Low washer fluid light - JeepForum.com
post #1 of 5 Old 07-09-2013, 10:07 PM Thread Starter
witchdoctor7710
My low washer fluid light has been turning on and off for a little bit. What could this be? nothing else seems to be wrong.
"I have been to the dark side.....their cookies are horrible"
witchdoctor7710 is offline
post #2 of 5 Old 07-09-2013, 11:41 PM
M35A2
1995 XJ Cherokee
The float is probably waterlogged. You can make a new one with a chunk of styrofoam or go to the hy and find a foamed vehicle. After the float dries out again, they float better.
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
post #3 of 5 Old 07-09-2013, 11:43 PM
jbudz511
Usually means low washer fluid lol...it's hard to check your level in I think 99 or 98+ because the fill bottle is in between the engine bay and the fender. Mine comes on and off when it's about low and I'm driving with a lot if hills. Top her off you should be fine...
jbudz511 is offline
post #4 of 5 Old 07-10-2013, 05:09 AM
mschi772
1997 XJ Cherokee
Yeah, it's probably just blinking on and off because the fluid is sloshing around in there. The float's movement isn't dampened, so it'll flop up and and down very easily as the level changes.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #5 of 5 Old 07-10-2013, 06:56 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
On my 96 the light starts coming on when the reservoir gets to a little less than half full, which means I only have about a 6 month supply left in there. Not sure about the later models but on mine it was really easy to unplug the sensor connection from the bottle and put an end to that nonsense.
***Chris***
chris87xj is online now
