ModStock's XJ 99 Sport - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > ModStock's XJ 99 Sport
The RuffStuff "I can't go to EJS" Sale!Offset Tie Rod Kit From RuffStuff!Check out our NEW Steering Stuff!
Unread 03-02-2013, 05:33 PM   #46
Modstock
Oh thanks. I'll try that out.
I do have some extensions that I never used for my YJ I can use.
Last night I put the 3/4" spacers on. Sits more level now.
Modstock is offline   Reply With Quote
Unread 03-02-2013, 06:52 PM   #47
S8NNG8
1995 XJ Cherokee
With that brakeline on the front, it seemed to me like there was too much slack and the brakeline may get snagged or tangled. I zip tied the brakeline to the shock working from the bottom up.
D3<!L!>3D
S8NNG8 is offline   Reply With Quote
Unread 03-03-2013, 10:51 PM   #48
Modstock
lift test
So after driving around for a week , I have some issues that need to be dealt with .
1.) Have some minor vibrations in the driveline from 45-65mph (accel and decel ) . I may replace both u-joints in the DL cause they look original but have no slop in them . Or put a 2* shim in the rear.
Do any of you have DL vibes with a 3" lift ???
2.) Due to the 3.75 back spacing I have, the tires rub a bit while turning after adding the spacer its not as bad but I may have to trim the back lower edge of the flare and have already trimed the front a bit.
3.) The disconntects look way too long and that puts the swaybar at a wierd angle (which is not good for handling) . I know the swaybar angle is just above level with the ground from the pic I took.
So . should I cut em' down and weld or do they offer shorter disco's.
4.) Ive gotta bumpstop this thing. Coming form a YJ, this XJ has mad flex.
Unread 03-04-2013, 09:49 PM   #49
Modstock
Linked up and no rubbin.
Disconnects are on. I flipped the bracket that bolts onto the swaybar itself and measured/compared to the stock link. It was a tad over 3 inches . I was able to bolt em' on and drive today. Corners way better. Nice and flat, no lean.
I still have to get those lower bolts out . May try the air-hammer tomorrow.
Unread 03-06-2013, 10:49 PM   #50
Modstock
Finally got the lower bolts out today and bolted on the lower pins. I'll install the retainers at work.
This weekend Im gonna start on the rear-end swap so I can set a date to get the front gears changed out.
Unread 03-09-2013, 10:49 PM   #51
Modstock
Update pics w/ Flex
Swaybar links worked by flipping the upper bracket.
Measured up .It made the swaybar alittle higher maybe an inch or two but no Ill handling effects .
Gonna have to bumpstop sometime soon.
Made sure the brakeline was OK.
Flexxxxxxx.
Unread 03-16-2013, 05:58 PM   #52
Modstock
Rear axle swap
Started on the rear axle swap today. Should have my OX axle from my YJ out here in a hour. Luckily it looks like the cable should go up to my console.
Unread 03-16-2013, 10:25 PM   #53
MOBBiN
What's that giant thing in the bag on your front bumper?
1997 Moss Green Pearlcoat XJ
2001 Silverstone Metallic Limited XJ
2006 World Rally Blue STi
MOBBiN is offline   Reply With Quote
Unread 03-17-2013, 08:05 AM   #54
VegasGT
Bolt Snapper
VegasGT's Avatar
You ever considered getting the chrome headlight bezels to match the grille? I think that would complete the look nicely.
Otherwise looking good man!
- '99 XJ -
Lifted, Locked, Stiffened
4.5"/35's
July 2013 COTM
VegasGT is online now   Reply With Quote
Unread 03-19-2013, 08:41 PM   #55
Modstock
rear axle swap
Its a fold up tow bar. When I build a bumper that'll come off.
Thanks. I do have those chrome visors .
This weeknd I cut off mounts on axles so I can put my OX axle in but ran outta time during the weekend.
Monday after work (5pm) I began the actual swap and finshed up at 4:30 this morning. Slept about 2-1/2 hrs and went to work. Im tired, I'll post pics tomorrow.
Unread 03-23-2013, 10:52 PM   #56
Modstock
rear axle continued.......
So a few days after my OX axle swap the XJ was taken to a shop to get the front gears done and the rear driveline lengthened (cause the new rear axle the pinion to axle distance was shorter).
Picked it up friday night and most of the DL vibes are gone but still have some at 30-40mph so I may add a 1/2 spacer to the t-case mount and see if that helps.
Somehow the rear axle swap lifted the rear about 1/2" or more . IDK maybe the rear hasent settled yet from being on the hoist .
Tested the 4wd today and works great but havent hooked up the OX cable yet. That'll be tomorrow or during the week.
Unread 03-25-2013, 12:18 AM   #57
Modstock
Rear swap pics :
Sorry YJ , im stealing your rearend .
Wierd the brakes were smaller on the 8.25 .
Going under .
All done .
Unread 03-25-2013, 10:43 PM   #58
Modstock
Damn RF fender flare came loose today . Must of been when I flexxed out for that pic .
Started thinking about switching back to the stock wheels so im not tearing up the body.
Unread 03-25-2013, 10:46 PM   #59
S8NNG8
1995 XJ Cherokee
Did you get a chance to run around on the OX yet?
D3<!L!>3D
Unread 03-25-2013, 11:06 PM   #60
Modstock
Havent hooked up the lil shifter for it. Sometime this week. Been driving it to work though.
Gotta put some longer bumpstops before our moab trip this year.
