Milton's Other Jeep Build - Page 14 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Milton's Other Jeep Build
Ford Explorer 8.8 4340 Chromoly Axle Shaft Kit C Clip ElimSave 17.76% for the 4th of july with ruffstuff specialtiesThe Ruffstuff Optima Battery Box!
Unread 12-02-2012, 06:42 AM   #196
ibjeepin95
ibjeepin95's Avatar
Originally Posted by gtikyle
you should have won cotm, just sayin.
x2
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 12-02-2012, 10:52 AM   #197
Camfam07
Question if you dont mind real fast!... I asked about the Tranny mount a little while back and I got around to replacing it, well my jeep is a 1996 and I ask for a 1996 trans mount, well the one I removed from the JEEP had the 4 bolts a little off center of the mount, the new one looks to be centered and that it would not work without drilling some new holes into my crossmember, so my question is should I modify the one that I got supposedly for a 1996 xj, or should I get the "correct" off centered one? thanks let me know if this makes 0 sense, ill try and explain a little better.
Camfam07 is offline   Reply With Quote Quick reply to this message
Unread 12-02-2012, 11:48 AM   #198
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
x2
Aww - shucks you guys Meh......maybe someday.......
If it's me, I paid for the right part - I want it in my hands. I didn't pay for an OEM bolt in part that I need to modify $h!t to make work.
In other words, you probably could drill new bolt holes in your crossmember, but why?
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 12-02-2012, 12:32 PM   #199
Camfam07
thats what I was thinking just checking I didnt think there was any benefit to either one, so I will return it tomorrow! fun fun! Thanks for the info
Unread 12-02-2012, 12:39 PM   #200
JeepN4KC
JeepN4KC's Avatar
^^^ You bet, bud.
BTW - don't over torque the four trans mount nuts to the crossmember.
~Mike~
Build Thread WK
Unread 12-02-2012, 02:01 PM   #201
Camfam07
got ya, I dont think I did, I just snugged em down with a 3/8 ratchet laying down on my back I dont think I over did them hope not.
Unread 12-02-2012, 04:32 PM   #202
JeepN4KC
JeepN4KC's Avatar
^^^ Sounds good - it's just that the shank of the bolts coming down from the mount aren't very substantial.As long as you didn't snap the bolt off you should be fine.
~Mike~
Build Thread WK
Unread 12-02-2012, 04:52 PM   #203
Camfam07
noo definetly did not snap any off, I dont superman bolts unless there big and bulkly like the control arms and stuff! lol but definetly glad it wasnt a hard job I didnt even notice they were different until trying to bolt the new one and it wasnt fitting correctly, glad its super easy though. but I have been chasing vibes down for a little while now, so im gonna replace this and the lower ca's hopefully helps
Unread 12-02-2012, 05:59 PM   #204
straightsixjeep
I recently snapped off one of the four studs for the trans mount using a torque wrench. Its best to use a 13mm socket on a 3/8" ratchet to get them snug, dont over do it. Come back after a few hundred miles and check them again, get them relatively tight, dont over do it.
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 12-02-2012, 06:49 PM   #205
Camfam07
ok ill rememeber that tomorrow when I go and get the new part, I have a lady who hooks me up through her work, like bumper to bumper warehouse or something like that. cost me a whopping 11 bucks for the mount, I also grabbed a few moog ujoints for 6 bucks each for the shafts, she tends to give me wrong parts here and there, lol but she makes it right and hooks me up so cant complain.
Unread 12-03-2012, 01:57 PM   #206
Camfam07
hey another question, I see that you said that mount that is off center if for a 99+?? so mine is a 1996 why would it have a off center piece? or am I reading your post wrong from when you did that. she is saying she gave me the correct part so im starting to think maybe someone swapped trannys or something in this jeep not sure. but I need a off center mount what year has the off center?
Unread 12-03-2012, 02:34 PM   #207
JeepN4KC
JeepN4KC's Avatar
^^^ The old mount I took off was centered (my XJ is a '01). The centered mount does not match the belly pan I have. I needed an offcentered tranny mount to match the hole locations on the belly pan. The '99 OEM trans mount for the I6/AW4 is offcentered.
~Mike~
Build Thread WK
Unread 12-03-2012, 02:36 PM   #208
straightsixjeep
My 98' with the ax15 is off centered as well.
Unread 12-03-2012, 05:23 PM   #209
JeepN4KC
JeepN4KC's Avatar
Originally Posted by straightsixjeep View Post
The xj seems to be doing well offroad, climbed right up in the 2nd video! I have a feeling it will be a swamp next weekend (supposed to rain Thursday/Friday, then a chance of snow Saturday night).
Trent, this is at KS Rocks.
Weather looks like it'll be good to go last I saw.
~Mike~
Build Thread WK
Unread 12-03-2012, 07:22 PM   #210
8pitcher
What day is it? I got permission to go
[URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #640[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
8pitcher is offline   Reply With Quote Quick reply to this message
