitters.com/scri...idproduct=2334
http://eastcoastgearsupply.com/i-160...nion-4-88.html
How random. Keep looking, I see a set pop up every now and then across the panhandle
Patriot Blue XJ 4x4
My Build Thread
05-01-2012, 06:13 PM
#825
If an 8.8 spins an axle tube and its welded......it wasnt welded correctly. that is a mute point because its almost free to weld the tubes up.
The 8.8 with 31 spline shafts has a 6,500 lb. ft, dana 44s are from 4,600-5,000 lb. ft. Thats quite the strength increase if you ask me
