Moab with 285/75r16 rub??? - JeepForum.com
post #1 of 9 Old 06-25-2012, 06:35 AM Thread Starter
xjfan
Just wanted to get your input.
I'm in need of wheels and tires soon. Been searching for a while and found a set of 5 moab 16's with Uniroyal 245/75r16 on them now. Asking price is $500.
Once I wear them out, I'm planning to go with 285/75r16. I've got a 4.5" and wanted to know if any has this setup and rubs? Front or rear.
Since finding them, I'm depating if I should go with steel. I currently have 15x8 with 3.25bs. No problems with rubbing at all.
Most of the wheeling I do is mud. Sometime small rocky stuff but that's if it happens to be on the same trail. In south florida, I haven't run into much rock trail. The only place I know of is in Ocala and that's a long drive.
XJ is my daily driver. If I go with Moab's they will have AT's that's close to 32". I'll put some kind of MT on my current wheels.
Joe
1999 XJ Sport, Black on Black, 4.0L
Follow build-up
xjfan is offline
post #2 of 9 Old 06-25-2012, 07:34 AM
chriskeenan
space the wheels out and you'll be fine
chriskeenan is offline
post #3 of 9 Old 06-25-2012, 08:55 AM Thread Starter
xjfan
What's you guys thought? Steel vs Moab? Is it preference? Better tire combo?
Thanks..
Joe
Follow build-up
xjfan is offline
post #4 of 9 Old 06-25-2012, 09:16 AM
AeroSync
Where in Miami are you?
I had Moabs on 285/75/16 and on an RE 3.5" and it was good but if I flexed the fenders popped off, at least the fronts. The Moab rim has 5" of backspacing.
Some pictures to help visualize at Ocala.
I drive an Orange.
AeroSync is offline
post #5 of 9 Old 06-25-2012, 09:47 AM Thread Starter
xjfan
I'm in north miami. What kind of tire are your running?
I've been searching and found Summit has a set of 5 - 15x8 with 3.75bs for around $215.
Still deciding if I should go steel or moab. Anyone have summit wheels? Any problems?
Joe
Follow build-up
xjfan is offline
post #6 of 9 Old 06-25-2012, 09:54 AM
Rockdrummer93
I had 285/75s on Moabs at 5" of lift for a week or 2, without spacers they rubbed the control arms at full lock but other then that they were fine.
2014 Cherokee Of The YEAR
Rockdrummer93 is offline
post #7 of 9 Old 06-25-2012, 10:41 AM Thread Starter
xjfan
After finding those Summit wheels. I'm second guessing going with those Moabs....
Joe
Follow build-up
xjfan is offline
post #8 of 9 Old 06-25-2012, 12:51 PM
Wearingthin
I have 305/70s on my Moabs with 1.25" spacers on a 4.5" lift. Without trimming they rub in the front a lot. They of course look way better than steel, but tires are more expensive
Patriot Blue XJ 4x4
RE 4.5" | 305/70/16 MTR K
Wearingthin is offline
post #9 of 9 Old 06-25-2012, 06:03 PM
AeroSync
At that time I think I had Nitto A/Ts. However I have 35s on JK 17's now.
Moabs look nicer in my opinion, but it is up to you.
I drive an Orange.
AeroSync is offline
Lt245 75r16 tires will they fit? efizzle XJ Cherokee Technical Forum 5 06-10-2015 02:55 AM
2" lift w/ 245/75r16's spnce XJ Cherokee Technical Forum 3 08-27-2010 11:02 AM
rubicon rims and 265/75r16 goodyear mtrs on my xj.... phattysrt XJ Cherokee Technical Forum 12 07-15-2009 07:51 PM
Pic Req: 265/75R16 on stock 16" cshontz XJ Cherokee Technical Forum 9 08-04-2007 10:54 AM
What width rim for a 265/75R16? XJ-NoDough XJ Cherokee Technical Forum 3 11-13-2004 12:43 AM
