Lquid industries sliders - JeepForum.com
post #1 of 26 Old 01-16-2012, 11:40 PM Thread Starter
Empty_Pockets
Has anyone used lquid industries sliders? Need some reviews Im thinking of using them on my xj once I out the 6.5in leaf pack in
1998 Cherokee 2 door 2.5L 5 speed
2000 Cherokee Sport 4.5in lift 33's (Sold)
1998 Cherokee Sport ORF bumper, Warn vr12, 6.5in long arm ended up netting 8-9in :( (SOLD)
Empty_Pockets is offline
post #2 of 26 Old 01-16-2012, 11:50 PM
XJcruiser
The look interesting, but it seems like they would limit down travel even more than a shackle would. I bet they would be great on the road and in high speed desert type stuff but not so much for articulation.
Friends dont let friends do DUBS.
XJcruiser is offline
post #3 of 26 Old 01-16-2012, 11:51 PM
chriskeenan
a few here have used them, they seem to be more popular on NAXJA, i haven't read anything bad about them during normal use, the racers/prerunners dont seem to like them though, due to the UHMW bushings being destroyed quickly in competition use.
chriskeenan is offline
post #4 of 26 Old 01-17-2012, 09:58 AM
donthelegend
I believe RoyalXJ was running them, he had some flex shots posted someplace. They looked like they gave more downtravel than most shackle setups. Definitely better than running a vertical shackle anyway.
donthelegend is offline
post #5 of 26 Old 01-17-2012, 10:09 AM
Timo_90xj
Timo_90xj's Avatar
Consider what kind of an arch the shackle makes during leaf travel, and how long is that arc?
LIIs sliders actually have quite a lot of available travel built into them, and IIRC the way they arre built makes the spring rate slightly progressive towards end of travel. The design IMO seems great and judging by the pics I've seen they are very well built. Like was mentioned downside I've heard is the bushing wear on heavy use. But under heavy use leaf/ shackle bushings wear out just as well.
***Under construction***
Timo_90xj is offline
post #6 of 26 Old 02-14-2012, 01:28 PM
dcorn
I've had a set in the garage for months, just need to find time to put them on. In theory, they look like they'll articulate really well and also provide a very smooth ride on the road or in fast bumps.
HeavyMetal has run them for quite a while.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #7 of 26 Old 02-14-2012, 07:39 PM Thread Starter
Empty_Pockets
I got a used set off of cherokeeforum, they will be going on with my lift very soon.
post #8 of 26 Old 02-14-2012, 10:37 PM
AeroSync
I have them with RE 3.5" springs.
I drive an Orange.
AeroSync is offline
post #9 of 26 Old 02-15-2012, 05:55 AM Thread Starter
Empty_Pockets
Do they affect the height at all or do they sit at 3.5in?
post #10 of 26 Old 02-15-2012, 07:06 PM
AeroSync
It went up like half an inch but I took 2 leafs out so now it sits level and is even smoother than the front. RE leafs are too stiff IMO.
I drive an Orange.
AeroSync is offline
post #11 of 26 Old 02-15-2012, 07:11 PM Thread Starter
Empty_Pockets
Cool thanks can't wait to install mine!
post #12 of 26 Old 02-15-2012, 11:31 PM
lilnapsak
1997 XJ Cherokee
i run them. alot more stable than a shackle.
lilnapsak is offline
post #13 of 26 Old 02-16-2012, 10:06 AM
PiKapp504
1997 XJ Cherokee
These look very interesting... Do they interfere w/ the stock bumper? Can these be installed with a hitch already mounted?
Jeremy
97 XJ - 4.0L, Auto, NP231, Zone 3" lift, 30" tires
2005 Dodge Magnum RT - DD/Beater
PiKapp504 is offline
post #14 of 26 Old 02-16-2012, 10:16 AM
lilnapsak
1997 XJ Cherokee
Yes you will need to trim your stock bumper slightly, and the hitch would need to go on after sliders are installed.
Ill post pics of both later.
post #15 of 26 Old 02-16-2012, 10:18 AM
PiKapp504
1997 XJ Cherokee
That's what I figured; the "tail piece" of those sliders look to be right where the bumper goes. And I was thinking the hitch would go on after these brackets (longer bolts too), but just wanted to clarify. Looks interesting! I wonder what the life of the slider is (i.e. daily driver w/ some weekend wheeling thrown in)...
Jeremy
sliders 7urtle XJ/MJ Cherokee Non-Technical Forum 3 05-15-2011 12:12 PM
sliders zte87 XJ Cherokee Technical Forum 1 10-27-2010 07:05 PM
RCX sliders 91xjgawes XJ/MJ Cherokee Non-Technical Forum 26 12-23-2008 02:01 PM
New sliders done! the303hooligan XJ/MJ Cherokee Non-Technical Forum 6 11-03-2008 08:51 AM
anyone running brown dog industries mounts njoyjeepin XJ Cherokee Technical Forum 6 03-08-2008 05:00 PM
