Milton's Other Jeep Build - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Milton's Other Jeep Build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 04-22-2013, 02:57 PM   #241
ibjeepin95
Looks like some good fun. Nice vent window mod
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 09:03 PM   #242
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
It was definately a good day of fun. There were a good handfull of other XJs out there. One broke a D30 shaft and another stripped the teeth off his D30 ring gear. So - my "vented window" was but a scratch in comparison.
Still - been looking at swapping in a sheet of lexan - but the $h!t seems to be most common in 48" width. The bottom width of the window opening is ~52".
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is online now   Reply With Quote Quick reply to this message
Unread 04-22-2013, 09:33 PM   #243
straightsixjeep
I'm thinking to myself, "did he grow a beard?" "It still doesn't look quite like him." That xj looks great on the trails, quality pictures as usual. Sorry about the hatch, at least you can chuckle about it in years to come. I went wheelin Saturday and my friend backed into a tree with his xj, messed up his hatch pretty good and shattered the glass. Let me know if you end up getting a new hatch or find a few laying around, my friend is on the look out. Take care.
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 11:01 PM   #244
8pitcher
8pitcher's Avatar
You can get big sheets of it and then just cut it yourself. That's what we do at school when we use lexan
Built Not Bought #640
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 06:08 PM   #245
unabashedpraise
Any ideas on what you may replace it with? I can handle dent carnage, but glass sucks.
1998 Grand Cherokee Limited; 5.2 L, 249
Help: Rear left lock doesn't lock using power locks, but will unlock. Any ideas?
-Born once, die twice. Born twice, die once.
unabashedpraise is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 08:59 AM   #246
JeepN4KC
JeepN4KC's Avatar
Not gonna replace the entire hatch - it isn't damaged to that point by any means. Just the window.
Yep.
Workin on it.
~Mike~
Build Thread WK
Unread 04-24-2013, 09:17 AM   #247
Weeder1
What about another glass from a junkyard xj?
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 09:46 AM   #248
JeepN4KC
JeepN4KC's Avatar
^^^Thought about that. But in the end I decided I'm not putting something back in it that will break again.
~Mike~
Build Thread WK
Unread 04-24-2013, 12:46 PM   #249
Weeder1
Good point!
-98 xj sport-
Unread 04-25-2013, 06:12 PM   #250
dukie564
dukie564's Avatar
1995 XJ Cherokee
too bad the late model XJ rear windows are urethaned in. Mine is easy as hell to pop in and out - just pull the gasket and done.
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 283,000 mi and runnin' strong
http://www.jeepforum.com/forum/f22/project-danger-cart-xj-1297118/
dukie564 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 09:45 PM   #251
JeepN4KC
JeepN4KC's Avatar
Well mine popped out easy enough with the help of a big f'n tree
~Mike~
Build Thread WK
Unread 04-25-2013, 09:54 PM   #252
JeepN4KC
JeepN4KC's Avatar
This is how it sits as of now:
Old stuff in the window lip cleaned/scraped out, sanded, primed, light sanding again, rattlecan black enamel.
~Mike~
Build Thread WK
Unread 04-25-2013, 10:40 PM   #253
donthelegend
When you first said you were going to put lexan or something similar in I thought no way in hell will you be able to make that look good. Now you've got me re-thinking that Any thoughts yet on how you'll retain it?
donthelegend is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 11:05 PM   #254
JeepN4KC
JeepN4KC's Avatar
Do you mean hold the fake glass in or retain the stock look?
~Mike~
Build Thread WK
Unread 04-25-2013, 11:20 PM   #255
donthelegend
Now that I re-read my post, that was a horrible way to word it Let me try this again...
How will you hold the fake glass in?
Edit to add: You've had that avatar for a little while now and I still crack up everytime I see it
