Milton's Other Jeep Build - Page 27 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Milton's Other Jeep Build
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 11-20-2013, 10:28 AM   #391
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Nothing new in the build other than I cleaned up the original trimming and took an additional 1/2" or so off in the front fenders and I freshened up the wheel wells and rockers with some rattle can flat black a few days ago. Everything as far as the cooling system is solid on all accounts since "fixing" the rad cap coolant spew problem. Got out and wheeled it last Sunday - and after wheeling a couple times since revamping the cooling system and yanking the rear sway I can say the Jeep definitely runs a little cooler and gets smoother, more complete travel in the rear.
.........and just for good measure - yes that is an H1 Hummer getting rescued by a Jeep JK:
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is online now   Reply With Quote Quick reply to this message
Unread 11-20-2013, 11:05 AM   #392
8pitcher
8pitcher's Avatar
Went out with Dan I see looks like fun I wish I woulda been able to go but I was workin on my 4 link on the crawler
I hope we can meet up at wheelin for toys December 14th
Built Not Bought #640
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 11-20-2013, 01:42 PM   #393
straightsixjeep
Beat me to it Trent. Hopefully when the YJ is done Dan will be able to get another group out there.
http://www.jeepforum.com/forum/f22/98-xj-gettin-her-trail-ready-1417602/
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 11-20-2013, 01:49 PM   #394
8pitcher
8pitcher's Avatar
Gotta come out man!!!
Unread 11-20-2013, 03:48 PM   #395
straightsixjeep
Thanksgiving break!
Edit: Mike, that back window really came out good.
Unread 11-20-2013, 07:38 PM   #396
JeepN4KC
JeepN4KC's Avatar
Originally Posted by straightsixjeep View Post
Thanksgiving break!
Yes, thanks, it came out better than I expected. I'm definitely glad I went that route rather than mess with a new piece of glass.
~Mike~
Build Thread WK
Unread 11-21-2013, 11:18 AM   #397
ibjeepin95
Looks like you had some fun! Jeep looks great!
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 11-22-2013, 09:31 AM   #398
JeepN4KC
JeepN4KC's Avatar
Thanks, man, it was a pretty good time. Always cool to check out new places - especially when they're close to home.
~Mike~
Build Thread WK
Unread 11-22-2013, 07:22 PM   #399
JeepN4KC
JeepN4KC's Avatar
Had some squealing going on from the front passenger wheel last couple times out. Originally, I thought it was the brakes or some crap getting hung up between the rotor and the backing plate. After some further inspection I found the culprit. So, I commenced to tearing down the front end - and let me tell ya, getting the hub bearings separated from the knuckle was a mother@#$*er!!
First I pulled the passenger side and cleaned up the knuckle:
Then the driver side:
Once I had them both out I cleaned up the shafts:
This is the passenger u-joint:
By "clean" I mean I took a wire brush to scrub all the crap and build up off, vacuumed a bunch of gunk out of the tubes, and lubed everything heavily with PB Blaster/WD40.
So, for now, the blue Jeep sits out of service again:
~Mike~
Build Thread WK
Unread 11-22-2013, 11:15 PM   #400
straightsixjeep
Yea probably about time for a new u-joint Did you try using a socket or an extension to pry the unit bearing out by turning the steering wheel?
Unread 11-23-2013, 09:14 AM   #401
JeepN4KC
JeepN4KC's Avatar
Unfortunately for me, that wasn't working - lots of screwdriver/chisel and BFH. The hub flange was pretty well fused to the knuckle.
But yeah that passenger side is gnarly lookin, huh?
~Mike~
Build Thread WK
Unread 11-26-2013, 04:13 PM   #402
JeepN4KC
JeepN4KC's Avatar
Ended up getting the front rotors turned yesterday. It's on jackstands in the garage with the front shafts pulled - why not?
Also bought a cheap pair of pads. I realize it isn't optimal but I'm willing to cheap out on easily changeable consumables. :-P
New front brakes on the beater for 27 bucks?...........gotta keep an addiction under wraps I guess.............
~Mike~
Build Thread WK
Unread 12-01-2013, 12:19 AM   #403
8pitcher
8pitcher's Avatar
See you at wheelin for toys?!? I'll be there in the jk
Unread 12-01-2013, 07:47 PM   #404
JeepN4KC
JeepN4KC's Avatar
Still planning on it. Have yet to register being as the XJ is still sitting on jackstands in the garage. I should have the front shafts broken down and new ujoints and hub bearings swapped in tomorrow but might not get to putting it all back together until later this week. I'm not putting pen to paper on the event at KSR until the blue Jeep is back in service - so for now I have Wheelin for Toys penciled in.
~Mike~
Build Thread WK
Unread 12-02-2013, 04:38 PM   #405
JeepN4KC
JeepN4KC's Avatar
Got everything back together today!
Took the shafts to a buddy's place so we could rebuild the shafts. While I was there I refinished the backing plates and he gave me a stub shaft to use as a trail spare.
Shafts back in, backing plates and hubs bolted down:
Rotors, fresh pads, and calipers back on:
Back on its own front feet:
Drove it around to check it out - all is good to go
~Mike~
Build Thread WK
