Milton's Other Jeep Build - Page 19 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Milton's Other Jeep Build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 05-02-2013, 06:47 PM   #271
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Spent the other day on the interior with a wirewheel and heavy grit sanding wheel and the grinder.
Like I said before - the driverside floor is the area that has the cancer. There are some minimal spots elsewhere but under the rear, outboard base of the driver seat is the worst. Area under the pedals came fairly clean.
I wanted to at least clean it up and get something on the floor in the driver side so after cleaning it up and scuffing it good I laid down some Krylon primer:
Then sprayed it with some flat black enamel:
This will need a more aggressive approach eventually:
from directly underneath:
For now this is how it sits in the garage:
The other day I was able to get together with a guy from my club who happens to have a template of the rear glass. Hopefully in the next few days I'll get my rear fake window put in.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is online now   Reply With Quote Quick reply to this message
Unread 05-02-2013, 07:01 PM   #272
Project1
I did my floor in that dupi color bedlinger .. I have good luck with that stuff... It was good for about 2 years then it faded a bit so I just hit it again and it looks really good. its like 10$ and would take you like 2-4 cans
Project1 is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 07:06 PM   #273
JeepN4KC
JeepN4KC's Avatar
I was originally wanting to use chassis saver on the bad sections and then Monstaline the entire floor with just a base black. I'm not so sure the chassis saver will help the spot at the back of the driver seat. I may end up cutting that floor pan out - having someone weld in new - then go from there.
~Mike~
Build Thread WK
Unread 05-02-2013, 09:06 PM   #274
Project1
that is for sure a better plan .. A a little more expensive but for sure the way to go .. I need to do that at some point
Unread 05-02-2013, 09:46 PM   #275
donthelegend
Whatever you go with for bedliner, DO NOT use Herculiner. It will never come clean and it chews up any cleaning sponge/cloth/etc incredibly fast. I went with monstaliner and couldn't be happier
donthelegend is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 10:02 PM   #276
Joshharris98xj
I used a base coat of duplicolor and when I ran out I had some heculiner laying around I used but I had to thin it out it works great. WRONG THREAD my apologies
image-3107325342.jpg   image-2737340452.jpg   image-1841926934.jpg   image-3960735380.jpg   image-3504872209.jpg
image-2117989230.jpg   image-2781155271.jpg   image-1976544871.jpg   image-2032563530.jpg   image-2763403627.jpg
Joshharris98xj is offline   Reply With Quote Quick reply to this message
Unread 05-03-2013, 03:29 PM   #277
JeepN4KC
JeepN4KC's Avatar
^^^ Okay ?
Finally got my fake glass cut.
~Mike~
Build Thread WK
Unread 05-03-2013, 10:57 PM   #278
straightsixjeep
That was fast!
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 05-04-2013, 08:32 AM   #279
Project1
man the window is great... did you go with mar 10?
Unread 05-04-2013, 11:22 AM   #280
JeepN4KC
JeepN4KC's Avatar
Originally Posted by straightsixjeep View Post
That was fast!
Took longer than I initially figured.
mar 10? Don't know what that is. I used this:
and this:
When cutting the polycarbonate I used a jigsaw and laminate (20 tpi) blade. It is nearly a must to have a large enough flat work space to put the sheet on and clamp the edges - otherwise the plastic will bounce and crack. Also - have a spray bottle with water on hand and spray the blade/plastic interface as you cut. Otherwise the polycarbonate will melt/fuse back together at the trail edge of the blade as you go. It is not a fast process cutting this stuff.
This is where I left off last night:
Just to "polish up" the look I'll tape off the outer edge of the poly and give it a finished primer&topcoat of something.
~Mike~
Build Thread WK
Unread 05-04-2013, 12:12 PM   #281
Project1
that looks like good stuff .. Mar10 is what they use for race car windows, and stuff .. its strong, lite, and pretty cheap, and you can get it tinted when you order it.
Unread 05-04-2013, 09:41 PM   #282
ibjeepin95
Nice!
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 05-05-2013, 07:58 AM   #283
Holaday
^^^ Okay ?
You would think he would be nice enough to fix his mistake...
Attachment 620853
Looks great man
Holaday is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 12:03 AM   #284
8pitcher
8pitcher's Avatar
I could help ya with welding a new one in if you'd like. I need a good excuse to go weld something.
Built Not Bought #640
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 07:54 AM   #285
JeepN4KC
JeepN4KC's Avatar
I've read this around the net and vendor display thread here. Herc gets its texture from rubber bits; Monsta gets its texture from the material itself and the roller.
I would of liked to have a tinted piece to work with - but what I got will get it done.
Nice!
Yup!
Originally Posted by Holaday View Post
Looks great man
Still trying to line all my ducks for SMORR.
If you have a welder and the skills and are saying you want something to weld .....................
~Mike~
Build Thread WK
