In the market - what to look for? - JeepForum.com
post #1 of 5 Old 09-04-2013, 12:20 PM Thread Starter
joshisme
Hey guys,
I'm looking for an XJ and I am just looking for some recommendations for things to look for.
I wish i would have read these forums before buying my YJ because i had some hidden rust in problem areas that i could have easily avoided, and I'm hoping for some similar suggestions.
Any common problem areas, or preferred years/parts that i should be looking for?
Thanks in advance
joshisme is offline
post #2 of 5 Old 09-04-2013, 12:39 PM
gs69350
Among the usual things, check the flat section of the floors from underneath for rust. When I checked mine out, I was more concerned with the frame areas and where the suspension mounts and I totally missed that I was looking at the bottom of the carpet, not sheet metal.
1998 Jeep Grand Cherokee 5.9 Limited - Stone White - Stock for now.
<-- 5.9 Owner's group on FB.
gs69350 is offline
post #3 of 5 Old 09-04-2013, 12:42 PM
psychoteen101
Rust is the main thing to look for. Floors and rocker panels are the first to go. Pay attention to that before anything else. the motors/transmissions are pretty solid. Just make sure they have been properly maintained. Test drive for sure and if possible, bring it to a shop and have it inspected before you buy it to make sure its mechanically sound
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #4 of 5 Old 09-04-2013, 12:49 PM Thread Starter
joshisme
Thanks guys, I will be sure to give it a thorough rust inspection. I've seen a few cherokees listed around here with only about 100k miles and i am going to try to snag one of those.
There are quite a few listed with 175k+ miles but I am a little wary of that, though i have heard these engines last forever.
joshisme is offline
post #5 of 5 Old 09-04-2013, 01:09 PM
gs69350
I bought mine with 223k, aside from the floors, everything was in great shape.
Drive it, use your judgement. I try and let vehicles that I might buy run for a while at idle, I want them nice and hot to make sure they aren't overheating, its easy to miss if you hurry the inspection process.
gs69350 is offline
