-   XJ/MJ Cherokee Non-Technical Forum (http://www.jeepforum.com/forum/f177/)
-   -   Moab with 285/75r16 rub??? (http://www.jeepforum.com/forum/f177/moab-285-75r16-rub-1385344/)
xjfan 06-25-2012 06:35 AM
Just wanted to get your input.
I'm in need of wheels and tires soon. Been searching for a while and found a set of 5 moab 16's with Uniroyal 245/75r16 on them now. Asking price is $500.
Once I wear them out, I'm planning to go with 285/75r16. I've got a 4.5" and wanted to know if any has this setup and rubs? Front or rear.
Since finding them, I'm depating if I should go with steel. I currently have 15x8 with 3.25bs. No problems with rubbing at all.
Most of the wheeling I do is mud. Sometime small rocky stuff but that's if it happens to be on the same trail. In south florida, I haven't run into much rock trail. The only place I know of is in Ocala and that's a long drive.
XJ is my daily driver. If I go with Moab's they will have AT's that's close to 32". I'll put some kind of MT on my current wheels.
chriskeenan 06-25-2012 07:34 AM
space the wheels out and you'll be fine
xjfan 06-25-2012 08:55 AM
What's you guys thought? Steel vs Moab? Is it preference? Better tire combo?
Thanks..
AeroSync 06-25-2012 09:16 AM
Where in Miami are you?
I had Moabs on 285/75/16 and on an RE 3.5" and it was good but if I flexed the fenders popped off, at least the fronts. The Moab rim has 5" of backspacing.
Some pictures to help visualize at Ocala.
https://fbcdn-sphotos-a.akamaihd.net...51912382_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...64158653_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...36972992_n.jpg
xjfan 06-25-2012 09:47 AM
I'm in north miami. What kind of tire are your running?
I've been searching and found Summit has a set of 5 - 15x8 with 3.75bs for around $215.
Still deciding if I should go steel or moab. Anyone have summit wheels? Any problems?
Rockdrummer93 06-25-2012 09:54 AM
I had 285/75s on Moabs at 5" of lift for a week or 2, without spacers they rubbed the control arms at full lock but other then that they were fine.
xjfan 06-25-2012 10:41 AM
After finding those Summit wheels. I'm second guessing going with those Moabs....
Wearingthin 06-25-2012 12:51 PM
I have 305/70s on my Moabs with 1.25" spacers on a 4.5" lift. Without trimming they rub in the front a lot. They of course look way better than steel, but tires are more expensive
AeroSync 06-25-2012 06:03 PM
At that time I think I had Nitto A/Ts. However I have 35s on JK 17's now.
Moabs look nicer in my opinion, but it is up to you.
The time now is 08:05 AM.
