Making My Magnaflow Louder? - JeepForum.com
post #1 of 12 Old 10-16-2013, 07:29 AM Thread Starter
Cherokeekid88
1997 XJ Cherokee
I have had my Magnaflow muffler and exhaust redone to 2.5" from the header back for about a year now. My system sounds good at higher RPM's I just wish it had a bit more of a rumble at idle and at lower RPM's. I know that I have heard some magnaflow mufflers on some jeeps and they seem louder. I have the shortest oval case that you can get. Im really an exhaust fanatic, and I really like to hear my jeep in the mornings when I am letting it warm up (sounds childish, I know but it makes me happy) Any ideas on how I can get it to be a bit louder?
Currently I have 2.5" piping from the header to the muffler, Hi flow cat, 2.5" piping from the the muffler to the tip, the tip is a 2.5" inlet and 3" outlet and ends right before my rear shackle for my leaf springs.
97 XJ 4.0 Auto D30/29 Sp. 8.25. Yukon 4.10's
4.5" IRO Long Arm Kit - 33x12.50x15's
HD Offroad Engineering Shackle Relocation Brackets
Bilstein 5100's - Magnaflow Exhaust.
Cherokeekid88 is offline
post #2 of 12 Old 10-16-2013, 10:16 AM
PaYankee
Cut the muffler off?
99 xj 2wd/94xj 4wd np231 3lift
PaYankee is offline
post #3 of 12 Old 10-16-2013, 10:17 AM Thread Starter
Cherokeekid88
1997 XJ Cherokee
post #4 of 12 Old 10-16-2013, 04:20 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Run a 4" round body magnaflow muffler. They are more aggressive. That's what I run. You can hear mine in the exhaust sound clip thread that's a sticky at the top mine is the first video
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #5 of 12 Old 10-16-2013, 06:23 PM
Motorcharge
Stick it to the man and ___ the ________.
*We are not on CF this can not be talked about here Mmmmkay ! <3 Tom95YJ
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #6 of 12 Old 10-17-2013, 08:55 AM Thread Starter
Cherokeekid88
1997 XJ Cherokee
I'd rather now run one of these...I ran a similar style from Dynomax (the bullet)
and it was too raspy.
Was thinking if I get a longer tip...stainless tip, might make the tone a bit better.
post #7 of 12 Old 10-17-2013, 10:17 AM
jeepkid03
Winning
jeepkid03's Avatar
A turn down after the muffler will make it deeper. I have found turn downs in general make the exhaust deeper since the sound bounces off the ground.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #8 of 12 Old 10-17-2013, 10:49 AM Thread Starter
Cherokeekid88
1997 XJ Cherokee
Thought about this....just don't want to add any more vibrations to my jeep than it already has.... hmmmm thinking about making it exit out the side somehow....
post #9 of 12 Old 10-17-2013, 12:42 PM
Tom95YJ
Tom95YJ's Avatar
Originally Posted by Cherokeekid88
I'd rather now run one of these...I ran a similar style from Dynomax (the bullet) and it was too raspy. Was thinking if I get a longer tip...stainless tip, might make the tone a bit better.
A longer tip won't do anything, If you want to make it louder and stick with a oval muffler get one with a shorter body then offset the length difference with 2.5" pipe
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #10 of 12 Old 10-17-2013, 02:14 PM Thread Starter
Cherokeekid88
1997 XJ Cherokee
Longer tip will change the tone of the exhaust. right now. I am using a VERY short stainless double rolled tip, so adding more tip for it to go through, it will change the exhaust note. won't make it louder, just change the tone.
Also, I have the shortest oval muffler they make.
post #11 of 12 Old 10-17-2013, 03:08 PM
Tom95YJ
Tom95YJ's Avatar
You may want to get a header then
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #12 of 12 Old 10-17-2013, 07:59 PM
Motorcharge
If I'm on mobile I can assume he's not in the US since I can't see his location and it's not illegal and thus doesn't break any JF rules.
|SOLD|
| June 2015 COTM |
