My '01 Build Thread - Page 11 - JeepForum.com
post #151 of 1718 Old 04-28-2011, 06:06 PM
Wearingthin
Originally Posted by alexrule123
I got the tie rod installed today.
Looks good, does it use the stock ends?
Patriot Blue XJ 4x4
RE 4.5" | 305/70/16 MTR K
Wearingthin is offline
post #152 of 1718 Old 04-28-2011, 06:45 PM Thread Starter
alexrule123
alexrule123's Avatar
Yes, it uses the factory tie rod ends.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #153 of 1718 Old 05-01-2011, 06:51 PM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
sweet, now lets go run it into **** and do a durability test
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #154 of 1718 Old 05-01-2011, 07:41 PM
Cherokee-at-16
Go wheeling, good idea. Run into *****...Bad idea, don't forget you still have stock rod ends.
And I read earlier that you went and got a v8 Zj drag link, and I just have to ask why, because I read they were the same for the zj's and xj's for any package. The difference is only that the v8 Zj tie-rod is thicker/solid and has a bigger rod end.
2000 Cherokee Sport Build: http://www.jeepforum.com/forum/f22/2000-xj-build-slow-uneventful-1162913/
Cherokee-at-16 is offline
post #155 of 1718 Old 05-01-2011, 08:27 PM Thread Starter
alexrule123
I didn't go with it, I couldn't find on in the jy today. I have been told the zj drag link is thicker than the xj one.
post #156 of 1718 Old 05-08-2011, 11:23 PM
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
you doin Jeep Beach this year?
2013 COTY
post #157 of 1718 Old 05-09-2011, 08:39 PM Thread Starter
alexrule123
I finally got the front driveshaft back on...took 5 hours to get the exhaust mostly out of the way. It still hits the driveshaft when flexed but I am ok with that.
When you going down to jeep beach?
post #158 of 1718 Old 05-09-2011, 09:03 PM
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
Ill be driving down saturday morning.
you can register your jeep there if you want to go on the courses, or you could just pay $5 to get in as a spectator
2013 COTY
post #159 of 1718 Old 05-09-2011, 09:47 PM
dave95_xj
1995 XJ Cherokee
Ok bro im sorry to ask a stupid question but man i have to it will save me a ****load of money. When i put a new radiator cap on, my radiator sprung a major leak. So i got an all metal radiator and installed it with the help this acquaintance that is a mechanic... He had me fill it with hose water and coolant. I asked if i should put in some distilled water or something he was like nah ur good... now(4months later) my fluid looks all dirty... what should i do?
dave95_xj is offline
post #160 of 1718 Old 05-09-2011, 10:20 PM Thread Starter
alexrule123
You need to flush the whole coolant system out and then put in the proper mix of antifreeze and water.
post #161 of 1718 Old 05-10-2011, 12:18 AM
-Rudy-
It's not necessarily dirty because of hose water. Usually, you will pic up crud that's built up in the engine block for a bit until you flush it and drive it a few times.
04 WJ Limited 4.7/QD: 245/70R17 Firestone A/T + Trimming
-Rudy- is offline
post #162 of 1718 Old 05-16-2011, 02:56 PM Thread Starter
alexrule123
Did a little wheeling last night and freaking bent the IRO double sheer track bar at the TRE. This is the same trail I have done easily a dozen times before so I don't know how it bent I guess I need to take it easier on the way to the grocery store next time.
post #163 of 1718 Old 05-16-2011, 03:53 PM
lk123
1993 XJ Cherokee
Holy .... That is worse than I expected lol
4.0 I6ho Sport RC LA 6.5"
95 Lexus Sc300 coiled on 19's
94 ZJ 5.2 v8 Limited 3" rancho*sold*
93 2wd pos xj sport *sold*
89 nissan 240sx *wrecked*-03 Cbr954rr *traded*
2nd 89 nissan 240sx *sold*
lk123 is offline
post #164 of 1718 Old 05-16-2011, 04:45 PM Thread Starter
alexrule123
Update: I emailed Iron Rock and they are sending me a new end. Awesome customer service!
post #165 of 1718 Old 05-16-2011, 04:46 PM Thread Starter
alexrule123
I knew something was wrong when my steering wheel was 90 degrees off
My 98 build thread......... come on in! CHAMPTEK XJ Cherokee Technical Forum 20 01-24-2012 01:45 PM
My build thread. My attempt on a SAFE build on a budget. xyimmyx XJ Cherokee Technical Forum 46 06-09-2011 02:50 PM
My little build thread Big4banger XJ Cherokee Technical Forum 5 09-16-2009 08:38 PM
My XJ Build Thread aero3685 XJ/MJ Cherokee Non-Technical Forum 14 03-13-2009 08:22 AM
Build thread, am I doing this right? Grinola XJ Cherokee Technical Forum 16 09-19-2008 12:53 PM
