Mikes '96 XJ Build - Page 6 - JeepForum.com
post #76 of 131 Old 07-10-2013, 02:46 PM
XJmike0122
Twin-tube Low Pressure Gas
A shock absorber or strut can be a low pressure gas, twin tube design. This basic design has not changed too much since the 60's, but there have been some refinements over the years. This design has some characteristics, such as a soft valving, and usually costs less to manufacture than a Monotube or Adjustable type shock absorber. They are usually pressurized with some Nitrogen gas, usually 100 psi or less. In this design the hydraulic oil and gas are mixed together in the same chamber, which, while dampening, causes some aeration/foaming. Monroe Auto Equipment, Bilstein, and KYB GR2 still make units like these.
Mono-tube High Pressure Gas
A shock absorber or strut can be a high pressure, mono tube design. These are a more modern type design, and have characteristics of their own. The monotube design allows them to operate cooler. Monotubes are under high pressure, from around 200 psi, to as high as 360 psi. The hydraulic oil and Nitrogen gas are in separate chambers, separated by a floating piston. This allows the shock/strut to function without any aeration or foaming. Monotube shocks usually have a stiff valving, and traditionally cost more to manufacture. They are also able to withstand more punishment, and offer higher dampening ability. (for instance, most racing shocks, from Nascar to Formula One, are of a monotube design). Great care and engineering is taken into consideration when manufacturing a monotube, and many have a very specific valving. This is years of racing technology adapted for street and off-road use. Some of the companies that make monotube shocks are Bilstein , Edelbrock, and KYB.
XJmike0122 is offline
post #77 of 131 Old 07-10-2013, 03:41 PM Thread Starter
T-REXJ
I know a lot of people don't like towing with there rigs, but I want to be able to tow my popup... In this case would a mono tube be better in the back since it is stiffer?
T-REXJ is offline
post #78 of 131 Old 07-10-2013, 05:20 PM
XJmike0122
If you can afford it check out something like the Rancho RS9000XL shocks they are adjustable so you would get the best of both worlds
post #79 of 131 Old 07-11-2013, 09:00 AM Thread Starter
T-REXJ
ya those would be awesome, a lil outta my range for now though, I think im gonna go for the monotube kit, so heres another newb question why do we use springs in the front and leafs in the back?
T-REXJ is offline
post #80 of 131 Old 07-11-2013, 09:12 AM
Puck81
Coil spring front. Leaf rear.
Puck81 is offline
post #81 of 131 Old 07-11-2013, 09:21 AM Thread Starter
T-REXJ
I know that I mean why not use a coild spring in the back?
T-REXJ is offline
post #82 of 131 Old 07-12-2013, 11:08 AM
XJmike0122
I tried to find a reason but came up with nothing. Maybe it was just cheaper?
post #83 of 131 Old 07-12-2013, 11:11 AM Thread Starter
T-REXJ
Lol thanks for lookin, hmm I wonder if that's possible to do coils and mono tube shocks in front and rear
T-REXJ is offline
post #84 of 131 Old 07-12-2013, 11:58 AM
XJmike0122
They make kits coil over kits for the rear of the xj just not cheap though
post #85 of 131 Old 07-12-2013, 12:06 PM Thread Starter
T-REXJ
ive been lookin at the RE 3.5" lift but not sure if im ready to go that far yet, maybe something like what you were thinkin about doin Xjmike to get started atleast
T-REXJ is offline
post #86 of 131 Old 07-12-2013, 12:15 PM Thread Starter
T-REXJ
I am also thinking about doing a few diy projects like these, not permanent necessarily but ive heard great things especially at lower speeds, like we do off roading.
Maybe something like this but more complete around the filter:
http://www.jeepforum.com/forum/f11/m...system-245583/
Or this sorta(scroll to second post)
http://www.jeepforum.com/forum/f46/x...-xj-xj-184475/
T-REXJ is offline
post #87 of 131 Old 07-12-2013, 12:57 PM
XJmike0122
I think I'm goin to see what will fit with a BB longer shocks and the those bushwacker flat flares. 32s or maybe 33s. If its 33s I'm going to be needind a different axle and new gears. I want to keep a low COG.
post #88 of 131 Old 07-12-2013, 12:59 PM
XJmike0122
Oh and those filter mods look like a good ides. I think I'm going to do the cowl snorkel mod.
post #89 of 131 Old 07-12-2013, 01:20 PM Thread Starter
T-REXJ
it wouldn't let me look at that mod for some reason, and ya for right now until some more work comes around I would like to keep it a low COG on 32's but I will probably change axle and gears anyways
T-REXJ is offline
post #90 of 131 Old 07-12-2013, 01:46 PM
XJmike0122
From what Puck was saying if you have a 29 spline 8.25 You should be good on the axle. Maybe just get some alloy shafts. Then you would have 2 spares and it would be a hell of a lot cheaper than even a 8.8 swap. Good chance you will break steering parts before those go. Me and (probably Toxic also) have the weakest dana 35. that's why I'm going to go with the 8.25. Probably never goin to be doing any extreme wheelin anyway.
black , build , cherokee , xj
