Milky diff fluid - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > Milky diff fluid
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineBill Baird Motorsports DIY parts - NalinMFG.comTJ 5.25" Speaker Adapters - NalinMFG
Unread 08-18-2014, 04:39 AM   #1
Trainhop91
Milky diff fluid
I've been having a humming coming from the front end so I decided to open the diff and drain the fluid. When I did it was a milky white color. I'm guessing it's water? But wouldn't the water separate from the oil?
I'll be replacing the back seal as well since I noticed a some lol on the rear of the housing. Could that be how the water got in? It's a d30 on a 2000 xj. Any help would be awesome!
Trainhop91 is offline   Reply With Quote
Unread 08-18-2014, 08:34 AM   #2
mschi772
mschi772's Avatar
1997 XJ Cherokee
It's probably water. At the high speeds and heats that those moving parts reach, the water and oil become a milky emulsion that takes a very long time to separate. Check your breather hose for a leak/hole. Pull your wheels to see if there's evidence of oil leakage at the axle seals; that could be another potential entry point.
Sent from my phone
mschi772 is offline   Reply With Quote
Unread 08-18-2014, 09:05 AM   #3
937Comanche
1991 MJ Comanche
Yep. I've seen it look like chocolate milk, too. If your breather tubes aren't extended now might be the time...
'91 MJ with some mods
'14 MK without some mods
937Comanche is offline   Reply With Quote
Unread 08-18-2014, 11:37 AM   #4
Trainhop91
Can't seem to find a breather tube on this thing. None anywhere around the housing?
Unread 08-18-2014, 06:10 PM   #5
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
Kinda over there. The other end of the hose should be near the firewall.
According to the National Shooting Sports Foundation, AR-15 sporting rifles account for nearly 20% of all U.S. firearms sales.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan: Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 08-18-2014, 06:12 PM   #6
Trainhop91
Originally Posted by CJ7-Tim
Just about there. The other end of the hose should be near the firewall. .
Thanks for the picture, I had been looking around but couldn't find it. Ended up finding it on the other side. Seems all the other pictures I see have the vent tube on the passenger side. Any reason mine would be on the driver side?
