making new gauges for newer XJs (and anything else that runs a 4.0 after 97) - Page 9 - JeepForum.com
post #121 of 414 Old 01-29-2013, 04:03 PM
SpakeXJ
These are awesome!!!
SpakeXJ is offline
post #122 of 414 Old 01-29-2013, 04:35 PM Thread Starter
Azzy
Originally Posted by KG8893 View Post
What you need to figure out I guess is first which pins go to which needles and then figure out whether they run off of amperage gain wattage gain or voltage gain. Then figure out whether you can find a way to make a machine that does the same (I would assume that a dimmer switch may work???)
I may be able to get you an ECU on the cheap but I'll have to see about that one.
REALLY REALLY liking the carbon fiber (or whatever it is) pattern. It's just that final touch you needed. Now I am DEFINITELY in for getting one. Can't wait to see what other patterns you come out with
Thanks guys!
The graphics shop is backordered, and I have a plan to combat the issues with the ghosting, which in order to look somewhat factory, will just need to have 2 extra layers. that should do it... the stock lighting is stronger than I expected. If going LED or otherwise, people may need to use less layers, but it is twice the material I expected on these, and a bit more printing.
Thus is why we try and try before getting them out, right?
Ive got a few people in mind who have helped with these from early on that I would like to participate in my first test run, hopefully in the first week of Feb. Look for a PM as I get my notes together.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #123 of 414 Old 01-29-2013, 05:42 PM
moses21
Originally Posted by Azzy View Post
Thanks guys!
So if you have leds can you just pull some layers off or is it more complicated then that.
moses21 is offline
post #124 of 414 Old 01-30-2013, 05:23 AM Thread Starter
Azzy
I think it will depend on the LED setup. if the LEDs are like the ones I had (pretty dim, and eventually destroyed by my dimmer) it will just be a matter of pulling off a layer, which would need to be tried for personal preference before the needles are put back in.
Azzy is offline
post #125 of 414 Old 01-30-2013, 08:01 AM
KG8893
Thanks guys!
jut like an extra 2 sheets of black for shading? couldn't that be done with a much cheaper material to save cost? and be easier on the cutter...
I noticed the ghosting but I thought maybe it was just the camera. Dont LEDs put out more light?
I'm not saying we should kill stupid people... Just get rid of all the warning labels...
If you find my comments to "infer" something, they don't. Go to hell.
Built Not Bought #666
KG8893 is offline
post #126 of 414 Old 01-31-2013, 06:51 AM Thread Starter
Azzy
Its not so much to block light, but to soften the light that does come through the white parts. If you look at the pictures above, there are strange shadows where you can see the internal reflections of the plastic they use for support and to refract light to under the needles. I dont think it will change the pricing point much, if at all, because the layers I think can be used from pieces that are scrapped anyhow. (36" sheet, 12" max cut area for alignment purposes right now)
Waste not, want not, right?
Azzy is offline
post #127 of 414 Old 01-31-2013, 06:53 AM
KG8893
So really... you will be saving money. Thats how you do it!
KG8893 is offline
post #128 of 414 Old 01-31-2013, 09:06 AM
DNFJ
If I get my LED bulbs in the mail anytime soon we could test it out considering you're what, 45 minutes from me?
Doubt I'll get them within the week though, stupid chinese shipping.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #129 of 414 Old 01-31-2013, 09:43 AM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
Would you be apposed to doing a write-up on how to disassemble then reassemble the cluster? Do the gauge needles need to be calibrated or are they notched at a specific location
April 2014 & 2015 COTM
MOBBiN is offline
post #130 of 414 Old 01-31-2013, 09:57 AM Thread Starter
Azzy
See what we can do, I bet the bulbs will be here before then.
Unfortunately not notched. Ive seen a good install video for an indiglow type aftermarket mask that I will be borrowing some cues from. I would say not as easy as installing new tires like the pre-97s, more like installing a SYE. Doable at home, but not super easy.
Azzy is offline
post #131 of 414 Old 02-02-2013, 04:15 PM
KG8893
This is completely unrelated, but I think on the "explode offroad" sticker you should put the XJ grill slats and the turn signals under the headlights in white... or sell one of all kinds of jeeps.
KG8893 is offline
post #132 of 414 Old 02-04-2013, 01:53 PM Thread Starter
Azzy
Noted!
Anywho...
Just got off the phone with my contact at Accugraphics. He has a sample print in hand, and will be emailing me photos of the precision tomorrow. If all goes well, its ordering time for the machine, and should not take long to get my setup calibrated to work with it.
Its making me a bit giddy
Ive also thought about the requests for the face plates for AC controls I had in the past. With the new machine and material, that should be doable now. I'll just have to find a 97+ and a pre97 unit to make demo models from.
Azzy is offline
post #133 of 414 Old 02-04-2013, 02:22 PM
moses21
Noted!
Anywho...
I'm getting way to excited for these ha. I you need to hurry up and make them!
moses21 is offline
post #134 of 414 Old 02-04-2013, 02:58 PM Thread Starter
Azzy
trust me, I would love to have them out the door! My wife noted last night that Ive got 5 jobs at the moment, and only 1 and a half are paying
Azzy is offline
post #135 of 414 Old 02-04-2013, 03:59 PM
moses21
Well I'm sure she won't be complaining when there all paying!
moses21 is offline
New to Jeepin: Bought 89 Cherokee, it starts and runs but runs rough and stalls in D stockli XJ Cherokee Technical Forum 7 04-29-2013 08:48 PM
(1997) How would I convert idiot light gauges to needle gauges? xjse XJ Cherokee Technical Forum 18 02-11-2013 09:21 AM
runs great cold but when warm it runs bad. flaneryjunior99 XJ Cherokee Technical Forum 4 07-09-2011 05:29 PM
gauges, SE to full gauges (tach, oil,temp, etc Xjay96 XJ Cherokee Technical Forum 2 02-08-2010 12:00 PM
looking to buy a newer XJ MiZZ XJ Cherokee Technical Forum 27 01-22-2007 07:51 PM
