Metro's XJ Build - Page 11 - JeepForum.com
post #151 of 437 Old 10-03-2012, 10:32 PM Thread Starter
Metro55
Originally Posted by DezertXj88 View Post
Those u bolts vs the straps are an amazing CHEAP mod! Should be 1 of the firsts for everyone! You can drill yokes on the jeep no worries. Cordless drills help but go slow and steady.
Correct me on the price but the "kit" is 8 bucks right? You have a great looking jeep btw..any more pics on the mini truss?
The kit was $6.99 per u-bolt so about $15 after tax, which is still worth it. The front D30 yoke is different though and u-bolts do not fit (the nut won't thread on, there is not enough room)
My mini truss has not been welded on yet. I'll probably get that done in the next week or so, provided I have enough room when it is flexed. But I should.
.,,_____,====,
//__l_l_,\____\,_____
l_,--\_l__l_/--|[]llllll[]|
,()_),,,,,,()_)--o-)_) Caged
Metro55 is offline
post #152 of 437 Old 10-05-2012, 10:18 PM
XJ Jay
Thanks for the upgrade idea Chris, cheap and easy, can't wait to put em to use in Moab. I used a precision 534-10 straps for those needing an alternative to the 81004 unit.
HISWhite 99 XJ Sport
5" RC/ProComp lift, Serious long arms, 33" Cooper STTs, Soft 8s, 4.56s, Aussie locked D30, LSD 8.25,discos, armoured blah blah blah, HP44/9" coming soon
HERSBlack 08 JK Unlimited X, Teraflex 1.5" leveling kit, Rubi coils 35" TSRs and 5.13s
XJ Jay is offline
post #153 of 437 Old 10-12-2012, 09:21 AM Thread Starter
Metro55
So, about a 1.5 years ago, Full Tilt Poker (online poker) website was closed and all players funds were frozen. They are now relaunching as of November 6th, and I will have access to my funds/winnings, which is a decent chunk of change. With this, I have some plans and orders in the works...
- Long Arm Upgrade
- 33" Interco Trxus MT's
- Aussie Rear Locker
- 4.88 gears
- Transmission Mount
- Spring Retainer Clips
- New Speakers
As great as this is... It's really too bad that these funds are becoming available ONE week after I will be returning from MOAB
.,,_____,====,
Metro55 is offline
post #154 of 437 Old 10-13-2012, 09:06 PM
XJ Jay
Yaahhhhhh
XJ Jay is offline
post #155 of 437 Old 11-08-2012, 11:47 AM Thread Starter
Metro55
Just made an order today for a few things:
- Rough Country Long Arm Upgrade
- Extended Front Brake Lines
- Tranny Cooler
- Transmission Temp Guage (Glowshift Tinted 7 colour)
- 1/4" LCA Brackets
- HD Coil retainers
Next Order will be:
- 33" Trxus MT's
- 4.88 Gears
- Flat Fenders
.,,_____,====,
Metro55 is offline
post #156 of 437 Old 11-08-2012, 11:59 PM Thread Starter
Metro55
Got some time in a buddies shop tonight so I did a couple things I wanted to get down while I had a welder on hand
Cut the mounting plate off my tire carrier and then angle cut the stock to 20 degrees to match the hatch
Then I wanted to tuck my rear shock mounts up, so I chopped them off and welded them higher
.,,_____,====,
Metro55 is offline
post #157 of 437 Old 11-15-2012, 06:56 AM Thread Starter
Metro55
Picking up my long arms tomorrow, and installing them this weekend! Also picking up a few other goodies!
.,,_____,====,
Metro55 is offline
post #158 of 437 Old 11-16-2012, 01:57 PM Thread Starter
Metro55
Grabbed my long arms from the border this morning and some other goodies
.,,_____,====,
Metro55 is offline
post #159 of 437 Old 11-16-2012, 07:08 PM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
I'm excited to see those go on.
April 2014 & 2015 COTM
MOBBiN is offline
post #160 of 437 Old 11-23-2012, 09:28 AM Thread Starter
Metro55
Well I spent the evening at a friends shop putting my long arms in. The install really isn't bad at all, but we did have a JEEP FIRE, when we were torching off the stock control arm brackets and the fuel line ruptured. We had 2 fire extinguishers within 5 seconds between 3 people, and everything seems to have been saved. We then continued with the install and got it done, just need to do a few small things today and then get an alignment.
Tranny mount with 2 broken studs and both mount bolts were loose. That's were my vibes were
Torching off stock control arms mounts
Post fire, checking everything out (notice the powder on the ground)
Ruptured fuel line
INSTALLED
.,,_____,====,
Metro55 is offline
post #161 of 437 Old 11-23-2012, 09:31 AM
PhotoJared
Congrats. I have a buddy that had quite a bit locked up because of that ordeal.
'99 XJ Sport
It has a lift
It has 31's
It also other stuff
PhotoJared is offline
post #162 of 437 Old 11-24-2012, 11:20 AM Thread Starter
Metro55
Fixed my fuel line and took it for a drive. It rides very nice and feels a lot more solid. I am happy so far with this upgrade!
.,,_____,====,
Metro55 is offline
post #163 of 437 Old 11-24-2012, 03:57 PM Thread Starter
Metro55
Just picked up a tranny cooler (11x7.5) to go with my GlowShift Tranny Temp Gauge
.,,_____,====,
Metro55 is offline
post #164 of 437 Old 11-24-2012, 05:18 PM
GtiKyle
Nice work on the shock mount tuck. Might be borrowing that. Keep up the good work
1998 Cherokee, 6.5" LA, D30/C8.25 4.56 locked F/R, 35" MTR's, other goodies ...
Build thread :
GtiKyle is offline
post #165 of 437 Old 11-25-2012, 06:54 PM Thread Starter
Metro55
Thanks man, it is coming along slowly but surely
.,,_____,====,
Metro55 is offline
The Trev-Rock Build....noobie build.. Trev-Rock XJ/MJ Cherokee Non-Technical Forum 1 03-20-2012 01:50 PM
My 98 XJ build Beowill XJ Cherokee Technical Forum 61 05-07-2011 03:06 PM
I need your opinions. Build the one I have or buy a newer one to build up. Element96x XJ/MJ Cherokee Non-Technical Forum 5 02-13-2009 03:52 PM
Build up the D30? 00xj54 XJ Cherokee Technical Forum 18 10-18-2006 03:34 PM
