MOBBiNs 01 xj build - Page 12 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > MOBBiNs 01 xj build
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-11-2013, 05:51 AM   #166
DNFJ
DNFJ's Avatar
Sharp man, I like it.
Just Another Yellow TJ
Built Not Bought #704
Previous:
'00 XJ 6.5 on 35" KM2s
'96 ZJ 2 on 31" Baja Claws
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 04-01-2013, 11:16 PM   #167
MOBBiN
MOBBiN's Avatar
Making some quick discos. Just need to bolt them up
I cut up, rounded off and drilled some grade 8 bolts and stuck some lynch pins in em for the disconnecting part
Also bought a Warn M8000i today. Guess that means ill need a winch bumper
2001 Silverstone Metallic Classic/Limited XJ
April 2014 COTM
MOBBiN is offline   Reply With Quote Quick reply to this message
Unread 04-02-2013, 08:13 AM   #168
DNFJ
DNFJ's Avatar
Or you can give me the winch. :P Nice discos.
Previous:
Unread 04-03-2013, 03:35 PM   #169
MOBBiN
MOBBiN's Avatar
New vs old:
Pulling the old stud:
Replaced the old stud with a grade 8 bolt I rounded off, drilled and put a lynch pin in. Also replaced the sway bar bushing (k3171 moog)
Old vs new:
Poly spacers:
And done...
April 2014 COTM
Unread 04-04-2013, 07:42 AM   #170
XJ99XJ
1995 XJ Cherokee
Really like then disco's. I could or a set of em soon! Should throw together I parts list. Help a brother out!!
--1999 Cherokee Sport 2" Lift 30" rubber
---1995 Cherokee Sport 4.5" 32" rubber
XJ99XJ is offline   Reply With Quote Quick reply to this message
Unread 04-04-2013, 07:53 AM   #171
MOBBiN
MOBBiN's Avatar
(4) female 1/2" rod ends/Heim joints
1/2" Threaded rod. I cut mine at 7" each side. I bought 3'
(8) 1/2" nuts. 2 on each disco and 2 on each stud
(2) 1/2 grade 8 bolts
(8) 3/8" poly spacers. These will depend on your mounting points. I didn't want mine rattling around
I also had the top mounts from the old IRO endlinks so I didn't have to make or build those. I spent right at $55 dollars making them and they took about an hour. I used a tie rod end puller to remove the factory studs. They came right out with no issues.
April 2014 COTM
Unread 04-04-2013, 09:10 AM   #172
XJ99XJ
1995 XJ Cherokee
Originally Posted by mobbin
(4) female 1/2" rod ends/heim joints
1/2" threaded rod. I cut mine at 7" each side. I bought 3'
i also had the top mounts from the old iro endlinks so i didn't have to make or build those. I spent right at $55 dollars making them and they took about an hour. I used a tie rod end puller to remove the factory studs. They came right out with no issues.
boom thanks man!
Unread 04-04-2013, 09:28 AM   #173
MOBBiN
MOBBiN's Avatar
Originally Posted by XJ99XJ View Post
boom thanks man!
No prob.
Check this thread out also: quick disco thread
April 2014 COTM
Unread 04-06-2013, 01:37 AM   #174
MOBBiN
MOBBiN's Avatar
Before:
After:
Safari snorkel bling
April 2014 COTM
Unread 04-06-2013, 01:46 AM   #175
MOBBiN
MOBBiN's Avatar
Picked up a set of backing plate, rotors and calipers off a 98 Grand Cherokee yesterday
Yay for being able to stop better
April 2014 COTM
Unread 04-06-2013, 07:43 AM   #176
DNFJ
DNFJ's Avatar
Originally Posted by MOBBiN View Post
Before:
After:
Finally.
Previous:
Unread 04-06-2013, 12:11 PM   #177
MOBBiN
MOBBiN's Avatar
Originally Posted by DNFJ View Post
Finally.
Yes! Still need to find a windsheild wiper fluid resivor. What'd you use?
April 2014 COTM
Unread 04-07-2013, 05:52 AM   #178
DNFJ
DNFJ's Avatar
I still don't have one, but get some tube and connectors from advanced, then go to a jy and get one from a 96 or older XJ. They go in the engine bay by the air box instead of the fender.
Previous:
Unread 04-07-2013, 10:48 AM   #179
MOBBiN
MOBBiN's Avatar
Gotcha. I've read about that from EricsXJ. Just not a lot of details on how to hook it up. It's nothing I can't figure out.
April 2014 COTM
Unread 04-07-2013, 09:28 PM   #180
bl44st
Nice build! Wish i had a XJ
bl44st is offline   Reply With Quote Quick reply to this message
