My '01 Build Thread - Page 102 - JeepForum.com
post #1516 of 1718 Old 05-29-2013, 10:24 AM Thread Starter
alexrule123
alexrule123's Avatar
Originally Posted by DNFJ
Not what my point was.
18MPG is pushing it for even a stock XJ.
Not it isn't I got over 20 when my blue one was stock.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #1517 of 1718 Old 05-29-2013, 10:24 AM Thread Starter
alexrule123
Originally Posted by SFRautomotive
Engine sits in more efficient part of powerband
And skinnier tires have less wind resistance on them.
post #1518 of 1718 Old 05-29-2013, 10:28 AM
Luke95
GPS verified at the same pump I'm pushing 17 on 33s.
Sent from go home iPhone your drunk.
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #1519 of 1718 Old 05-29-2013, 11:07 AM
DNFJ
Stock gears or?
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #1520 of 1718 Old 05-29-2013, 11:54 AM
Luke95
Stock gears or?
Stock gears
Luke95 is offline
post #1521 of 1718 Old 05-29-2013, 11:59 AM
DNFJ
Maybe I skinny pedal too much.
Previous:
DNFJ is offline
post #1522 of 1718 Old 05-30-2013, 07:22 AM
fedx95
1993 XJ Cherokee
With 32s and 3.55s I was doing 21 mpg highway. 5 speed FTW
fedx95 is offline
post #1523 of 1718 Old 05-30-2013, 07:28 AM
DNFJ
**** you and your 5 speed
Previous:
DNFJ is offline
post #1524 of 1718 Old 06-03-2013, 08:33 AM
Spokes
correct me if im missing something for the WJ swap...
WJ balljoints
JKS hub spacers
WJ rotors,pads,calipers
WJ knuckles
That should be it right? and than just need to redrill rotors to 5x4.5. no other spacers or anything is needed correct?
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #1525 of 1718 Old 06-03-2013, 02:03 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
WJ balljoints
JKS hub spacers
WJ knuckles
Yes that is all. Steering will need to be addressed. And eventually the trackbar/draglink angles
1990JEEPXJ is offline
post #1526 of 1718 Old 06-03-2013, 02:11 PM Thread Starter
alexrule123
Don't forget 2000+ hub bearings if you don't want to run caliper spacers.
post #1527 of 1718 Old 06-03-2013, 02:23 PM
YoureverydayXJ
If you use the hub spacers, and the 2007 Explorer Sport Trac rotors you don't have to drill them or space the caliper right?
'00 XJ not quite there..
'00 XJ parts donor, '98 XJ body donor
YoureverydayXJ is offline
post #1528 of 1718 Old 06-03-2013, 03:44 PM Thread Starter
alexrule123
You have to enlarge the inner part of the rotor to fit over the hub if you run the sport trac rotors and you need caliper spacers. No matter which hub you use you need to run the hub spacer to make the ujoint line up properly.
post #1529 of 1718 Old 06-03-2013, 03:50 PM
YoureverydayXJ
But with the WJ rotors you don't?
post #1530 of 1718 Old 06-03-2013, 03:55 PM Thread Starter
alexrule123
Nope.
My 98 build thread......... come on in! CHAMPTEK XJ Cherokee Technical Forum 20 01-24-2012 12:45 PM
My little build thread Big4banger XJ Cherokee Technical Forum 5 09-16-2009 07:38 PM
My XJ Build Thread aero3685 XJ/MJ Cherokee Non-Technical Forum 14 03-13-2009 07:22 AM
Build thread, am I doing this right? Grinola XJ Cherokee Technical Forum 16 09-19-2008 11:53 AM
