ModStock's XJ 99 Sport - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > ModStock's XJ 99 Sport
Offset Tie Rod Kit From RuffStuff!The Original 3/8" Ruffstuff Diff Cover!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-12-2013, 10:39 PM   #16
Modstock
Not sure on the weight. Im sure its a bit more than most since its custom built.
I did some work on it today . Welded the legs on to mount it to my bars but then ran outta gas for the welder. Started sawzall-ing the spacers between the hoops and broke my last blade so I called it a day.
I have a few thoughts about the paint . Tell me whatcha think ?
1.) Black (flat or shiney) standard rack color. OR.....
2.) Metallic green (like the jeep color)
3.) Dark drab (army green)
Took some before pics too.
Modstock is offline   Reply With Quote
Unread 01-13-2013, 09:48 AM   #17
S8NNG8
1995 XJ Cherokee
The army green could be a cool looking combination with the rig being green, creative and unique
D3<!L!>3D
S8NNG8 is offline   Reply With Quote
Unread 01-14-2013, 06:59 PM   #18
Modstock
Im leaning in that direction.
Ive always wanted to paint somethin army green.
Unread 01-31-2013, 10:16 PM   #19
Modstock
So I just had my taxes done and now can look at lifts . Im thinking of going with the RC 4.5 X series because it has all the extras I'd end up getting anyway Brake lines, Adj Track bar, ect . Any pro's or cons to this lift ???
Unread 01-31-2013, 10:44 PM   #20
S8NNG8
1995 XJ Cherokee
At 4.5", you need to make arrangements for a Slip Yolk Eliminator...and a new driveline.
D3<!L!>3D
Unread 02-01-2013, 06:41 AM   #21
VegasGT
Bolt Snapper
VegasGT's Avatar
You can get by with a t-case drop but Id definately look into an SYE. I had 4.5" X-Flex on my old '99 and ran t-case drop. Worked fine but was certainly not ideal.
- '99 XJ -
Lifted, Locked, Stiffened
4.5"/35's
July 2013 COTM
VegasGT is offline   Reply With Quote
Unread 02-01-2013, 10:57 PM   #22
Modstock
Are these gonna rub ???
So I am re-thinking this 4.5" lift and maybe going 3" cause I forgot I need the front axle regeared when I throw the other rear in. Wich makes my lift fund a bit smaller .
Here's my prob. I have a set of 15x8 softies with 3-3/4 backspacing, 31x10.5
BFG-AT's mounted .
Are these gonna rub if I go the 3" lift ???
Unread 02-01-2013, 11:59 PM   #23
S8NNG8
1995 XJ Cherokee
I run 31's, 3" front, 4.5" rear (heavy speaker box). She sits level. I catch an edge on my flares from time to time, but nothing that's ever gonna do any damage
D3<!L!>3D
Unread 02-03-2013, 10:34 PM   #24
Modstock
Lookin expo
Put the rack on yesterday. Also mounted the lights.
pics this week.
Unread 02-08-2013, 10:58 PM   #25
Modstock
Rack w/ lights
Here's the rack how I got it . It was 8.5" tall so it needed to be cut down badly and it was a bit rusty . My crossbars next to it so i can mok up some mounts.
Some 2" spacers for the hoops and 1.5" angle cut to 2" wide for mounts and some mounts I cut in 2 for lights.
All mounted up and painted army green. 7 light mounts (3-front , 1 each side, and 2 facing the rear for those pesky tailgaters) . Also mounted my fogs up front.
Lookin a bit more Expo .
I had some headlight visors hangin around and put those on. Not sure if they'll stay. Hhmm maybe I'll paint em' army green.
Unread 02-09-2013, 01:25 PM   #26
S8NNG8
1995 XJ Cherokee
So now that the alterations are done, what would you guess it weighs?
D3<!L!>3D
Unread 02-09-2013, 08:43 PM   #27
Modstock
I think its at least around 60lbs + - . It was built for a photographer to stand on so it has thick tubing . In the future I may cut out the bottom and redo it to make it lighter, plus it has the mesh metal welded on. . Measurements are 62"length x 49"w.
Unread 02-09-2013, 11:02 PM   #28
Modstock
I had a headlight go out a few days ago and today I picked up a new set of Sylvania Silverstars . These are wayyyy better than my old lights.
Gonna be ordering my lift monday. Then I'll swap out the rear axle and have the front re-geared to 4:10 also .
Unread 02-10-2013, 10:38 AM   #29
S8NNG8
1995 XJ Cherokee
I've kinda got Karma working for me... I've wanted to get a pair of those Silverstars, but in 4 years I haven't needed a headlight replaced yet.
D3<!L!>3D
Unread 02-16-2013, 10:24 PM   #30
Modstock
Lift and disconnects should be in by tomorrow.
I'll spend the week spraying PB blaster on everything .
