Mikes '96 XJ Build - Page 7 - JeepForum.com
post #91 of 131 Old 07-12-2013, 02:58 PM Thread Starter
T-REXJ
I prolly wont go extreme either but I think I have the weeker spline like you guys, are they marked?
T-REXJ is offline
post #92 of 131 Old 07-12-2013, 03:21 PM
Puck81
You have the 27 spline. 97+ get the 29 spline.
Puck81 is offline
post #93 of 131 Old 07-12-2013, 03:24 PM
XJmike0122
Mine is a Dana 35 because it has ABS yours is Chrysler 8.25 if it was made pre 06/96 than it would surly be the 27 spline. You can find out the month by checking the vin #. If it was made after that then there is a little chance its a 29 spline. Only way to know for sure is pulling the shaft which would take some work, but hey when was the last time the fluid has been changed in it anyway.
XJmike0122 is offline
post #94 of 131 Old 07-12-2013, 03:29 PM
XJmike0122
Man I know you have been around longer than me and thanks for all the help but I am looking at it right now where it says any xj made after 06/96 has a chance that's its a 29 spline just read a post with a 10/96 that had a 29 when he pulled it.
post #95 of 131 Old 07-12-2013, 03:30 PM Thread Starter
T-REXJ
have no idea should prolly do that anyways
T-REXJ is offline
post #96 of 131 Old 07-12-2013, 03:35 PM
Puck81
Good luck with the build ether way.
Puck81 is offline
post #97 of 131 Old 07-12-2013, 03:48 PM
XJmike0122
I'm not trying to be a dick or anything just trying to give the best info I can when I actually know it (Does not happen often ) but like I said thanks because I would probably still be looking for a 44 without your heads up on the 29 spline 8.25
post #98 of 131 Old 07-12-2013, 03:51 PM Thread Starter
T-REXJ
im gonna look up my vin and see what month it was made
T-REXJ is offline
post #99 of 131 Old 07-16-2013, 02:41 AM
XJmike0122
Did you ever find out what month your XJ was built?
post #100 of 131 Old 07-16-2013, 09:20 AM Thread Starter
T-REXJ
was workin this weekend ill check it out now
T-REXJ is offline
post #101 of 131 Old 07-18-2013, 05:28 PM Thread Starter
T-REXJ
Havent don't much recently waiting until I get back from LA and then the lift and tires should go on.... but until then I took off the fog lights that were on there cause only one worked and put my spare on top to see if I liked it
T-REXJ is offline
post #102 of 131 Old 07-19-2013, 02:00 AM
XJmike0122
How do you feel about the tire?
post #103 of 131 Old 07-26-2013, 12:11 PM Thread Starter
T-REXJ
Sorry Ive been in Southern Cali for a week, back now and ready to do some work to this beast, anyways:
I like how it looks up there and I cant really tell its up there for the most part haven't driven it far like that though but when I get a roof rack and new tires I will probably keep it up there
T-REXJ is offline
post #104 of 131 Old 07-28-2013, 02:35 PM
TABonifacio
1995 XJ Cherokee
Looks good without the fog lights!
1995 Jeep Cherokee SE Coupe, AX-15 5-Speed, 4.0L High Output Inline 6 Cylinder...Soon to be Road Worthy!
http://www.jeepforum.com/forum/f22/95-xj-se-1513890/
TABonifacio is offline
post #105 of 131 Old 08-06-2013, 12:59 AM
XJmike0122
Have not seen you around. The Jeep OK?
black , build , cherokee , xj
