Metro's XJ Build - Page 19 - JeepForum.com
post #271 of 437 Old 08-01-2013, 08:53 AM Thread Starter
Metro55
Originally Posted by Luke95 View Post
I am so ****ing jealous of the old school mtrs that your running.
I've enjoyed them so far! They have worked great on the rocks for me
.,,_____,====,
//__l_l_,\____\,_____
l_,--\_l__l_/--|[]llllll[]|
,(•)_),,,,,,(•)_)--o-)_) Caged
Metro55 is offline
post #272 of 437 Old 08-01-2013, 08:58 AM
VegasGT
1988 MJ Comanche
If my eyes dont deceive me I believe he is also running Kevlars on the other side.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #273 of 437 Old 08-01-2013, 09:10 AM Thread Starter
Metro55
I am running 1 new MTR Kevlar, because it came with the set of 4 that i bought for only $300, and they all have tons of tread left. I can deal with it, until I spent over a $1000 on a new set of 33's
.,,_____,====,
Metro55 is offline
post #274 of 437 Old 08-01-2013, 09:11 AM
Spokes
Originally Posted by Metro55 View Post
Thanks.. yup, the front is next.. Ran out of time/sunlight and still deciding how much I want to trim in the front.
i just followed the upper line of the fender when i did mine. dont know if this helps ya
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #275 of 437 Old 08-01-2013, 09:14 AM
VegasGT
1988 MJ Comanche
Ohhh I gotcha. I wasnt hatin, just happened to notice. Ive snagged my fair share of craigslist mix n match deals, at least yours all match brands. I would have snatched those up for 300 bucks too.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #276 of 437 Old 08-01-2013, 09:21 AM
VegasGT
1988 MJ Comanche
I left the lip on mine to keep a little (little being key word) rigidity in the fender, and to match the lip on rear. Like it just fine, no rubbing at full stuff.
Example shot:
Not really sure if that helps, you're seasoned enough in the XJ world to have seen a hundred trim jobs, just gotta choose one haha.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #277 of 437 Old 08-01-2013, 10:55 AM Thread Starter
Metro55
Example shot:
Thanks for that pic.. I feel like I may want to go a bit higher... Where did you get that black trim?
.,,_____,====,
Metro55 is offline
post #278 of 437 Old 08-01-2013, 11:08 AM
VegasGT
1988 MJ Comanche
Its just door edge trim, picked it up from Autozone I believe. Finishes the look of it nicely and keeps tires from getting cut up should the two ever meet.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #279 of 437 Old 08-01-2013, 11:19 AM Thread Starter
Metro55
Did you use any adhesive or anything like that?
.,,_____,====,
Metro55 is offline
post #280 of 437 Old 08-01-2013, 11:55 AM
VegasGT
1988 MJ Comanche
It has adhesive in the trim, stayed on great for about 3 months and 2 big weekend wheeling trips and then it started to come loose a bit around the curves so I put a drop of hobby grade CA glue in the corners. Still holding great.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #281 of 437 Old 08-09-2013, 08:50 AM Thread Starter
Metro55
Boxed in my upper control arm bracket and welded on HD lower control arm brackets on my HP D30
.,,_____,====,
Metro55 is offline
post #282 of 437 Old 08-09-2013, 04:03 PM Thread Starter
Metro55
Trimmed my front fenders this afternoon... I like it
.,,_____,====,
Metro55 is offline
post #283 of 437 Old 08-11-2013, 06:08 PM
tofuzeppelin
tofuzeppelin's Avatar
Like your cap man, we always joke bout starting surgery when the green n white goes on. Pretty solid welds tho, what kind of set up you running welding wize n still goin for notch's flairs? Kinda lookin forward to seeing them on this forum.
01 TJ with some stuff
77 SJ Cruzer
Lifes to short for bad coffee and bald tires
tofuzeppelin is offline
post #284 of 437 Old 08-14-2013, 07:54 PM Thread Starter
Metro55
Finished up my rear fender trimming. Had to trim my 1/4" steel bumper quarter panel pieces to get to the remaining fender. I used the first piece I cut off from the first side then flipped it to ensure I had the same arch on both sides. Looks much better now.
.,,_____,====,
Metro55 is offline
post #285 of 437 Old 08-18-2013, 02:04 PM Thread Starter
Metro55
Wheeled in Rennie this weekend. Jeep did great as per usual
.,,_____,====,
Metro55 is offline
The Trev-Rock Build....noobie build.. Trev-Rock XJ/MJ Cherokee Non-Technical Forum 1 03-20-2012 01:50 PM
My 98 XJ build Beowill XJ Cherokee Technical Forum 61 05-07-2011 03:06 PM
I need your opinions. Build the one I have or buy a newer one to build up. Element96x XJ/MJ Cherokee Non-Technical Forum 5 02-13-2009 03:52 PM
Build up the D30? 00xj54 XJ Cherokee Technical Forum 18 10-18-2006 03:34 PM
