MOBBiNs 01 xj build - Page 13 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > MOBBiNs 01 xj build
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-08-2013, 12:04 AM   #181
MOBBiN
MOBBiN's Avatar
A fellow Alaskan! Rare around these parts
2001 Silverstone Metallic Classic/Limited XJ
April 2014 COTM
MOBBiN is offline   Reply With Quote Quick reply to this message
Unread 04-08-2013, 02:39 AM   #182
bl44st
I drive the only white mr2 spyder in alaska. one of these days i will get a jeep and finally get to explore the awesome land we have.
bl44st is offline   Reply With Quote Quick reply to this message
Unread 04-08-2013, 10:59 AM   #183
MOBBiN
MOBBiN's Avatar
Get on it! Also check out Alaska4x4network.com
April 2014 COTM
Unread 04-08-2013, 01:05 PM   #184
lobeyxj
1995 XJ Cherokee
hey man, your jeep is awesome! i read your whole build thread, i like the way its coming together! im curious, at what store did you buy the stuff for your sway bar disconnects? i have the brackets, just not sure where i can find heim joints... again, kudos on your great jeep! someday if i make it to alaska we will have to go wheeling!
lobeyxj is offline   Reply With Quote Quick reply to this message
Unread 04-08-2013, 02:26 PM   #185
MOBBiN
MOBBiN's Avatar
Thanks for the complement, I bought the rod ends/Heim joints at a local bearing store called Alaska bearing. The threaded rod I got from my local hardware store
April 2014 COTM
Unread 04-10-2013, 07:52 PM   #186
MOBBiN
MOBBiN's Avatar
Originally Posted by MOBBiN View Post
Gotcha. I've read about that from EricsXJ. Just not a lot of details on how to hook it up. It's nothing I can't figure out.
I found a windshield wiper resivor at my local junkyard wading through fresh knee high powder. Dedication.
I'm in the process of pulling wires and swapping pumps from the 97-01 into the 96
Ill update more when I have more progress
April 2014 COTM
Unread 04-10-2013, 08:29 PM   #187
MOBBiN
MOBBiN's Avatar
Pumps pulled, showing the top hold that needs expanding
the size of the 01 pumps
2001 pumps in the 96 resivor
April 2014 COTM
Unread 04-11-2013, 06:15 AM   #188
DNFJ
DNFJ's Avatar
Continue....
Just Another Yellow TJ
Built Not Bought #704
Previous:
'00 XJ 6.5 on 35" KM2s
'96 ZJ 2 on 31" Baja Claws
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 04-11-2013, 10:23 PM   #189
MOBBiN
MOBBiN's Avatar
Pulled all the wires up to the new location of the windshield wiper resivor
Retucked all the wires
April 2014 COTM
Unread 04-13-2013, 01:29 PM   #190
MOBBiN
MOBBiN's Avatar
Started on this bad boy 2 days ago:
Winch plate mounted, winch mounted and fairlead mounted
Bottom tube
Fairlead tube/ mini stinger
Stinger
Headlight hoops
From inside
I leave for work Sunday so there won't be any more picture until the 28th
April 2014 COTM
Unread 04-13-2013, 04:03 PM   #191
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
i like!
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline   Reply With Quote Quick reply to this message
Unread 04-13-2013, 06:05 PM   #192
gfox48
That front bumper looks really good.
Build Thread: http://www.jeepforum.com/forum/f177/zombie-prep-xj-1500071/
gfox48 is offline   Reply With Quote Quick reply to this message
Unread 04-13-2013, 07:29 PM   #193
MOBBiN
MOBBiN's Avatar
Thanks guys it's turning out exactly how I wanted it
April 2014 COTM
Unread 04-15-2013, 08:04 PM   #194
Project1
that bumper is beefffy
Project1 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 11:18 PM   #195
MOBBiN
MOBBiN's Avatar
The 8" channel i used as a winch plate is very beefy. A tad overkill if ya ask me...
April 2014 COTM
