Milton's Other Jeep Build - Page 29 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Milton's Other Jeep Build
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 12-20-2013, 10:42 PM   #421
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
Score! on those seats
What length shackles are you running?
Build Thread
April 2014 & 2015 COTM
MOBBiN is offline   Reply With Quote Quick reply to this message
Unread 12-21-2013, 06:33 AM   #422
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Tell me about it!
They are 2-2.5" shackles (5" eye to eye).
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is online now   Reply With Quote Quick reply to this message
Unread 12-21-2013, 08:40 AM   #423
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
However, I'd looked at those and didn't think they'd be compatible with a rear hitch because they use the same space/bolts. But what I noticed about the pics in Brandon's thread is the HDO no lift relos are tucked up higher. My set-up appears to compromise my departure angle (the shackles and rear of springs are now low hanging fruit).
Anyway, only driven up and down the block to make sure everything's square and tight. I might go search for a flex spot today and see what these things do.
HD includes several 1/4 spacer plates to allow brackets to be mounted above or below a hitch. But yea the "tucked up" thing was a big selling point, but honestly its probably a non issue really, plenty of people out there wheeling standard relo's. I actually think it looks kinda cool as is. You could always run shorter shackles and add an extra leaf to the pack to gain some clearance back if it turned out to be an issue.
Now flex that ***** and be amazed that your rear suspension works!
P.S. Those seats.....
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 12-21-2013, 04:21 PM   #424
JeepN4KC
JeepN4KC's Avatar
I know - really curious how it performs now...........
~Mike~
Build Thread WK
Unread 12-29-2013, 01:27 PM   #425
JeepN4KC
JeepN4KC's Avatar
Temps have been well above freezing last few days and so the last winter storm we got was melting and generally making a mess. The XJ has been sitting clean in the garage since getting the relos and seats installed. Today everything is back to frozen, weather wise, so I took the blue Jeep out for a quick flex and some poser pics.
Quite pleased with the travel in the rear suspension - I didn't even get it in full flex/droop but the down travel is definitely there with ease. I see longer shocks and brake lines in the future............
~Mike~
Build Thread WK
Unread 01-01-2014, 11:07 AM   #426
Camfam07
looking great!
Camfam07 is offline   Reply With Quote Quick reply to this message
Unread 01-02-2014, 08:32 PM   #427
JeepN4KC
JeepN4KC's Avatar
Originally Posted by Camfam07 View Post
looking great!
Thanks. I'm pretty happy with where it's at for now.
Always thinkin though............what next? :-P
~Mike~
Build Thread WK
Unread 01-05-2014, 02:21 AM   #428
unabashedpraise
Where were these taken? Off road park?
1998 Grand Cherokee Limited; 5.2 L, 249
Help: Rear left lock doesn't lock using power locks, but will unlock. Any ideas?
-Born once, die twice. Born twice, die once.
unabashedpraise is offline   Reply With Quote Quick reply to this message
Unread 01-05-2014, 06:52 AM   #429
JeepN4KC
JeepN4KC's Avatar
No.....I haven't had a chance to get to any good places since doing the relocations.
~Mike~
Build Thread WK
Unread 01-21-2014, 05:00 PM   #430
JeepN4KC
JeepN4KC's Avatar
Finally took the time to work on my sagging driver's door. I picked up a couple sets of Dorman #38439 hinge pin and bushings and swapped them in. The old bushings were completely disintegrated - all of them.
This little project proved to be a PITA for what it is - I'd recommend a second set of hands for this. Dremel with little cut-off wheel works just fine to cut the pins then a big flathead and a hammer to wedge into the cut and the old pins pop out pretty easy. Getting everything back together is the fun part if doing this solo. The replacement pins have to have the serration ground off at the heads and in the end the reassembles hinges don't fit as tight as I'd hoped. May have gotten wallered out some over time after time of opening and closing with shot bushings. But it is what it is and at least I have new pins with fresh bushings and everything lubed with bearing grease.
