MOBBiNs 01 xj build - Page 9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > MOBBiNs 01 xj build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBilstein Shock Upgrade Kits, Jeep JK TJ XJ Wranglers and CJeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 12-17-2012, 09:09 PM   #121
MOBBiN
MOBBiN's Avatar
It was cold today
Brrrrrr
So I started redoing my hood vents
Color matched outter ring and new hardware
2001 Silverstone Metallic Classic/Limited XJ
April 2014 COTM
MOBBiN is offline   Reply With Quote Quick reply to this message
Unread 12-19-2012, 08:37 PM   #122
MOBBiN
MOBBiN's Avatar
Notched the Rubicon Express cross member
No more exhaust or t-case rubbing
I never did put up pictures of the long arms
It's been about 200 miles on the new kit so I went threw and was checking to make sure all the bolts and nuts were still tight
I found 2 (driverside and passengers side same bolt) loose bolts
When I loosen it the bolt it backs out, when I tighten it gets snug then just spins. What should I do about that?
**EDIT** fixed the bolt issue... Turns out that the old bolts were a little rusty so I replaced them. The new bolts snugged up and stayed tight.
April 2014 COTM
Unread 12-20-2012, 06:11 PM   #123
MOBBiN
MOBBiN's Avatar
Rustys steering box brace
It fit horribly not 1 hole lined up.
Then I was bored so I relocated my vacuum ball
April 2014 COTM
Unread 12-20-2012, 06:44 PM   #124
Texsun
Herro fellow subi owner
Texsun is offline   Reply With Quote Quick reply to this message
Unread 12-20-2012, 07:15 PM   #125
MOBBiN
MOBBiN's Avatar
I wish mine was silver
April 2014 COTM
Unread 12-20-2012, 07:23 PM   #126
Texsun
A little less attention! However mine is un godly loud...
Unread 12-20-2012, 07:29 PM   #127
MOBBiN
MOBBiN's Avatar
What exhaust do you have? I thought you sold yours for some reason?
April 2014 COTM
Unread 12-20-2012, 07:46 PM   #128
Texsun
I had it up for sale on here, but nothing but low ballets/tire kickers. I have a Perrin 3" exhaust that turns down behind rear axle.
Unread 12-20-2012, 07:50 PM   #129
Texsun
Btw, your jeep is looking great!
Unread 12-20-2012, 08:03 PM   #130
MOBBiN
MOBBiN's Avatar
I had a Perrin on my old wagon. I have a Cobb TBE now I've been thinkin about get the stupid loud Invidia N1 exhaust
April 2014 COTM
Unread 12-20-2012, 08:05 PM   #131
MOBBiN
MOBBiN's Avatar
Thanks. It has a long ways to go.
Good luck with Cherokee of the year
April 2014 COTM
Unread 12-21-2012, 04:42 PM   #132
MOBBiN
MOBBiN's Avatar
I dropped my jeep off at the local jeep dealership this morning because of a small leak, that turned out to be the rear main seal, and a drowning noise in 4wd and that turned out to be my front drive shaft. :-/ let's hope my warranty covers that rear main deal! My only worry is that they won't because it's a gasket.
April 2014 COTM
Unread 12-21-2012, 05:59 PM   #133
Texsun
You still have a warranty on it? Or did you get a crate motor?
Unread 12-21-2012, 06:23 PM   #134
MOBBiN
MOBBiN's Avatar
I bought my jeep Feb 2011 with a 2 year/24k mile warranty from a stealership
I have 2.5 months left or 3k left on my warranty
I lost compression in my motor summer of 2011 and got it warrantied with a lower mileage motor (New motor had 69k on it and mine had 98k)
April 2014 COTM
Unread 12-29-2012, 08:47 AM   #135
MOBBiN
MOBBiN's Avatar
I recieved a phone call from Lithia Jeep yesterday. They brought in a 3rd party inspector to look at my jeep. The warranty company is going cover the rear main seal, head gasket and vavle cover gasket. Best part is that i only have a 50$ deductible
April 2014 COTM
