Milton's Other Jeep Build - Page 21 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Milton's Other Jeep Build
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 05-13-2013, 06:56 AM   #301
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Got the stiffeners burned on, primed and top coated this past Saturday. It is quite a project and I'm glad I did the majority of the prep a few days prior.
I failed to get any pics of the process but in a nutshell: put the rig on jackstands f/r and get the wheels off and outtta the way; the more hands the better (we had 4 of us getting in on the install); the more jacks the better; at least 1 large c-clamp; button/rosette welds are your friend.
First my bro tacked in starting at the front and used a bfh (manipulator he called it) to "cinch up" the stiffener to the unirail as he worked his way down. Then did 1" diameter rosette welds every 8" (drilling those out with a 18v cordless and stepbit - went through some batteries); capped off the front and rear ends; welded up the seams where the bends are; 1.5-2" stitch welds on the inboard lip of the uni/stiffener - alternating with the rosettes on the opposite side.
I also caulked in some paintable silicone around the entire welded assembly anywhere that wasn't "sealed."
As I said - it is a long, messy, steely process and it didn't occur to me to pull out the cell camera during - but I did snap some while I finished up.
3 coats of primer:
Finished with 3 coats semi-flat enamel:
Overall, aside from installing the Aussie in the rear diff - these were the funnest project to tackle on the XJ - good times.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 07:40 AM   #302
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Looking good! This is something I really need to do before long.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 03:11 PM   #303
Joshharris98xj
X2 looks clean, I need to do this. This might just be my imagination but I can feel the jeep flex a bit.
Joshharris98xj is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 04:54 PM   #304
Project1
That just looks so right
Project1 is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 07:54 PM   #305
JeepN4KC
JeepN4KC's Avatar
Yes - it is. Especially before you get into the unirails too much in the rocks. Having to weld these into deformed unirails would have really been a PITA.
It might not be your imagination.
Yup - it do don't it.
~Mike~
Build Thread WK
Unread 05-16-2013, 06:42 AM   #306
Project1
man I'm stoked how your jeeps turning out.. you must be really happy with it. It sweet when you do it right .. Just went though your thread again .. looks killer man .. good work
Unread 05-16-2013, 02:37 PM   #307
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
x2, one of my favorite builds right here. Just a perfect, capable all arounder. Not to mention lots of well documented progress. Props again!
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 05-16-2013, 07:05 PM   #308
straightsixjeep
Your neighbors JK looks better with a lift I believe he is on the kc northland jeepers fb page, seen it on there if I recall.
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 05-16-2013, 10:30 PM   #309
8pitcher
8pitcher's Avatar
I'm part of that club what's his name?
Built Not Bought #640
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 05-16-2013, 11:16 PM   #310
JeepN4KC
JeepN4KC's Avatar
Thanks - It's been a good project for me - keeps me busy.
Well it's far from perfect and it's good it isn't my dd - but I do what I can when I can to provide details.
Yes - it does look good how he set it up.
Ask him next time ya see him.
~Mike~
Build Thread WK
Unread 05-17-2013, 07:39 AM   #311
Project1
So whats next on the list?
Unread 06-01-2013, 08:51 AM   #312
JeepN4KC
JeepN4KC's Avatar
Wheel it!
~Mike~
Build Thread WK
Unread 06-01-2013, 01:56 PM   #313
Holaday
Wheel it!
When are you doing that?
Holaday is offline   Reply With Quote Quick reply to this message
Unread 06-01-2013, 05:59 PM   #314
JeepN4KC
JeepN4KC's Avatar
Tomorrow down in Mapleton (KSRocks)
How was SMORR?
~Mike~
Build Thread WK
Unread 06-02-2013, 03:43 PM   #315
Holaday
How was SMORR?
Going on the 21st. Looks like I will be the smallest jeep in the group