I realize I passed on an opportunity to set this door up to go doorless, especially considering it is essentially the same steps involved. However, I'm not sure I'm sold on that modification as my tires sling some stuff when I wheel it and the doors make a good barrier between the outside of the Jeep and the inside of the Jeep. Maybe if I had flares but I probably never will...........
Besides, the new pins have snap rings that make it easy enough to remove the new pins and I could always come back to the doorless idea.
I also adjusted the striker at the b-post so the door now opens and closes smoothly w/o the need to pull up on it.
I'm not happy with the alignment but whatta ya gonna do?
Good from afar:
....but far from good:
~Mike~
Build Thread WK
Unread 03-07-2014, 01:47 PM   #431
JeepN4KC
JeepN4KC's Avatar
Haven't done anything to or wheeled the XJ in quite a while. Everytime I plan on something for the past couple months the weather decides to ruin it.
I did take the spare front shaft I had in the garage and broke it all down - ujoints, centering socket, ball, spring, yoke etc.
I was planning to rebuild it but I'm running into some confusion as to the parts list. Specifically the centering yoke, socket, ball, spring (double cardan parts).
Any body have some solid part numbers for the double cardan rebuild on an '01 front shaft? I'm looking at Spicer 211544X but just that yoke is like 50 bucks. I also can't get a solid line on the rubber boot/dust cover.
Ideas anyone?
~Mike~
Build Thread WK
Unread 03-07-2014, 02:01 PM   #432
donthelegend
Ideas anyone?
Spicer 2-86-418 CV Seal Slinger is the rubber boot/dust cover
Spicer 211355X Is the greasable yoke with centering ball/spring
Spicer 211544X is the non-greasable yoke with centering ball/spring
Moog/Precision 617 is the replacement centering ball/spring kit that you can use to avoid replacing the entire yoke, but getting the old one out is a bit of a pain.
Tool for re-installing the rubber boot:
http://www.dennysdriveshaft.com/p154...oot_part_.html
If you don't buy that tool, buy an extra rubber boot. Odds are good you'll wreck the first one trying to get it on without the special tool (ask me how I know )
Depending on how much your time is worth to you, the replacement yokes with the centering ball already installed are worth every penny. Getting the old race out of the yoke takes a while the first time you do it.
Hopefully those part numbers answer your question?
donthelegend is offline   Reply With Quote Quick reply to this message
Unread 03-07-2014, 02:12 PM   #433
JeepN4KC
JeepN4KC's Avatar
Well this is what I have:
I might have to look up the MOOG part. Getting the race outta the socket wasn't bad - snapped a tip of a screwdriver but I got it out with little to no damage to the parts. Only reason I even bothered was because I dropped the yoke and 3 of the needle bearings fell into the hole between the back of the ball and the yoke. I thought of just regreasing it reusing it but I still would prefer new stuff.
Thanks for the info!
~Mike~
Build Thread WK
Unread 03-07-2014, 02:15 PM   #434
JeepN4KC
JeepN4KC's Avatar
BTW - holycrap! 25 bucks for that tool! I'd probably never use it again.................
Edit:
Oh my God! Another 24 bucks for the Moog/Precision part from RockAuto (cheapest I see)! What have I gotten myself into?
~Mike~
Build Thread WK
Unread 03-07-2014, 02:23 PM   #435
dukie564
dukie564's Avatar
1995 XJ Cherokee
Just went though doing mine
Head over to http://www.actionmachineinc.com/
Grab two ujoints (5-1310x), one centering ball rebuild kit (404-0A), and one new dust boot (2-86-418).
$68.49 Shipped. You don't need a tool for the dust boot just slide it on and use a hammer and blunt chisel to seat it
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 283,000 mi and runnin' strong
http://www.jeepforum.com/forum/f22/project-danger-cart-xj-1297118/
dukie564 is offline   Reply With Quote Quick reply to this message
