Metro's XJ Build - Page 19 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Metro's XJ Build
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 08-01-2013, 09:53 AM   #271
Metro55
Metro55's Avatar
Originally Posted by Luke95 View Post
I am so ****ing jealous of the old school mtrs that your running.
I've enjoyed them so far! They have worked great on the rocks for me
.,,_____,====,
//__l_l_,\____\,_____
l_,--\_l__l_/--|[]llllll[]|
,()_),,,,,,()_)--o-)_) Caged
Metro55 is offline   Reply With Quote Quick reply to this message
Unread 08-01-2013, 09:58 AM   #272
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
If my eyes dont deceive me I believe he is also running Kevlars on the other side.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 08-01-2013, 10:10 AM   #273
Metro55
Metro55's Avatar
I am running 1 new MTR Kevlar, because it came with the set of 4 that i bought for only $300, and they all have tons of tread left. I can deal with it, until I spent over a $1000 on a new set of 33's
.,,_____,====,
Unread 08-01-2013, 10:11 AM   #274
Spokes
Originally Posted by Metro55 View Post
Thanks.. yup, the front is next.. Ran out of time/sunlight and still deciding how much I want to trim in the front.
i just followed the upper line of the fender when i did mine. dont know if this helps ya
Red 00 XJ lifted
Build -->http://www.jeepforum.com/forum/f177/...hread-1280981/
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline   Reply With Quote Quick reply to this message
Unread 08-01-2013, 10:14 AM   #275
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Ohhh I gotcha. I wasnt hatin, just happened to notice. Ive snagged my fair share of craigslist mix n match deals, at least yours all match brands. I would have snatched those up for 300 bucks too.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 08-01-2013, 10:21 AM   #276
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
I left the lip on mine to keep a little (little being key word) rigidity in the fender, and to match the lip on rear. Like it just fine, no rubbing at full stuff.
Example shot:
Not really sure if that helps, you're seasoned enough in the XJ world to have seen a hundred trim jobs, just gotta choose one haha.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 08-01-2013, 11:55 AM   #277
Metro55
Metro55's Avatar
Example shot:
Thanks for that pic.. I feel like I may want to go a bit higher... Where did you get that black trim?
.,,_____,====,
Unread 08-01-2013, 12:08 PM   #278
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Its just door edge trim, picked it up from Autozone I believe. Finishes the look of it nicely and keeps tires from getting cut up should the two ever meet.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 08-01-2013, 12:19 PM   #279
Metro55
Metro55's Avatar
Did you use any adhesive or anything like that?
.,,_____,====,
Unread 08-01-2013, 12:55 PM   #280
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
It has adhesive in the trim, stayed on great for about 3 months and 2 big weekend wheeling trips and then it started to come loose a bit around the curves so I put a drop of hobby grade CA glue in the corners. Still holding great.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 08-09-2013, 09:50 AM   #281
Metro55
Metro55's Avatar
Boxed in my upper control arm bracket and welded on HD lower control arm brackets on my HP D30
.,,_____,====,
Unread 08-09-2013, 05:03 PM   #282
Metro55
Metro55's Avatar
Trimmed my front fenders this afternoon... I like it
.,,_____,====,
Unread 08-11-2013, 07:08 PM   #283
tofuzeppelin
tofuzeppelin's Avatar
Like your cap man, we always joke bout starting surgery when the green n white goes on. Pretty solid welds tho, what kind of set up you running welding wize n still goin for notch's flairs? Kinda lookin forward to seeing them on this forum.
01 TJ with some stuff
77 SJ Cruzer
Lifes to short for bad coffee and bald tires
tofuzeppelin is offline   Reply With Quote Quick reply to this message
Unread 08-14-2013, 08:54 PM   #284
Metro55
Metro55's Avatar
Finished up my rear fender trimming. Had to trim my 1/4" steel bumper quarter panel pieces to get to the remaining fender. I used the first piece I cut off from the first side then flipped it to ensure I had the same arch on both sides. Looks much better now.
.,,_____,====,
Unread 08-18-2013, 03:04 PM   #285
Metro55
Metro55's Avatar
Wheeled in Rennie this weekend. Jeep did great as per usual
.,,_____,====,
