making new gauges for newer XJs (and anything else that runs a 4.0 after 97) - Page 8 - JeepForum.com
post #106 of 414 Old 01-21-2013, 11:38 PM Thread Starter
Azzy
Getting closer.... Yes, the speedo (and a few others) needs moved over just a hair. This was the 3rd cut and I only adjusted for where the holes are, not for the print, that I can do tomorrow.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #107 of 414 Old 01-22-2013, 03:22 PM
KG8893
They look kick *** man. Keep it up.
Sent from under my Jeep.
I'm not saying we should kill stupid people... Just get rid of all the warning labels...
If you find my comments to "infer" something, they don't. Go to hell.
Built Not Bought #666
KG8893 is offline
post #108 of 414 Old 01-22-2013, 04:14 PM
jimmy21669
So ready for mine when you get it dialed in.
jimmy21669 is offline
post #109 of 414 Old 01-28-2013, 11:07 AM
CloakedLJ
Wow these look awesome. When the TJ ones are ready I will order a set for sure!
CloakedLJ is offline
post #110 of 414 Old 01-28-2013, 03:19 PM Thread Starter
Azzy
Progress!
Ive got the cut template adjusted. Got the prints adjusted, and a set of those is coming out of the printer right now:
Sent off some files to the good folks at Accugraphics to test on of their machines, and if all goes according to plan, I'll empty out my bank account (filled from sales of my other gauges) and then buy one of their spiffy cutters. Nothing is done on credit folks, its all about saving and making... and then investing to save and make some more.
Azzy is offline
post #111 of 414 Old 01-28-2013, 04:24 PM
Project1
I'm putting my 2 cents in here .... I want my check engine light to be a " $ " and change the light to green!!! and count me in!!
Project1 is offline
post #112 of 414 Old 01-28-2013, 04:37 PM
Jbat
I would really like a cluster that is the same color as my jeep. If you could do that, I would buy one yesterday. I have a 97 Grand Cherokee Leredo. In the factory purple
Jbat is offline
post #113 of 414 Old 01-28-2013, 06:17 PM Thread Starter
Azzy
Color matching would be interesting... but a tad bit difficult. To really get close I would need a paint sample at best, or a really good photo.
Azzy is offline
post #114 of 414 Old 01-28-2013, 06:28 PM Thread Starter
Azzy
Asked the question over here, but it doent get much traffic over there.
http://www.jeepforum.com/forum/f20/s...-them-1470412/
Is there a place that I can find sensor output values (like the temp sensor runs 200-300 ohms) and what sort of signal needs to go to the tach and speedo?
I am building up a test and calibration setup for my new gauge kits (thread on that here), and would like to be able to tell the things to sit dead center and be able to move a pot or 1 and run through the range of motion so I can not only test the cluster, but make sure the needles are in the right places.
Azzy is offline
post #115 of 414 Old 01-28-2013, 07:50 PM
KG8893
I know it would be pretty crude... But have you thought to splice the wires behind and see with a multimeter?
KG8893 is offline
post #116 of 414 Old 01-28-2013, 08:30 PM Thread Starter
Azzy
Check engine light color is set to what it is set to. There is a special diffuser lens that needs to be removed / modified that sits behind the faceplate.
Yes. Right now, dont have the pigtails to be able to do that. What I have found is that a TJ pinout is different (although same cluster) than an XJ, and the idiot light versions are different too. No luck so far, although I can get the idiot light cluster to go though a diagnostic, but no luck with the needles. I fear I need an ECU to be able to run the full diagnostic test for the cluster. That is a bit out of my price range. And I dont want to hit the wrong wires with a multimeter attached to the wife's XJ and blow something expensive.
Right now I am working out an issue with the overall backlighting. It looks fantastic, but the diffusion of the colors is not as nice as I would like them. A small hurdle, I am sure.
Sample being cut as I type, picture coming shortly.
Azzy is offline
post #117 of 414 Old 01-28-2013, 08:57 PM Thread Starter
Azzy
Dark shots, taken in my office, hooked up to a power supply.
Naked:
Stock:
Layer 1:
Layer 2:
Surround:
Lens (kinda dusty):
And here you can see why they arent lined up just right and why I sent of a cut sample this morning... ugg. To cut this material right, it takes 4 light cuts, right on top of each other. Sometimes it works, most times it does this. Sucks, because there is material and printing down the drain New machine we are looking at can do it in 1 pass.
Azzy is offline
post #118 of 414 Old 01-28-2013, 10:11 PM
donthelegend
Have you tried NAXJA? I generally find more in-depth tech over there...
Gauges are looking good! Can't wait for them to be available.
donthelegend is offline
post #119 of 414 Old 01-28-2013, 10:13 PM
ibjeepin95
Originally Posted by donthelegend
Have you tried NAXJA? I generally find tech over there....
Lawl, fixed it for ya...
ibjeepin95 is offline
post #120 of 414 Old 01-28-2013, 10:19 PM
KG8893
What you need to figure out I guess is first which pins go to which needles and then figure out whether they run off of amperage gain wattage gain or voltage gain. Then figure out whether you can find a way to make a machine that does the same (I would assume that a dimmer switch may work???)
I may be able to get you an ECU on the cheap but I'll have to see about that one.
Layer 2:
REALLY REALLY liking the carbon fiber (or whatever it is) pattern. It's just that final touch you needed. Now I am DEFINITELY in for getting one. Can't wait to see what other patterns you come out with
KG8893 is offline
New to Jeepin: Bought 89 Cherokee, it starts and runs but runs rough and stalls in D stockli XJ Cherokee Technical Forum 7 04-29-2013 08:48 PM
(1997) How would I convert idiot light gauges to needle gauges? xjse XJ Cherokee Technical Forum 18 02-11-2013 09:21 AM
runs great cold but when warm it runs bad. flaneryjunior99 XJ Cherokee Technical Forum 4 07-09-2011 05:29 PM
gauges, SE to full gauges (tach, oil,temp, etc Xjay96 XJ Cherokee Technical Forum 2 02-08-2010 12:00 PM
looking to buy a newer XJ MiZZ XJ Cherokee Technical Forum 27 01-22-2007 07:51 PM
